Old 04-12-2005, 04:11 PM   #1 (permalink)
Babies and Intercooler question
Does anyone run babies without an intercooler? How are the temps? Do you tow with them and if so...how are the temps then? Thanks
1997 F250, PSD, CC, 4X4, 5SP, 4.10, 131,000 miles. 3" DP, 4" Diamond Eye exhaust. 4" lift, 315/75/16, 70HP chip, AFE Intake. Gutted Cat.
http://photos.thedieselstop.com/data...010002-med.JPG
druesch is offline
Old 04-12-2005, 05:00 PM   #2 (permalink)
My Photos: (14)
Re: Babies and Intercooler question
I have been running them for over a year without an intercooler towing fairly heavy 18-24k. I run Bill's Extreme program all the time, and have no problems. My right foot controls the heat, If i keep boost at around 20 psi i can maintain 65-70mph no sweat on some of the biggest hills.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt)
My Webshots
Moremph is offline
Old 04-12-2005, 07:28 PM   #3 (permalink)
i've been runnin my stage 1's without a inter-cooler, temps are manageable, but you have to watch them. in my tow mode it'll go up to 1100 pretty quick but tend to level out, if i run my race program it'll keep climbing until i back off the throttle a little, in my extreme program there's not a chance of towing. i have a intercooler that i'm going to install though just to help keep temps down a little.
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
on the way: more power
bullridin_fool is offline
Old 04-12-2005, 07:42 PM   #4 (permalink)
BIGRED95's Avatar
I've been running the babies w/out an intercooler and have towed a few times, as said before you have to adjust egt's with your right foot! I think I am going to try and get an intercooler this summer to help out a little. The babies are bye far the best investment I've made for the truck!! [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Justin
98 12V QC, 282,000 +, 5 Speed, with a few power enhancements
SOLD
2000 F-350 XLT CC SRW CC PSD, 249,000+Miles, 6 Speed trans with Luk Con-O-FE clutch, 4" ATS Straight piped, Tymar style intake, Ready to start modding.
Meridian Motorsports Dyno Jet 5/13/2006
219 HP 457 TQ
SOLD:
Lifted 95 F-350 XLT Crew Cab Srw Lwb Psd, 268,000 + miles, 35*12.50*16.5 Trail Cutter Radial RT,4.10's, BABY SWAMPS, Humped HPOP, Homeade Tymar setup with custom 4" intake, Gutted EBPV, Modified turbo pedistal, 1.0 turbine housing, CTI AIC, Auto Meter Lunar gauges, BDP 5 position chip, Complete Alpine sound system, Automatic, Billet torque converter, Tru Cool 28,000 lb external trans cooler, Bully Dog down pipe, 5" twin turnout stacks, 6.0 intercooler with custom built pipes, Optima red top batteries, Wanting more mods!!!
My webshots homepage
Bully Dog Dog Days Of Summer Dyno Pull 7/9/2005
347 hp 660 torque
BIGRED95 is offline
Old 04-12-2005, 08:25 PM   #5 (permalink)
sea97stroker's Avatar
[img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1997 F350 CC 5 Speed 4x4 , BDP Stage 2's, Wildman Chip, Isspro Gauges, 5 inch stacks, SD Turbo Setup,Banks Intercooler,Tymar Intake, SD Leather Seats. Dyno 427hp/813tq
www.BeansDieselPerformance.com
sea97stroker is offline
Old 04-12-2005, 08:55 PM   #6 (permalink)
Old_Machinist's Avatar
Same here,
Babies and no intercooler. Can control with right foot but have come upon across several times it would have been good to have one. I have seen 1475 on a few times for less than a minute. I have a TWildman 4 pos chip. The 1475 was on the dyno burn pulling the 5th wheel in my sig. I also have been able to set an CEL several times but not as much lately. I still can not get over 30 psi of boost no matter how hard I rev and how large of a load I am pulling. It hits about 27 then just drops off big time. Don't know if I really want to be boosting the stock turbo up to 30 very much as I am sure that the thrust bearing would not take it for long. Would rather spend money on hopped up HPOP than a turbo.
96 Ford Powerstroke, Centarus Converson CC, 4.10, Long bed DRW, 4 pos TWildman chip, SD HPOP, 6.0 Intercooler, 3.0 downpipe and Bully Dog 4.0 exhaust, AFE intake system, pyro (pre turbo),trans gage (located in test port), Custom Fabion Motosports Torque Converter, pump mods, Tugger trans kit, Torqueshift tranny cooler, Firestone air bags, Rancho RX 9000 adjustable shocks, and baby SWAMPS!!
Pulling a 2000 American Star, 34RLCK bedroom and living room slides, w/d stack ,12,640 lbs.
Total weight 19,300. New addition 20ft VIP Bowrider boat towed behind 5th wheel, total length 74 ft, 24,000 lbs!
Old_Machinist is offline
Old 04-12-2005, 09:41 PM   #7 (permalink)
Banned
Last weekend we had a friends truck loaded with 5 quads and a pretty heavy 22' trailr and pulling some hills it was way to hot. Couldn't use all the power. However this was on a very hot and smokely extreem program. I think with a different program it would have been fine. With the babies especially it is all in the programming. They will work good without an intercooler but to be able to tow with them up to their potential you will need one.
gtspowerstroke is offline
Old 04-13-2005, 07:42 AM   #8 (permalink)
MarkEkberg's Avatar
My Photos: (13)
See sig. No intercooler, and new babies. I will be looking for a intercooler when $$ allow (mainly after my impala project is done in a few weeks). Have towed a few things,and a few heavy things. All I can have the chip on is first hp setting. Otherwise temps head above 1300.
It will work, but as stated a few times already you have to pay attention. For what a used IC set-upp costs it would be a wise investment, but get the babies first because a IC dosean't require a babies, however babies need the IC.
MarkEkberg is offline
Old 04-13-2005, 02:22 PM   #9 (permalink)
My hot program is a Bill's burn specifically for Babies. With light (4000lbs) or less, the truck runs cooler with this burn than stock or the other Bill's burns not specifically for babies. Go figure. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 cc, shortbed, XLT, 4x4, 3.55, 3" downpipe, 4" exhaust, no felines in sight, gauges, tymar intake, 4 pos chip, baby swamps, superduty HPOP, bypass oil filter, IDM mod, with 150k of "experience".
motobuff is offline
