Old 08-06-2005, 11:33 PM   #1 (permalink)
banks system on 95
I installed a banks powerpack on my brother in laws 95. it also came with a transloader which i installed. the problem i am having is that in driving down the interstate, it always seems like it needs to shift into high gear. I am not that familiar with driving his truck, but it turns about 2800 at 80. It has standard siae tires and i think a 3.73. Whatever ger came stack. I clicked the overdrive button and it is functioning properly. Anyone seen a problem like this???
troyclemens is offline
Old 08-07-2005, 04:36 AM   #2 (permalink)
Re: banks system on 95
The only rear end option was 4.10. As far as 2800 RPMs at 80 that isn't quit normal. I hit 80 at about 2400 RPMs in my truck.
97 Powerstroke, Auto Trans, 4X4, Crewcab, Longbed, K&N FIPK2, Superchips, Aftermarket Downpipe, Hypermax Intercooler, 2 Plate Tourqe converter, Transgo Shift kit, and Auto meters Boost, Trans Temp, And EGT.
Knighton is offline
Old 08-07-2005, 10:00 AM   #3 (permalink)
any ideas why the tranny would not be shifting now?
Old 08-07-2005, 10:17 AM   #4 (permalink)
When you said Transloader did you mean Transcommand? My Transcommand came with a bypass plug, If you have one of those, I'd plug it in and see if your trans module is bad.
Dan
'97 F350 4x4 CC PSD. 4:10, 4" Lift w/315 BFG MT's, E4OD-Sonnax-Tricumulator-Transcommand, Mobil 1 ATF, Banks Powerpack, Shimmed reg, Hayden 679 trans cooler, 3 gauge A-pillar, Tymar intake and no Kitty.
dtenorio is offline
Old 08-07-2005, 02:23 PM   #5 (permalink)
Yes, i meant the command, i will try the plug. I know my 05 with banks has much more power, but his 95 is just sick.
Old 08-07-2005, 06:07 PM   #6 (permalink)
Depending on tire size, 2800 at 80 sounds resonable for a 4.10 rear end. The truck in my signature turns just about 2500 at 70 with 33's and 2250 or so at 70 with 35's.
Bernhardt
Goliath - 94 F350 444DIT CC SRW 4X4 4.10 Luk SMF Coolant Filter 33X12.5R16.5 Reunel Rear Bumper LineX liner Hunter Green 254K
82 VW Pickup 1.6l TD 5sp Gold Metallic 350K
Bernhardt is offline
Old 08-07-2005, 06:26 PM   #7 (permalink)
brahamfireman's Avatar
3:55's were also an option. door code 39 for an open or C9 for limited slip.
sounds like normal RPM for 4:10's. 4:10's are not ment to go 100 mph, you need 3:55's for that. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 08-07-2005, 07:33 PM   #8 (permalink)
I agree with that. The top end on the 3.55's was much better than the 4.10's, but I like the take off a whole lot better as well as overall throttle response. Besides 100MPH tickets are very espensive...I have some experience with the 88 in 55 zone for racing a KR SD. Oh well it was worth the look on his face!!!
Art
2005 Dodge Durango Limited w/HEMI.
2006 Chevrolet Cobalt LT.
agsF2501 is offline
Old 08-08-2005, 08:57 PM   #9 (permalink)
I was also wondering if anyone had this system, and how loud it was. His is extremely loud, I have checked over and over for an exhaust leak and cannot find one, but it is way louder than before
Old 08-09-2005, 06:31 PM   #10 (permalink)
louder inside or outside??? I can just hear a slight rumble from both mine in the cab and they bark pretty good outside.
Diesel Rod
Old 08-09-2005, 11:28 PM   #11 (permalink)
I really notice it inside the cab, it is really pretty loud
Old 08-10-2005, 05:06 PM   #12 (permalink)
My Photos: (28)
When I still had the banks exhaust it was much quieter than what I have now. Your noise may be from the up-pipes, as the turbo would have been off to change out the exhaust housing - check the doughnut gaskets for soot. Another place to check is the downpipe to transmission clearance. If a muffler clamp was used to secure the two halves, (vs. a band clamp) the muffler clamp may very well be contacting the transmission while under load - it's a drone that will drive you crazy.
'97 F350 CC, XLT, 4WD off road, 4.10, Milemarker manual hubs, Suncoast E40D w/ Bob Riley's (Dieselsite) remote filter & Triple Lock Torque Converter, Hypermax H2, BABY SWAMP'S! Swamp's 20* HPOP, Head Studs, TS 4 position chip w/ Bill's programming, Banks Intercooler. Ceramic coated up-pipes and down pipe. Triple pillar w/ Isspro boost, trans temp and digital EGT gauges. 4" Exhaust. 45gal Transfer flow rear tank. Dale Isley's HX mod. Joe Servo's IDM mod. Bob Riley's coolant filter, Coolant "T", Evans Coolant, A/C mod. Velvet-Ride's, Monroe Gas Magnum Shocks. TSM's rear disc brake kit. Frozen/ Slotted front rotors with Hawk Pads. Centramatic Wheel Balancers & 285/75/16 Michelin LTX/MS. Interior sound deadening (what a difference!).
BLDITRT1 is offline
Old 08-10-2005, 10:12 PM   #13 (permalink)
thanks, i will check that.....i do not recall any donought gaskets though.. I had a v clamp on the turbo outlet, and then the downpipe went down and attached to the cat section. Where is the donuts you are talking about????? One thing i do know is that the clearance on the downpipe between the tunnel/firewall was extremely tight. You think this would be a drone?????
Old 08-10-2005, 11:52 PM   #14 (permalink)
If that downpipe ever touches anything other than air you will transfer vibration(noise) right into your cab. Get a porta-power and make yourself some clearance, you wont be sorry.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 08-11-2005, 10:46 AM   #15 (permalink)
definitely the down pipe resonation. it can not be touching the body. even properly installed, these early trucks do resonate loudly inside from the hi-perf round downpipes a lot more than the newer trucks with room for these.
I put in floor, door and firewall sound insulation. it helps some, but 4.10's at interstate speeds are musclecar loud.
SOLD--97 F-250 HD PSD XL reg cab 4x4, 84k miles. E40d 5R110 torque converter-John Wood trans, 4.10 gears (Detroit Locker!). Banks power pack, Stock AB splitshots, TS 2-pos chip, Pedal-switched 10k mod., aFe intake, Ugly Saddle Brown metallic paint. 290 rwhp. No leaks.
mike100 is offline
