Anyone mod'd suspension on 2wd to smooth the ride?
Just curious if there are ane reasonable ways to smooth out the choppy ride on the 2wd models. I searched and found several for the 4wd, but a 2wd solution eludes me. Any good options that do not adversly affect 5th wheel towing?
Thanks,
Doug
97 F-250 extra cab 2WD. K&N FIPK, 410 gears, Pace Edwards roll-top bed cover, Reese 16K 5th wheel hitch, defender trans cooler, 81K orig! New to me 10/2003. Pyrometer and trans temp pillar, boost gauge, SCMT, exhaust brake & t/c lockup, Hypermax downpipe/tymar out 4", ATS Intercooler (Thanks CaryT)
Re: Anyone mod'd suspension on 2wd to smooth the ride?
That Kelderman system looks nice, and I hear great things about it, bit it's spendy! How much benefit is there over regular airbags? Anyone added airbags and pulled a leaf, or had the springs re-arched, or went with a softer spring pack with the bags making up the difference?
Doug
On my 4WD I put Bilsteins on and took off the front and rear sway bars. Changing them two items made a real difference in the ride.
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
