Old 04-29-2006, 12:40 PM   #1 (permalink)
Baby Swamps are in!
well the job is done. my truck is running great. the EGT's are way out of control. the IC is next. I think that a turbo would have been a better mod. it seems that the low end isnt as good as I had unless I run it on hot or very hot(bills burn). on the hot settings by the time I hit 60mph I'm at 1300 degrees. there is definately improvement if I can get the EGT's under control. hopefully it will run better in the lower programs after a few more miles. bottom line is I got a grin but not Perma Grin. it's going to take a little more to get to the Perma grin. [img]/ubbthreads/images/graemlins/depressed.gif[/img]
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
Old 04-29-2006, 02:40 PM   #2 (permalink)
Re: Baby Swamps are in!
I have a feeling once I put the Bean's stage 1's in I will feel the same as you.
Sample is offline
Old 04-29-2006, 03:07 PM   #3 (permalink)
maloney's Avatar
yep, its easy to send the EGTs through the roof with the big injectors.
-Black 1997 F-250 4X4 regular cab
-K&N intake/filter
-stainless Bully Dog 3" down pipe and 4" exhaust
-Tony Wildman chip
-Beans Stage I injectors
-Tru-Cool 4739 MAX transmission cooler
-A-pillar with Autometer gauges boost/trans/pyro
-Donaldson semi-truck oil filter
-John Deere coolant eye (thanks deeretrac)
-Bronco rear fuel tank (33 gal)
-Fuel tank vent mod
-150,000 miles
maloney is offline
Old 04-29-2006, 04:15 PM   #4 (permalink)
My Photos: (5)
Get Twildman to reburn your chip with his stuff, the Ts programs are not that great with the babies, I have been through them all.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 04-29-2006, 05:01 PM   #5 (permalink)
yeah, I'm gonna have to do something. I dont feel like I have all that much more then with stockers and the edge evo. it runs a ton better but its like it doesnt want to spool up. when it does its great it just hard to get used to the 1.15 housing again. the .84 was awsome. might have to try t-wildman and a 1.00 housing.
krowell is offline
Old 04-29-2006, 09:16 PM   #6 (permalink)
It works ok with the Fuel7 burn from TS but other than that you need to get the chip reburned for the injectors. I had the same problem with my old Bill chip and babies. Lotsa smoke but not a whole lot of power. When the new chip came in, it was a big difference.
ART
2005 Dodge Durango Limited w/HEMI.
2006 Chevrolet Cobalt LT.
agsF2501 is offline
Old 04-29-2006, 10:06 PM   #7 (permalink)
ThreeStarJR's Avatar
Kevin, the reason that the .84 felt good was because you only had at best 95 cc of fuel @ each injector with the stockers. You made the right move in going back to the 1.15 stock housing to get more air to the 150cc babies. spend the money to get with tony and fine tune your chip to complement your new fuel...don't even think about spending money on a 1.0 housing, it would be a waste on higher rpm's with the babies...
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
#3
ThreeStarJR is offline
Old 04-30-2006, 12:10 AM   #8 (permalink)
Ok I'll just e-mail tony tommorrow. the only problem is he told me before that he only does 4 position chips and I want six. anyway I am going to try the evo tommorow and see if thats any better for the time being. hope tony can fix it.
krowell is offline
Old 04-30-2006, 02:21 AM   #9 (permalink)
"he only does 4 position chips and I want six"
Did he explain why only 4 position chips are available
from him? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Sparkydm is offline
Old 04-30-2006, 10:47 AM   #10 (permalink)
he told me through e-mail so I did'nt get the whole story. that was about a year ago so it might be different now. the edge evo is working better then the TS program
krowell is offline
Old 04-30-2006, 12:09 PM   #11 (permalink)
My Photos: (5)
he can do a six, but I think there is a problem with his 6 pos burner. He can tell you for sure. T should be back in town in a day or so.
1999.5 cc dually
Old 04-30-2006, 06:49 PM   #12 (permalink)
hope so put a lot of work in and so far not any gain!! without the chip my truck ran better then the chip did in stock. how can there be that much difference in programming. how can TS sell chips if they run like this? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
krowell is offline
Old 04-30-2006, 10:33 PM   #13 (permalink)
I have the same problem... just got my BDP stage 1s in and changed my .84 houasing back to 1.15. It is making less boost, more EGTs and about the same power. I thought I must have a leak in my turbo - i/c somewhere ??? I guess L'll drive it for a week and get back into it next weekend. Bob.
Now - 2003 3500 CTD
Sold - 96 F250 SC 4x4 E4OD 3.55, DP Tuner Chip, T Wild prgms, Tymar,Downpipe, Isspro, Jordan, Sonnax & Tricum, Mobil 1 ATF, BDP stage 1s, SD I/C W/GTS install kit, GTS exhaust brake, 8K 5er, 18' Mariah.
NYTPSD is offline
Old 05-01-2006, 12:06 AM   #14 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
I've got swamps Toddlers and its hard to get the temps up as high after I gutted the EBPV, if you want to go that route.
-Michael
Michael Paul
1995 F250: Regular cab, 7.3L PSD, 5-Speed, 4x4, 4.10 LSD, gauges, 2L chip, injectors, turbo, 4" downpipe - 6" tip, clutch, fuel system, Medium oil, Headstuds, Valvesprings, Cab lights, Dana 60 - New Look Soon!
1995 F250: Regular cab, 7.3L PSD, 5-speed, 4x2, 3.55 open, Intake, Downpipe, 4" exhaust, clutch, 2L chip, short throw shifter - To do list!
My Webshots
Dieselfever78 is offline
Old 05-01-2006, 04:10 PM   #15 (permalink)
I talked to Swamps today. they tell me that I got old, bad progamming and that I'm only burning about half the fuel that I should be. that makes sense because of how retarded it felt. so I sent the chip back to be redone. should be here first of the week. I hope this does it cause I could have sent it to tony wildman today. I cant wait to see what good programming can do. I whooped a truck today that I couldnt beat before and I was using my edge evo. ok perma grin on standby!
krowell is offline
» Wheel & T
