Old 12-21-2007, 03:33 PM   #1 (permalink)
Anyone ever weigh a 250 shortbed??
Has anyone ever weighed a 250 shortbed (crewcab or extra cab)?? If so, what do we weigh?
97' F250 4x4 crew cab. 4:10 gears,High Idle mod, Dana 60 conversion using 3"SKY RSK w/03' SD springs and 3 3/4" rear blocks to level. Tymar, Issopro gauges on 3 gauge pod, 3" down pipe, shimmed FPR and DP tuner 6 pos. chip (12-13-07).
http://community.webshots.com/user/amberjax
amberjax is offline
Old 12-21-2007, 03:38 PM   #2 (permalink)
hheynow's Avatar
Re: Anyone ever weigh a 250 shortbed??
Check your vehicle registration and title. My unladen weight is listed on both...but I don't have an F-250 shorty.
1997 F-350 PSD XLT RC 4x4 E4OD
303K miles and still running very strong
Using WVO and biodiesel since May 2006
hheynow is online now
Old 12-21-2007, 04:20 PM   #3 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: hheynow</div><div class="ubbcode-body">Check your vehicle registration and title. My unladen weight is listed on both...but I don't have an F-250 shorty. </div></div>
Only weight listed on registration in IL & WI, the two states I've licensed vehicles in is the max. legal licensed weight. Not sure about Your state but I KNOW those two could care less what Your vehicle weighs as long as it's LESS than the licensed max. weight. And they also don't care if Your loading causes tires or axles to be overloaded as long as Your still under You max. licensed weight.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
294,000 mi & NO Problems, LUK Clutch, and the Cat is buried in the back yard!
Dr.Evil is offline
Old 12-21-2007, 05:09 PM   #4 (permalink)
I have a shortbed supercab, 4x4, manual transmission and it comes it at just above 6500 pounds. I can't remember how much fuel was in the tanks at the time though.
Snowtow is online now
Old 12-21-2007, 05:43 PM   #5 (permalink)
hheynow's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Dr.Evil</div><div class="ubbcode-body">Only weight listed on registration in IL & WI, </div></div>
Not true. It's listed on California registrations.
Old 12-22-2007, 03:09 AM   #6 (permalink)
Nit
mine is very close to 8000lbs as it sits, add teh kids GF adn dog plus luggage and I'm over with the bed empty. BUt hell it still hauls 3000lbs more and fast too.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 12-22-2007, 12:22 PM   #7 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Nit</div><div class="ubbcode-body">mine is very close to 8000lbs as it sits, add teh kids GF adn dog plus luggage and I'm over with the bed empty. BUt hell it still hauls 3000lbs more and fast too. </div></div>
You run 2200 lbs over GVW?!?!?
My old CC dually with the IDI weighed right at 6400. I didn't keep a bunch of tools or junk in there though.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 12-22-2007, 02:11 PM   #8 (permalink)
On CAT scales mine was 7200 lbs with me setting in it.
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Sparkydm is offline
Old 12-23-2007, 10:32 AM   #9 (permalink)
Ok,
For those inquiring minds......
Just had the truck weighed this morning at the CAT certified scales. The truck was FULL of fuel,with just me and is a crew cab short bed. I've converted the stock 250 to Dana 60 with RSK, added rear sway bar, and have a "roll-n-lock" bed cover installed on the truck. So here are the weights:
Steer axle- 4100 lbs.
Drive axle- 3020 lbs.
Gross Weight- 7120 lbs.
Cost me- $8.50
amberjax is offline
Old 12-23-2007, 11:37 AM   #10 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: amberjax</div><div class="ubbcode-body">Has anyone ever weighed a 250 shortbed (crewcab or extra cab)?? If so, what do we weigh? </div></div>
My cc sb weighs 6900 w/ me in it and 50 gal of fuel.
ford pinto with spinner hubcaps from walmart- big pimpin
Thunder_struck is offline
Old 12-24-2007, 02:13 AM   #11 (permalink)
mine weighs something....
1997 F-250
Strait pipe and cold air...
8-15" subwoofers soon...
travisa is offline
Old 12-26-2007, 07:37 PM   #12 (permalink)
7650# fuel about half.
1997 CC SRW 4X4, 4.10s, 3 guage pod, built e4od, mbrp 4" straight, here kitty-kitty...., rough country 4" lift, MT 35" baja claw radials. Beans stage 1 injectors, dp 6 pos chip and diy intake. Custom dual electric fuel pumps and Stealth. Great dealing with Jeremy at LIPD!
cam1111 is offline
Old 01-01-2008, 02:47 PM   #13 (permalink)
7200 with almost full tanks of fuel
97 F-250 CC/SB 4x4 black,automatic by ULTRATECK,swamps 250,intercooled,gauges,5"exhaust,QsH2E,studs,pushr ods
huffkid is offline
Old 01-01-2008, 10:52 PM   #14 (permalink)
I weighed my truck stock with both tanks full of diesel. The bed was empty.
Cat scales: 6300 pounds
Regular Cab - Long Bed
1996 F350 4x4 PSD 4.10's
LoadHauler is offline
For advertising information, please visit our AutoForums.com website and C
