Old 05-21-2007, 11:58 AM   #1 (permalink)
PSDan000's Avatar
My Photos: (11)
Send a message via AIM to PSDan000
anyone welded a reciever tube to a ranchhand rear bumper?
im going to need to weld one on mine with the lift im putting on, i bought a 2"x12" long reciever tuber at tsc, you guys think it would be ok to just weld that right to the bottom of the bumper? anyone have pics of what they did? thanks
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille,
318hp 643tq
#24
sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
PSDan000 is online now
Old 05-21-2007, 08:49 PM   #2 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
Re: anyone welded a reciever tube to a ranchhand rear bumper?
Dan did ya get ur tranny done yet?
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 05-21-2007, 10:38 PM   #3 (permalink)
Darth_Stroker's Avatar
My Photos: (6)
I bought one that bolted to my bumper with grade 8 bolts from tsc and then welded it on also.
Alan
97 F350 CC 4x4
BDP Stage 2's, Dominator 66 turbo, 4pos Wildman Chip, BTS Tranny, ATS .95 Wastegated exhaust housing, Hypermax IC and Pipes, comp 910 valve springs, MBRP DP and 4" exhaust, DIY intake, 17 deg SD hpop, Autmometer sport comp boost,pyro,tranny temp, 35" BFG A/T's, Centerline wheels,3.55 LS, Powerslot rotors,hawk pads, gpr bypass,ac mod,fumoto valve,coolant filter,ELC coolant,JD coolant eye,fpr shim,EBPV gut, IDM Mod
Fightin Texas Aggie Class of '98
Darth_Stroker is offline
Old 05-21-2007, 11:19 PM   #4 (permalink)
PSDan000's Avatar
My Photos: (11)
its in the shop right now, then when it gets back i get to tear it all back apart and put my IC and lift on [img]/ubbthreads/images/graemlins/grin.gif[/img]
Thanks Alan i will check that out.
-Dan
318hp 643tq
#24
My Webshots
Old 05-21-2007, 11:39 PM   #5 (permalink)
SoB
SoB's Avatar
Mine has been that way since day one back in '96. Works great, drilled plate for two d-rings for the safety chains.
Steve
Black '96 F250 XLT 4x4 SC,LB,7.3L PSD,Suncoast E4OD,3:55 Gears,Tymar Intake,4"exhaust,Hypermax intercooler,H2E,DIY StageII's, Wildman 4 position chip,Tymar HX mod,2001 HPOP,Ranch Hand Bumpers F&R, Warn 12000LB Winch,305 70R16 MTR's,Oil,Tranny&Pyro pillar mounted, 278K
SoB is offline
Old 05-22-2007, 01:52 AM   #6 (permalink)
I did the exact same thing Darth_Stroker did with probably the same part from the same store.It has been on the truck for some time now.I'll post a picture as soon as I have time to take one.
94 F-250 4X4 SC 5 SPD,ORIGINALLY IDI,355s,CURRENTLY 97 PSD ENGINE,97 F-350 SPRINGS,AXLES 410s,ALL OF THE BELOW.COPYCAT TYMAR,3"DOWNPIPE,STRAIGHTPIPED,RDS STAGE II's,SOUTH BEND CON OFE,GUTTED EBV,GUAGES,6.0 INTERCOOLER
PICS GUAGEPOD
TERRCO is offline
Old 05-22-2007, 03:03 AM   #7 (permalink)
PSDan000's Avatar
My Photos: (11)
is this what you guys are referring to?
http://tractorsupply.com/detail.asp?pcID...productID=28302
-Dan
318hp 643tq
#24
My Webshots
Old 05-22-2007, 09:31 AM   #8 (permalink)
tjbeggs's Avatar
I hope not. That thing is only rated for a 3,500 pound trailer!
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is offline
Old 05-22-2007, 06:28 PM   #9 (permalink)
My Photos: (6)
similar, I'm pretty sure mine is alot thicker and the chain holes were in a diffent location etc. I don't tow alot but I've pulled an 8000lb boat and a 32' tongue pull camper with no problems. I bought mine in 98 or 99.
Old 05-23-2007, 12:09 AM   #10 (permalink)
TheRubberDuck's Avatar
I don't have a Ranch hand rear, but I did weld my 2" reciever tube to my bumper. But I welded it on top where the ball used to mount. I have the stock chrome drop bumper. I think it's much stronger on top because you can weld down each side, and up and over the back. Then just get a drop hitch a couple of inches longer. But to counter act the longer drop hitch, I welded two 1-1/4" solid steel rod stringers to the frame that meet under the reciever tube. Kinda like ladder bars for the bumper. And I'm glad I did. I pulled a dump trailer WAAAAAY overloaded with just under 14k of scap iron. It handled it no problem. Bolt and weld is better, but I just went with the tube itself. Good luck man.
TheRubberDuck
1995 F350 Crew Cab 4x4 dually
Stage 2 DIY inj
RSB 140v IDM
Tymar Intake
DP Tuner 2 pos. chip w/custom switch
FPR Shim 70psi
3"dp to 4" straight piped to 5" Stacks
Hot Pedal
I miss you No.3
RIP #17
TheRubberDuck is offline
Old 05-23-2007, 12:36 AM   #11 (permalink)
Um my ranchhand replacement bumper is welded on the top of the drop instead of under it only reason I could think of was maybe so it would not drag or dig in if you were wheeling? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
Aljay is offline
Old 05-23-2007, 10:26 AM   #12 (permalink)
I removed the bumper, turned it over, then welded mine on with the reinforceing ring edge against the rear edge of bumper. Then I took a piece of flat bar from junk pile about 1/4" x 1" x 9" or so bent it like this \_/ and welded it just behind the ring and to bumper flush with back edge of bumper, this gives you a place for the safety chains, plus it reinforces the tube/bumper weld,& leaves you a flat step area. Pulled all over US with it. ( bumper is rated 1000/10,000 )
stoneburgfarmer is offline
Old 05-23-2007, 11:39 PM   #13 (permalink)
Dan, I welded a thin version of the tube you describe to my rear bumper, using a 110 miller. I was a career welder, but anyone with a little exp. and common sense can acheive the same results. I had a 20' bumper pull loaded with about 20-25k lbs of wood posts. Traveled around 20 miles, through the city, and never once did the weld or tube ever crack. I used that hitch for about 2 years, then decided to go with a reese when I started hauling my horses.
I'm sure someone will throw there unwanted 2 cents in about how stupid that was, so before anyone does, don't.
Dan, with the proper weld it will hold fine. If you do weld it, once it cools some, spray it with black paint, flat or gloss. That way if the weld does ever start to crack, you will be able to see it easier.
And BTW, I didn't doubt my welding abilities when I cut my tube off, and replaced it with a reese, just got tired of hearing my wifes
b!tching at me about the safety of her horses when they were being trailered.
2006 4 door swb dodge cummins all stock
* SOLD * 1997 F-250 PSD Ex-Cab 4x4
280,000 miles
4" lift - 35" BFG AT , Vault keyless entry,
3" Performance Parts DP w/CAT & muff delete,
FPR shim
May God be a Presence in Your Everyday
crfinc is offline
