Old 12-27-2005, 07:35 PM   #1 (permalink)
kfjensen's Avatar
Back-up Lights
I know most guys add a another additional set of lights (which is on the future list [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]) but are there any aftermarket bulbs that are better then the stockers? LED's? Thanks.
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 12-27-2005, 08:19 PM   #2 (permalink)
My Photos: (9)
Re: Back-up Lights
Several years ago I purchased some back up light bulbs that were supposed to be 50 watt bulbs, but I could not tell the difference. I now have a set of Hella driving lights under the bumper and they do a wonderful job.
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
SLAPS Treasurer
Member of FOKISD
<font color="red"> #5 </font>
Truck pics at http://community.webshots.com/user/ytee1100
ytee is offline
Old 12-27-2005, 09:40 PM   #3 (permalink)
Re: Back-up Lights
I just put in a set of the White Knight backup lights and really pleased with the difference. They are angled out and illuminate 2-4 ft outside the line of the truck. Never can have enough light when backing up. I bought mine from the guys at GOS Performance. They know their stuff and always provide prompt service.
kp
97 F250, 4X4, CC, DP, 4" Magna-Flow exhaust, Tymar Intake, BTS 4 Position Chip; BTS Tranny; Baby Swamps,Tru-Cool Max,Autometer 3 gauge A-Pillar,HX,Hot water mod, Centramatic balancers;Correct-Trak;Rhino-liner, SKY-FI, Prodigy Brake Controller, Bilsteins all around, Royal Purple in the Diff, Pro-Tech Headache Rack, N-Fab Nerf Bars, Heated Seats..aaahh. Auto-Dimming Mirror with Temp/Compass; Polk Audio with SONY Head Unit. GOS Headlight Harness with Diode Mod.
bobtaildog is offline
Old 12-28-2005, 12:13 AM   #4 (permalink)
kfjensen's Avatar
Re: Back-up Lights
kp
Thanks Bobtail I will check them out.
Kevin
kfjensen is offline
Old 12-28-2005, 03:10 PM   #5 (permalink)
Re: Back-up Lights
I just mounted a pair of the really cheap white tractor lights on my bumper, works good and I think I'm in about a whole 20 bucks on the deal.
97 psd, sc, 4X4, 4 pos Wildman Chip - Tymar Intake/H-max Downpipe
'99-'00 Igneous Pinners, '00 Igneous Smurfs, '02 Dynastar Arno Adams, '03 Atomic BIG Daddies, '04 V-Pros
-- Resident Bilge Don Quixote #3
lemon boy is offline
Old 12-29-2005, 01:28 AM   #6 (permalink)
PSDfreak's Avatar
Re: Back-up Lights
i've got the same setup...although I just lost my second lamp on the driver side...not sure why. The first one was cracked (the sealed lamp) so water got into it. Can telll why this second one went out. I've got another lamp to put in it so we'll see how it goes. They other one is still original. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 12-29-2005, 03:01 PM   #7 (permalink)
Re: Back-up Lights
I need to put some lights on mine, how'd you wire'em? [img]/ubbthreads/images/graemlins/confused.gif[/img]
1972 Ford F-250 4X2, 1997 F-250HD x-cab PSD 4X4, Tymar Intake, 2000 Excursion XLT PSD
BulldogPSD is offline
Old 12-29-2005, 03:17 PM   #8 (permalink)
Re: Back-up Lights
I have everything sitting here its just not on, Ill take a stab at it... You have a wire coming from the stock reverse lights, a wire from a 12v source, and they both go to a three way stitch. The other wire coming from the switch goes to a relay that also needs hooked up, you have a ground, constant 12v, and your switched wire and the wire that goes to the lights. That should be it! Well hope that is what you are looking for, Jordan
96 f350 7.3 206kmiles 4x4 stage 1's downpipe and gagues.
jray3369 is offline
Old 12-29-2005, 09:23 PM   #9 (permalink)
My Photos: (6)
Re: Back-up Lights
I hooked mine up to the big 7-wire connector under the truck.....work like a charm! [img]/ubbthreads/images/graemlins/smirk.gif[/img]
'95 XL SuperCab, LWB, 4X4, 204,000 miles, E4OD, 4.10 LS(when it wants to be!), body lift, 305-70-16 Cooper STT's on 10" Eagle Alloy wheels, "Brand X"-inspired home-made open-element air filter, 3" downpipe & 4" straight pipe with 5" stainless tip exiting in front of the rear wheel, 6 pos. TS Performance chip (going to visit T. Wildman soon, I hope), FPR mod, A/C mod, MileMarker manuals, onboard air (York running off the alternator...1 five gallon tank) with dual Grover air horns
2000 Jeep Wrangler Sahara Edition, white w/tan top & interier, 119,000 miles, 4.0L, auto, loaded.....no mods, yet!
Knothead is offline
Old 12-30-2005, 10:40 AM   #10 (permalink)
Tom S's Avatar
My Photos: (20)
Re: Back-up Lights
Same here a relay controled circuit without all the work.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 12-30-2005, 04:51 PM   #11 (permalink)
Re: Back-up Lights
I wondered about that, its for trailers that have reverse lights, so why not? if it will power those lights then it should power bumper lights. The only problem i see is if you hook to a trailer with them you may over load it? Maybe not depends on the set up i guess
jray3369 is offline
