Old 03-22-2006, 01:43 PM   #1 (permalink)
is it bad to stack add-a-leafs?
Think about going with a 2 1/2 lift instead a 4 inch now for towing reasons
I have already added a add-a-leaf in the rear and with the kit it comes with another add-a-leaf Is it ok to stack them on top of each other?
Tanner
2000 Crew Short F250 4x4 Lariat
White over Ebony
Limo Tint all the way around
F350 Blocks- 1 1/2" Shackle kit up Front
Eagle Alloys
265/75/16 Toyo Open Country M/T's
5" straight pipe
~sold~
1992 Ford F250- excab- 4x4- Canary Yellow- 12 valve Cummins Swap- NV4500 5spd-
"Ford Makes It-Cummins Shakes It"
Rip Rook's 4inch straight pipe exhaust
~custom~ fuel plate
Pump Timing Set to 17*
Isspro Pryo and Boost Gauges on the Pillar
rolling on 285's Toyo M55's
bananaboatford is offline
Old 03-22-2006, 01:48 PM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
Re: is it bad to stack add-a-leafs?
I wouldn't think that the ride would be too good.
As far as if its bad, I don't know?
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 03-22-2006, 02:22 PM   #3 (permalink)
i would consult a reputable local spring shop im sure they will give yuou all the pros and cons of doing such things [img]/ubbthreads/images/graemlins/shrug.gif[/img]
96 f-350 2wd dually powerstroke roach coach 275k BTS tranny,4.10, XLT,alcoa alloys,tymar intake,western diesel downpipe,"diet" kitty,a/c bypass mod,coolant filter behind front bumper, beans stage 1's,dp tuner 60hp pcm, hx hardline crossover from ITP......
01 f-350 dually powerstroke lariat supercab 40k 4.10 4x4 ESOF, leather, heated seats all the toys i dont need, 4r100,garret ball bearing turbo,tymar intake, ccv redirected out under the truck,magnaflow 4inch tuner exhaust,no cat,a/c bypass mod,zoodad mod,autometer cobalt pyro boost and tranny,dp tuner 4program chip,ITP complete regulated return fuel kit,ITP hx crossover hard line,203 t-stat and dieselsite billet t-stat neck, coolant filter,dieselsite high pressure intercooler boots
chris bottom is offline
Old 03-22-2006, 02:23 PM   #4 (permalink)
to tell you the truth and I dont know how it is possible- but after installing the first add-a-leafs it seemed to ride better than stock
Maybe my springs are shot?
White over Ebony
Eagle Alloys
5" straight pipe
~sold~
~custom~ fuel plate
Old 03-23-2006, 03:52 PM   #5 (permalink)
when i bought my new 01 i didnt like how soft the stock suspension was so i had my local spring shop add a spring in both front and rear.....they were spec'ed for a f450 and it not only lifted the truck nicely without a lift kit but it made the truck handle like a damn sports car.......little rougher ride but its a truck not a caddy [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 03-23-2006, 04:33 PM   #6 (permalink)
brahamfireman's Avatar
does your original add-a-leaf go over or under the rear springs.
most lifts the leafs go under the rear springs, so if your first set is over the springs, like the factory over loads, then you should be alright.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 03-23-2006, 11:31 PM   #7 (permalink)
Under and it lifted the arse end up atleast a good 1 1/2"
White over Ebony
Eagle Alloys
5" straight pipe
~sold~
~custom~ fuel plate
Old 03-24-2006, 04:53 PM   #8 (permalink)
I'd run em, provided they are shorter then the ones you already put in, so that you still have the shortest leaf on bottom. we have stacked many leaf springs in mud trucks to gain lift because blocks are not strong enough. [img]/ubbthreads/images/graemlins/shrug.gif[/img] I dont see why this wouldnt be different.
Diesel Rod
Old 03-24-2006, 05:54 PM   #9 (permalink)
I put two add-a-leafs on the front on my 92 F350 and it beats the crap out on me. The front end won't even move an inch when I jump up and down on the front bumper. Hopefully soon I will be getting rid of one add a leaf and putting a reverse shackle on
'96 F350 XLT 4:10 gears ZF5 speed, TYMAR filter, Joe Servo IDM, HX mod, WD downpipe, 4" exhaust, test pipe, 285/75/R16 Goodyear MTR's
'92 F350 Spray Truck, 600 gallon tank, 62 ft booms, 4:56 gear, 11.00 22.5 tires, the rest is stock
barney1 is offline
