auto trans mods for 97 (any good trans guys in Portland/vanc area)
I'm posting for my father in laws 97; He'd like to look at some good mods for the trans. Its all stock right now at 195K and no chip. The fluid is very clean; it runs good but gear changes are very soft and it acts like the converter 'hunts' between lockup and no lock depending on throttle load. I just don't know how to better describe it....
He pulls a 10K# travel trailer now and then, and wants firmer (not harsh) shifts.
Any ideas are appreciated!
thx!
Mike
94 F250 SC, 4x4, 5spd, 4.10ls, LuK, Toyo Country AT 285/16s, 190K, edge evo, shimmed FPR, Bilsteins, Add-a-leaf, 3"DP/4" exh, new ACs, ISSPRO, Term. 17* HPOP, pedestal mod, Tymar Intake and HPX, IDM and CCV mods
Re: auto trans mods for 97 (any good trans guys in Portland/vanc area)
My original E4OD died at 226k miles, then I went with a Ford-rebuilt E4OD, then added the mods in my signature file ~2 years later. All mod parts were from Tymar Performance, and self-installed. It was a pretty easy install. Not sure what it would do on an old tranny, but I have always figured that firmer shifts can't hurt!
I don't have any experience with anyone in the area who does tranny mods. I actually paid a former dealer tech to swap my tranny (first time I'd ever paid someone else for something like that, but I had no time since my daughter had just been born). I would recommend him, except I haven't been able to get in touch with him for over a year.
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 255k miles (Ford rebuilt E4OD at 226k)
ISSPRO Prototype Performax gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Edge Evolution on "Tow", Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 doorslammer drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
NRA member and certified firearms instructor
GOA member
IDPA member
Two suggestions:
1. Larry and Sons, would look here for more of a stock rebuild. Very reputable and honest shop
2. Gresham Transmission, they are familiar with the E40D and can do more of a performance build but I don't think they are in the same league as Richter69 or BTS
1997 F350 Crewcab, SRW, 4:10LS, E40D, Banks I/C, 1.0 Turbo Housing, Custom Chip by DP Tuner, Tymar intake, HPX mod and race pipe, fuel shim, Sonnax Valve and Tricumulator Springs, TruCool trans cooler, BD exhaust brake. Six leaf rear spring packs, air bagsTruck Pics
I go to Kaare (Cory) at Trans-Medic. Go down Burnside to 202nd. Just before Rockwood if your coming from gresham or it's just before the hill to gresham if your coming from rockwood. He can hook you up with a shift kit.
mandkole,
Have you tried Clark Co. Transmission off Hwy. 99? (360) 574-7649.
'95 F350 Red cc,zf5,157k miles,3"dp with 4" exhaust,Di Pricol egt and boost gauges,DP-Tuner F5,295/75/R16 BFG AT, SD IC, 1.0 A/R,IC pipe kit, and Stage 1's from GTS, South Bend smfw with the con O from BDP.
Thanks for the quick suggestions-- I forgot that I race with some transmission guys (the Floyds from Gresham and Tualatin trans), so I'll check with them. I'm not sure on the shift kit yet as I've heard that they can get pretty harsh. Perhaps its the chip programming also...
I've seen that many of the auto guys are using the Sonnax valve and tricumulator springs. What do these do? My FIL is on fixed income, so he'd like to just make the stocker better. I'm not real familiar with late model autos so the help is appreciated.
thanks, mike
a shift kit wont necessarily be harsh. it depends on what size holes you drill when you install it. since your not putting in big injectors, i would just put in a transgo tugger kit, a good cooler, and maybe a 4r100 converter. it wont break the bank, and it will make a big improvement. -marty
P.S. you should talk to Richter69, he can tell you exactly what you need, and i think he can even get you the parts.
1996 F-350 CC,LB,4x4,E40D by BTS,BDP stage II's,Hypermax H2E,Big Oil,ARP head studs,3"intakes,Comp 910 springs,4 pos. chip w/Jody's and Tony's tunes,electric fuel system,modded IDM,open element intake,6.0 intercooler,Stancor GPR,Hypermax downpipe,Magnaflow 4" stainless exhaust,Perma Cool remote trans filter,B&M 70274 tranny cooler,Interceptor Scan Gauge,a bunch of Autometer Sport Comp gauges,4.56's,RSK w/ V-codes,flipped spring hangers in rear,custom anti-axle wrap bars,37x12.50 Interco Super Swamper TRXUS MT's on 16x10 Eagle Alloys 143's(polished),Warn manual hubs,west coast mirrors from an F-700,Lund sunvisor,Stull polished stainless billet grille,diamond cut headlights,park/turn signal lights,and corner lights
