Old 06-30-2005, 01:16 AM   #1 (permalink)
gmpt444epsd's Avatar
Banks turbo downpipe upgrade
Anybody run this "turbine outlet pipe" and if so how do you like it, does it increase whine, significant HP or torque increase, etc?
http://www.bankspower.com/System.cfm...amp;sysid=SF08
thanks
geoff
1995 F250 XLT 4x4 7.3L Power Stroke, 3.55LS,E40D,252K+ miles on stock engine, BANKS 3 inch downpipe, winter and summer grille cover, WARN premium hubs,40 channel CB, 2 add-a-leaves in back, NEW 33x12.50x16.50 BFG All Terrains, Pioneer DEH-2700 CD player, Hella Dual Beam Fog/Driving Lights, DeeZee bed rails, Isspro Pyrometer and Boost guages, TSC toolbox with cargo rack on top, Front Tow Hooks
gmpt444epsd is offline
Old 06-30-2005, 02:34 AM   #2 (permalink)
SlopeTruck's Avatar
My Photos: (29)
Re: Banks turbo downpipe upgrade
I have a 3" downpipe (not a Banks...) and coupled with an aftermarket intake it is louder but only when your foots in it. Have to make sure you can bend enough of the firewall out of the way. I tried using just a big bar and some 2X's but wasn't enough, ended up using a power ??? used in body repair. (Brain fart...) If it touches the body you will get lots of noise. I went the cheap route of simply cutting my airbox open for awhile but ended up getting an aftermarket intake. Should have done it alot sooner! I did both at the same time so not sure how much noise comes from just the downpipe but mainly I can hear the turbo spooling up through the intake (which is a great sound!) Going the cheap route I would get an intake, downpipe and ditch the muffler (& cat if you can.) Those mods cost me about $300 which included 10' of 3.5" exhaust pipe. So far I've improved my milage, gotten ALOT more power off the line and even loaded fairly heavy can pass on long inclines without problem. Very noticeable power increase.
[color:"blue"]WEBSHOTS[/color]
'00 F350 CC 4X4 longbed, wht, Lariet pkg. She's pretty! Open element intake, 4" exhaust, A-pillar pod w/ Isspro gauges, TW 4 pos. chip, leveling kit, 315-70-17 BFG AT's on black alloy rims, and...
SOLD '95 F350 CC 4X4 (ex-slope truck) flatbed. Open element intake, 3-4" dp, 4" straight pipe through bumper, shimmed FPR, IDM mod, TW 4 pos. chip, DIY RSK/shackle flip, 315-70-17 BFG AT's, H2 rims, 4.10's, rebuilt E40D, 3 guage a-piller pod w/ Isspro guages, DIY rear disks, SD front bumper, Warn 8000# winch, Explorer power buckets, Dodge center console/seat...
Play/plow truck '81 F250 on 40X17's. Bored 351W, S/C bobbed 3', 4 wheel discs, solid axles, Detroit, 2 winches, lots of DIY stuff.
Commute Vehicle: '07 American Lifan LF200GY, 1 cylinder, 16 hp, street legal enduro bike of Chinese origin. Top speed= maybe 70 mph but gets 80 mpg
SlopeTruck is offline
Old 06-30-2005, 05:24 AM   #3 (permalink)
The only real way to add horsepower and torque significantly is to add fuel. However a DP is a pre-requisite to any mod on our trucks and will definately be a benifit to your motor. You may notice a little seat of the pants, but more so, egt's will be lower. There are less expensive DP's if you look around the site sponsors, this one has a cat delete also
http://www.itpdiesel.com/Products73L.shtm
If you really want some whine, replace your muffler with a section of straight pipe. Then put in a high flow Tymar type filter. Now you are ready for a chip.
I run a 5" straight pipe. I have turbo whistle right off throttle increasing right on up the rpm's and a very big rig sounding suck back sound when shifting.
96 F-350 4x4 CC LB, International block and heads from Mcandless IH in Denver, <span style="color: red">Baby Swamps </span>, Luk Cerametallic Clutch, 5" straight exhaust,5 speed ZF, 4.10's, Evolution programmer, Banks brake, non-EBPV IH turbopedestal, AFE Magnum force, CA reg. kit, 12,000 lb. Milemarker on reciever mount, 215amp ambulance alt., 33" muds on factory aluminum, Class 5 bumper hitch, hidden gooseneck, pillar gauges, fosgate amp, 12" sub.
Colorado National Gaurd.
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independece. When Firearms go, all go's. We need them every hour!"
President GEORGE WASHINGTON
bigbore is offline
Old 06-30-2005, 09:55 AM   #4 (permalink)
gmpt444epsd,
The guys are correct, a down pipe is a MUST before you add any HP mods. We have a 3 incher that is one of theeasiest to install out there, it's available with or without the 2 bolt flange to connect up to the stock converter, we also have a cat test pipe for off road and racing use. Finally you can get an entire MBRP aluminized or 409 stainless systesm from us that has the 3 inch down pipe in it and then it is a 4 inch system from there back. Get that and a good programmer or chip and you'll get a ton more for you money HP wise. Call us if you have any questions etc.
Mark @ DPPI
DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM GUARANTEED PRICES DISTRIBUTOR of MBRP & AFE EXHAUST, EDGE PRODUCTS, SMARTY, AUTO METER, ISSPRO, & DiPRICOL GAUGES, SUPERCHIPS, PREDATOR by DIABLO, AFE FILTERS & INTAKES, PML TRANNY PANS & DIFF COVERS, ARP, FLUIDAMPR, POWERSLOT & HAWK, TS PERFORMANCE, BULLY DOG, AIR DOG FUEL SYSTEMS, BOSCH, SUNCOAST, STANADYNE AND MORE.
