Old 04-13-2006, 12:37 PM   #1 (permalink)
My Photos: (9)
Baby swamps
Hey has anyone done them? With the mods in my sig will it give me alot more power? I want to get to like 250 on the dyno. I dont know if I want to save more money and go stage I's. Thanks for any info.
Jon K
94 F250 4x4 SC LB 367,000 miles (Same motor it came from the factory with) 5 speed, Intake, Bully dog 4 pos chip, Egt gauge, 3in down pipe into 3in straight pipe, 16x10 rims 265/75/16 tires, 2in leveling kit http://photos.thedieselstop.com/show...=1&thecat=500/
jonathankasprzak@hotmail.com
kasprzak85 is offline
Old 04-13-2006, 01:33 PM   #2 (permalink)
Re: Baby swamps
250 will be no problem with the baby's, you will need to get your chip reburned though.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 04-13-2006, 03:12 PM   #3 (permalink)
Banned
Re: Baby swamps
You should see an easy 250-260 with your current programming unless the bullydog stuff is even worse than I think.
96strokin is offline
Old 04-13-2006, 03:55 PM   #4 (permalink)
My Photos: (9)
Re: Baby swamps
Someone on here said you can only pull about 200 with the stock injectors.
Jon K
Old 04-13-2006, 04:04 PM   #5 (permalink)
Re: Baby swamps
He's talkin about with the new injectors, but I personally wouldn't run bullydog programing with modded injectors, or stock ones for that matter.
Old 04-13-2006, 04:39 PM   #6 (permalink)
Re: Baby swamps
kasprzak85,
I have the babies and 250 was no problem. I would say with the right programming you should be around 300hp.
Just my .02 worth.
2P
96' F350 CC 4X4 5spd 4.10's
150cc injectors - SBC Con OFE - Gutted EBPV -
Banks IC - Autometer Guages - Tymar intake - SS 4" exhaust -
Aero turbine - Mag Hytec diff covers
pp96f350 is offline
Old 04-13-2006, 04:58 PM   #7 (permalink)
Scott's Avatar
My Photos: (34)
Re: Baby swamps
the '95 in my sig. did 300 hp with baby swamps, chip and stock exhaust (flat downpipe, cat and all) a few weeks ago.
'97 F250 SC 2wd, auto, 3.55
'02 F250 CC 2wd, auto, 3.73
'95 F250 SC 2wd, auto, 3.31
Scott is offline
Old 04-13-2006, 05:13 PM   #8 (permalink)
pwrtrip's Avatar
Re: Baby swamps
When I had baby swamps I did 344hp [img]/ubbthreads/images/graemlins/smokin.gif[/img]
jeremiah
1996 crew cab 4x4 black psd
BDP 250cc hyrbids
BDP fuel system
Stealthhinator dual ipr hpop
H2E
TDP tuning
515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke
Truck and misc pics
pwrtrip is offline
Old 04-13-2006, 05:16 PM   #9 (permalink)
gnxtc2's Avatar
Re: Baby swamps
Did 225HP to the rear wheels with stock injectors and an old TS program. Stuff is in my sig.
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, US GEAR downpipe, Bilstein 5150s, Front add-a-leaf w/urethane bushings, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, Shimmed fuel regulator, 4" Exhaust-Straight piped,FORD AIC, Custom triple A-pillar gauge holder,B&M Supercooler, gutted EBPV, B&M Transpan, ART Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, 149K
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 04-13-2006, 07:42 PM   #10 (permalink)
Banned
Re: Baby swamps
i did 324.7hp 620.2tq with babys.i have dyno sheets from stock to know.just click the sleeper below then go to dyno.i have a list of mods with each run
tubzz is offline
Old 04-13-2006, 07:48 PM   #11 (permalink)
My Photos: (9)
Re: Baby swamps
I like the bully dog chip got it for cheap and I am going to get it reburned when I get the baby swamps. Either Tony or Jody programes. Thanks for everyones info.
Jon K
Old 04-13-2006, 08:50 PM   #12 (permalink)
Re: Baby swamps
What Stage I's are you lookin at? We recently had a price increase but they are still cheaper then Baby's. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Ryan Bean
beans diesel performance
<font color="red">bdp</font> Custom Injectors
<font color="red">bdp</font> Custom Fuel systems
<font color="red">bdp</font> Custom Turbo systems
Stealth Dual HPOP Systems
Get Destroked W/Destroke Cummins Conversion Kits
Whatever else you may need to go fast or tow with your truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 5SPD F350 4X4 4:11LS For Sale
New Truck- 02 F350 Dually 4x CC 6spd- 05 CR Cummins Built For Pullin And Raisin Hell
BIGBEAN is offline
Old 04-13-2006, 09:04 PM   #13 (permalink)
Re: Baby swamps
[/ QUOTE ]I called and you wanted more for your stage 1's then I put out on BABY's
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
Old 04-13-2006, 11:28 PM   #14 (permalink)
Re: Baby swamps
Dunno, just goin by advertised price, must be where I am confused.
Ryan Bean
BIGBEAN is offline
Old 04-14-2006, 01:21 AM   #15 (permalink)
Re: Baby swamps
hey man im glad that chip works well for you, we just installed beans stage 1s in my fathers 97 f250, he uses the exact same bully dog chip you have, the truck runs incredible, puts you back in the seat and a smile on your face through every gear.
96 f250 ext. cab 4x4. ts perf. 6 pos chip, 3 inch dp. 4 inch straight exhaust, no cat or muffler, valeo clutch, lunar series guages, fpr shimmed, open element filter. 208,000 mi. elizabeth colorado
mnapp is offline
