Re: Anything missing?
Replace the seal on top of the tranny. When you take the tranny out you will see a small puddle of transmission oil on the top. It is in a recess so it never has the chance to run down to the ground.
I figured if it can leak out it can leak in so I didn't want to let any crud back in with any oil.
