Auxillary tanks
I'm putting a auxillary tank in the bed of my '97 and would like to set it up so I dont even use the factory filler necks. I plan on machining a adaptor to put right on each tank where the factory filler hose goes on eliminating the vents and just putting one on my auxillary tank. I haven't looked yet, but I assume there is a return line going back into the factory tanks and I assume I should run them into the top of my auxillary tank to keep from having any pressure on the return from having 100 gallons fo fuel trying to gravity feed into the lower tanks. Any suggestions???
'97 F350 Crew Cab 4x4 5spd dually conversion. Downpipe, three stage chip, K&N, ranch hand front bumper, DMI crome rear bumper, eagle 5-spoke dually wheels, 255-85-16 bfg mud terrains, 5" chrome bullhauler stacks OUTSIDE of the 8 x 8 1/2 hillsboro aluminum flatbed, stainless 40 gallon saddle tanks, aluminum headache rack, stainless lighted grab handles, stainless rocker tim, stainless wheelwell trim, stainless cab visor, diamondtread running boards, 98 led's added. Dana 70 rear 4.10's limited slip with disc brakes and 5/8 wheel studs. over 200k
