Old 06-30-2005, 08:55 PM   #1 (permalink)
Baby Swamp or 175 cc versus BDP stage 1
I have a 1996 F250 7.3 It has a 6-position TS Performance chip, gauges, and a cold air intake. I just can't make my mind up on what injector to buy.I'm looking for a lot of smoke!! Does anyone have any suggestions or opinions?
1996 F250 XLT ExtCab 4wd, E40D 4:10L,315/85/16 BUCKSHOTS, Straight Pipe, Ts Performance 6 position chip, Isspro Pyrometer, Boost Gauge set in "A" Pillar,3"DP,Tymar intake,EBPV Gutted,Lincoln Ranger 250 Welder,
WelderWV is offline
Old 06-30-2005, 08:58 PM   #2 (permalink)
My Photos: (22)
Re: Baby Swamp or 175 cc versus BDP stage 1
Why?
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Hammer
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
Old 06-30-2005, 09:35 PM   #3 (permalink)
Banned
bdp stage 2's can layout some smoke if ya wantem too and they make very good power aswell.
luke
lukecline is offline
Old 06-30-2005, 09:46 PM   #4 (permalink)
BlueMule's Avatar
My Photos: (12)
Why?
Hammer
......ditto..........who do you know that's impressed with pollution and wasted fuel?
BlueMule is offline
Old 06-30-2005, 09:49 PM   #5 (permalink)
TravisT's Avatar
Mine smokes bad when dialed up and I DON'T like it at all.
But FWIW, the Stage IIs smoke a ton.
1997 F-250HD 5-SPEED 4X, New 4.10s (PRECISION GEAR), Truetrac (DETROIT LOCKER), Hubs (WARN), 4" lift (SKYJACKER), 35x12.50 (PRO-COMP), Classic Lock (M/T), 100 Gallon Nomad (greasel.com), Dominator 66 Turbo, Stage 1 Injectors, 6 Position (BDP), Clutch (LuK), 6.0 Intercooler (4WP Dumpster), DP & Guages (SCHEID DIESEL), 4" exhaust - properly loud (BD-POWER), 203' Tstat (dieselsite.com), Prerunner bar (N-FAB), Yellow tops (OPTIMA), Diamond Clear headlights with H.I.D. conversion, 205000 (s)miles 2005 Emblems
TravisT is offline
Old 06-30-2005, 10:40 PM   #6 (permalink)
take it easy on the guy jeeze if he wants his truck to smoke let him personally i think its pretty cool when you can lay down a jet black cloud
www.upstatebombers.com
the fords gone i got a cummins
DBogo is offline
Old 06-30-2005, 11:09 PM   #7 (permalink)
My Photos: (14)
Like we were talking about earlier today,
the BabySwamp and the stage 1 injectors utilize stock nozzles, thier will be smoke under lugging conditions and at throttle input however both sets should clear up pretty good with the stock charger under boost.
If you are wanting the extra power (Fuel which also equals smoke) in the bottom end then you will need to step up to the next size which would be the 175/173's or the stage 2's which utilize a bigger nozzle that flows more fuel at less throttle input. You are less likly to burn this amount of fuel at full boost so you will prolly still see some haze even under full out hauling rear conditions.
Hope this helps Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt)
My Webshots
Moremph is offline
Old 07-01-2005, 12:54 AM   #8 (permalink)
GSXRTURBOQUAD's Avatar
[/ QUOTE ]Not true, if you have oil. With proper atomization and stage2's you will clear to a grey haze(as long as your nozzles are the correct spray angle) [img]/ubbthreads/images/graemlins/biggrin.gif[/img]!
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 07-01-2005, 01:20 AM   #9 (permalink)
Banned
On my truck w/ stock oil and turbo, stage 2's clear upto a slight haze. So i guess that leaves the nozzles for discussion. IMO look at dyno sheets and time slips of both stage 2's and 175's then make your decision (both are in my sig below for bdp stage 2s)
luke
Old 07-01-2005, 02:34 AM   #10 (permalink)
Banned
With more oil pressure you will be injecting more fuel. Seems I heard something about your truck smokeing more since the big oil due to the added fuel.
gtspowerstroke is offline
Old 07-01-2005, 07:49 AM   #11 (permalink)
For what it's worth, I love my Baby Swamps! With the right tuning, you can have the best of both worlds! Keep your foot out of them and you'll be fine! Put your foot down, and watch it smoke! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Just my .02 worth!
2P
96' F350 CC 4X4 5spd 4.10's
150cc injectors - SBC Con OFE - Gutted EBPV -
Banks IC - Autometer Guages - Tymar intake - SS 4" exhaust -
Aero turbine - Mag Hytec diff covers
pp96f350 is offline
Old 07-01-2005, 08:32 AM   #12 (permalink)
If I drive normal with my 175's they don't smoke. But if you feel the need they can stop traffic. And with the BB Garrett they clean up to a light gray fog on the top, but they will never clean up all the way.
CharlieII is offline
Old 07-01-2005, 11:34 AM   #13 (permalink)
I am happy with my stage ones. I like the fact that my foot controls the smoke, only there if I get after it. I also like that they drive like stock until I need it. Under "normal driving" you don't notice any difference, but get it and the smoke is flowing and you are [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
It does clear up pretty quick with the stock turbo.
'95 F250 PSD, Bean 170's, AFE intake, HPC'd 3" downpipe and 3 1/2" cat delete, Magna flow 4" exhaust, DP/Bean 6 pos flip chip with TWildman burns, 6" lift, 35's, 4.10's, ARB frt/rear, custom pre-runner bumper, and some stereo stuff. Daily driven.
'73 Bronco buggy
'06 Jeep Liberty CRD (stock for now)
'90 Miata go-cart
rckcrlr is offline
Old 07-01-2005, 11:38 AM   #14 (permalink)
My Photos: (21)
Swamps FM 250's will give you all the smoke you want. I love the thick black smoke but in my opinion it has its time and place i.e. tailgaters, drag strip, messing with your dodge driving friends. I can't stand any smoke while I'm just driving on the Hwy or in town. A lot of the smoke can be brought on with a good program and then "turned off" by switching to a mild program.
JIM
His: 1997 F350 PSD, CC, 4X4, 4.10's, 35/12.5/16.5's BFG's
Hers: 1997 F250 PSD, X-Cab, 4x4, 4.10's, 315's
All My Photos
Toys/Blown Head Gasket
Drag Videos
motor/turbo/fuelsystem pics
Traction Bars
Father & Son Time
THE_ALASKAN is offline
Old 07-01-2005, 09:41 PM   #15 (permalink)
I run the 175/173's as well, Doesnt smoke under light throttle to bad but when the peddle hits the floor(most of the time) smoke sceen. The power is great, Dynoed at 266hp-512tq. Now this is with a mild chip,stock turbo and fuel system with no inercooler.
96' F-250 Ex-cab 4x4
Injectors,Intake,5-in exhaust,Ts flip chip-6po
35's on centerlines,Aotometer tripple pod with gauges,limo tint all around. all I need now is big oil,fuel system,inercooler,a big F-in turbo and a DD-clutch to hang on while pullen-------Maybe a little nos and some water and booom!
Just bought an 06' F-250 Lariat,crew with all the options-even has 20's on it and its a 4x4 (dealer packadge.)
coldsmoke is offline