Mark Craig is offline
Old 06-30-2005, 01:54 PM   #5 (permalink)
iu was going to go with banks because they have a 2 piece design and claim to not require any firewall modifacations and it also has a bung for a pyrometer which i want to get in the future.
thanks for your input guys
geoff
Old 06-30-2005, 02:06 PM   #6 (permalink)
BIGRED95's Avatar
My Bully Dog downpipe was a two piece design, I think every 3" downpipe made is going to require some firewall modification. Also the best place to mount your pyro is pre-turbo in your drivers side exhaust manifold for the most accurate temps. Hope this helps.
Justin
98 12V QC, 282,000 +, 5 Speed, with a few power enhancements
SOLD
2000 F-350 XLT CC SRW CC PSD, 249,000+Miles, 6 Speed trans with Luk Con-O-FE clutch, 4" ATS Straight piped, Tymar style intake, Ready to start modding.
Meridian Motorsports Dyno Jet 5/13/2006
219 HP 457 TQ
SOLD:
Lifted 95 F-350 XLT Crew Cab Srw Lwb Psd, 268,000 + miles, 35*12.50*16.5 Trail Cutter Radial RT,4.10's, BABY SWAMPS, Humped HPOP, Homeade Tymar setup with custom 4" intake, Gutted EBPV, Modified turbo pedistal, 1.0 turbine housing, CTI AIC, Auto Meter Lunar gauges, BDP 5 position chip, Complete Alpine sound system, Automatic, Billet torque converter, Tru Cool 28,000 lb external trans cooler, Bully Dog down pipe, 5" twin turnout stacks, 6.0 intercooler with custom built pipes, Optima red top batteries, Wanting more mods!!!
My webshots homepage
Bully Dog Dog Days Of Summer Dyno Pull 7/9/2005
347 hp 660 torque
BIGRED95 is offline
Old 06-30-2005, 02:39 PM   #7 (permalink)
yes you do not want to get the downpipe from banks i mean its a high quality piece but have you got the price for it the gitkit is a little less then $700 and the downpipe itself is $298 and you really do want to put the pyro in the manifold not the downpipe
www.upstatebombers.com
the fords gone i got a cummins
DBogo is offline
Old 06-30-2005, 02:49 PM   #8 (permalink)
Here it comes again...
Tymar Tymar Tymar [img]/ubbthreads/images/graemlins/smokin.gif[/img]
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 06-30-2005, 03:20 PM   #9 (permalink)
That's funny, because the instructions for thier kit very clearly state that you have to cut the body seam in a couple places and fold it over, maybe they dont consider that firewall. However, if you dont push the firewall back, it will vibrate against it, either under torque, or all the time.
bigbore is offline
Old 06-30-2005, 03:40 PM   #10 (permalink)
FWIW I only had to cut/bend the seam. I think most did for a 3" dp.
- Ryan
285HP
ryanPSD is offline
Old 06-30-2005, 04:25 PM   #11 (permalink)
whats a good place to get a downpipe for a good price besides tymar? BTW whats Dale's number there?
thanks
geoff
Old 06-30-2005, 04:45 PM   #12 (permalink)
My Photos: (11)
Geoff,
Dale's # is 509-922-8785. You can double check the number on his website . I know he doesn't have online ordering but the education you'll get from him on the phone is worth every long distance nickel you spend.
Fred
<font color="009966">`97 F250HD, XLT, CC, SB, 4X4, E4OD, 3.55's, Calypso Green/White, 141K, TDE0, Built 4/97.</font>
Mods: 3/8" trans lines, 1.00 A/R Turbine Housing, Stancor GPR, FTVB, Bill's Chip[img]/ubbthreads/images/graemlins/smokin.gif[/img], JoeServo IDM[img]/ubbthreads/images/graemlins/biggrin.gif[/img], Filler necks vented, Gutted EBPV, Hypermax DP, 4" Tymar Exhaust, GTS I/C, Add-A-Leafs F&R, Un-shimmed, Pyro-Boost-Trans Gauges, Tymar Intake & HPX Hose, TRU-COOL 4590 28,000 GVWR.
`04 Nash 285D 5er, Prodigy brake controller.
`70 VW Bug: 1776cc, Berg CW crank, Berg 42DCNF's, Engle 110 cam, HD valve springs, etc... Almost as much fun as a PSD!
Blue_Mtn_Boy is offline
Old 06-30-2005, 05:00 PM   #13 (permalink)
I got my stuff through Bean.
- Ryan
285HP
ryanPSD is offline
Old 06-30-2005, 09:52 PM   #14 (permalink)
sweet thanks again guys
im pulling my engine next week due to oil leaks and figured i might as well junk the old pancake pipe and put a new one in. my dad wants to make certain upgrades for my birthday that require a little better breathing
geoff
Old 07-01-2005, 08:53 AM   #15 (permalink)
Mine's not obs, but I'm running the banks power elbow and dp and have been for about 4 years. The power elbow does away with the ebpv and makes a nice sweeping turn instead of the sharp exit of the stock pipe. It also holds 3.5" all the way out. It comes tapped for a post pyro, and I think it is a VERY well made piece. Don't know if it's offered for the obs trucks, but I know the dp and elbow I got from Banks for my truck are some really nice pieces. I wouldn't worry about quality from Banks. Just have to decide if the price is right.
CharlieII is offline
» Site Navigation
» Home
 > FAQ
