Ball Joint Replacement... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-14-2009, 06:16 PM   #1 (permalink)
nm50's Avatar
Can ball joints be replaced at home? Any special tools needed? I have a D60 to swap for my D50 but want to keep the steering knuckles and brakes from the D50 and install new ball joints.
Also, does anybody sell all the parts I need to rebuild the D60 (ball joints, bearings, seals, etc.) as a kit?
Thanks!
1997 F250 4x4 CC PSD E4OD/3.55s
2000 Durango 5.9 AWD
2001 VW Jetta TDI
nm50 is offline
Old 11-15-2009, 04:57 PM   #2 (permalink)
I Have done mine and parents f-350 this year the only special tool i needed want a ball joint removal/installation tool which is pretty much an overly beefed up C clamp. and available for renting at any o-reilly or advanced auto probaly others also and then up to a 1 1/8 i beleive socket ...i prefer 1inch wratchet and a biiig prybar to break em loose. other than that everything else is all sockets i needed no special tools except the D-50 D-60 axle nut socket
and as far as kits i dunno but ...axle seal, ball joints upper/lower, inner/outer bearings and races, if u want to spindle bearings, hub seal, new ujoints, nice warn locking hubs if you dont got em and ur smart ;> umm i beleive all that x's 2 i just got done rebuilding parents 95 f-350 d-60 and put in all that and i beleive total bill at o-reillys was 350 bucks
2005 KR CC SB Auto 6.0L - 4in straight to the back no muff or kitty, Upfitter High Idle mod, Blue Spring
1996 F250 Crew Cab LBox 5sp "Sold"
1967 Ford Fairlane 2Dr Post factory radio delete non ac, manual brakes, manual steering car. 80% restored working on interior Body and Paint done- 390FE stock oil eater, C6, Starshifter, Micky T Indy Style 60 Series on back. Originaly Black repainted black
1972 Ford Gran Torino Fastback 351 Cobra Sold
1979 F350 Custom Crew Cab Short Box replaced Torino for project vehicle..
2004 Lincoln LS8 "Sold"
2008 Kawasaki Brute Force 750 4x4i
96strokerlb is offline
Old 11-15-2009, 05:30 PM   #3 (permalink)
nm50's Avatar
I have MileMarker hubs on the D50 and would like to swap the whole setup onto the D60 installing the balljoints at the same time. Sounds like it shouldn't be too bad. Thanks!
2001 VW Jetta TDI
nm50 is offline
Old 11-15-2009, 09:45 PM   #4 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
I have to ask. Why do you want to put the D50 knuckles on the D60? If it is because of the mile marker lickouts they will fit the D60.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
Old 11-15-2009, 10:26 PM   #5 (permalink)
nm50's Avatar
I believe D60 and D50 are the same from the ball joints out. That should include knuckles, hubs, brakes, etc. I figured if I was going to replace ball joints anyway (preventive maint.), I may as well just swap the ends. The D60 I have doesn't have brakes, and the rotors don't look as nice as mine.
2001 VW Jetta TDI
nm50 is offline
Old 11-16-2009, 05:58 PM   #6 (permalink)
gnxtc2's Avatar
The D50 and D60 knuckles do NOT interchange. The spindles are the same to an extent. You can re-use your brake hardware from your D50 if the D60 is from '95-'97 other wise you need differrent rotors, calipers and hoses.
You can get all your rebuilding components from Extreme Axle Sales
Do some reading Pirate4x4.Com - Extreme Four Wheel Drive
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, 3"-4" DP, Bilstein 5125s, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, CA fuel regulator, 4" Exhaust-Straight piped,FORD AIC, welded EBPV, B&M Transpan, Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, Hydroboost conversion, replacement 38 gal rear tank, Swamp's Baby Hybrids, CJC Traction blocks, 209K <---STOLEN
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 11-17-2009, 10:48 AM   #7 (permalink)
nm50's Avatar
Not the same!?! Bummer... Well, I guess it doens't matter much if I am going to do bearings and ball joints anyway. Thanks for the links and info.
2001 VW Jetta TDI
nm50 is offline
