Has anyone installed rear SD springs, I know they are longer and I think the center is not the same as ours, I was just wondering if its worth moving the spring mounts to make them fit. I need to do something with my shackles and mounts anyway because they are rusted pretty bad. Thanks guys
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
I heard they where completely interchangable between the Stupid Duties and the OBS...Although I never compared it... I'll check it out if I get a chance tonight with my wifes Excursion...I put Stupid Duty rear lift springs in that when I lifted it.
As far as I know..just measured some they should work fine..a couple of members have installed them. I am installing some Donahoe SD lift springs hopefully this weekend! Got to make room for the 37" If anyone needs 35x13.5x18" Micky Thomson ATZ's let me know...as new 1500 miles+-
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
Thanks, Cary do the 35's rub on the springs when hard over? I am looking for tires and rims, just not sure if I will have a issue with the 13.5, I dont go off road unless hunting, but thats about it and my turning ratio seems to have gotten a little worse after the Dana 60 install. Can you pm me with the load rating and a price, O'yeah do you have any wheels? Thanks Cary
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">my turning ratio seems to have gotten a little worse after the Dana 60 install </div></div>
Do you have the steering stops adjusted to far out maybe? Mine turns sharper now than it did with the TTB.
No not yet, I left them where they were, I figured they were like that so you couldnt bind up the u-joints, but now that I think about it you would have to go pretty far. Then I thought it was because I moved the axle back a inch but that should make it better, right. I'm gonna go outside now and try it. Thanks
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
