does the ats intercooler piping run under the rad or what? the pipes in those pictures seem very long....
kevin
(mine) 94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a used p-stroke exhaust on the end of it 24xxxx miles, amsoil bypass, coolant filter
(dads) 02 350 7.3 powerstroke crew cab 4x4 ESOF
mods: itp in tank/prepump, 4 inch exhaust, ats housing, western diesel gauges, 6.0 transmission cooler, 6.0 Banks "technicooler" intercooler 150 bucks , coolant filter, "OEIS", b&w 5th wheel companion
18xxxx miles my gallery
WHY THE HELL SHOULD I HAVE TO PUSH 1 FOR ENGLISH? H O N D A - How Odd No Damn Acceleration
Actually out through the fenderwell. The only plus of the ATS is the fact there is no cutting. Pipes are smaller and go through the gap between fender liner and frame and connect to the ends of the tanks as opposed tot the sides as normal. I think Caryt had pics of the one he had on his.......
Diesel Mechanic 28 yrs
The others are right in the way the ic goes on the truck. I can tell you that I like it very much and works very well. Just make sure that all the clamps are tight, since there are like 6 of them! It does work well though!
1997 ECLB F-250 4X4, TAT e4Od,4.10 Open Diffs,Superwinch Manual Hubs, 265/75/16 Force 4 AT's, DP Tuner F-5 5-Position (Stock,Hi-Idle, 40 Tow, 40 High Alt Tow, 80 Econo ),3"DP,4" Exhaust,Tymar Intake,Full gauges. Intercooled. ATS Turbo.
With stock injectors, I do not regrete anything! CaryT helped me make the decission about it, and so did TomS. They both have more experience than me, and have good sound advice. They were bothright on about the ATS working well. I obviously have nothing but a stock truck to compair to, but I do not have any heat issues when towing at high elivation anymore!! Would do it again in a heart beat! No cutting or any mods. Very well done!
