Battery size - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 12-14-2009, 09:50 AM   #1 (permalink)
dirtyharry's Avatar
Battery size
Can anyone tell me what is the largest battery series (size) that will fit in a 94 7.3 battery tray without extensive mods? I don't mind using a different tie down but dont want to start hacking anything.
Thanks,
Rob
08 6.4 F350 SC LB DRW
dirtyharry is offline
Old 12-14-2009, 12:34 PM   #2 (permalink)
Nit
it fits 65 series, there really isn't any more room for anything larger, the other thing you can do is add a 3rd battery along the frame rail under the bed. Ford use frame rail mounts on van-bodied cube vans, I have seen those mounted along the frame, looks great too.
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now pictures
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
Old 12-14-2009, 09:54 PM   #3 (permalink)
dirtyharry's Avatar
Batt
Thanks, I will just go with that then. I have to replace them and didn't know if there was a larger one that would fit. Thanks again
Rob
Old 12-15-2009, 08:21 AM   #4 (permalink)
midwestconnection's Avatar
There should be a lot of choices in the 65 series as to the cold cranking amps. Some almost twice as much in price as well as twice the amps, hot or cold.
Bumper to bumper, Full Synthetic!!! Rotella T 5-40(7.3L) -- Mobil 1 Mercon V(E40D) -- Amsoil Extreme 75-90(Danas 60) -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 XLT Club Wagon 15 Passenger Van. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
midwestconnection is offline
Old 12-19-2009, 06:22 AM   #5 (permalink)
u2slow's Avatar
My Photos: (21)
65s are about all you can do. Its a Ford size. 27s and 31s are too long. 31s are also too tall. My buddy wore a hole in his battery because the tray doesn't fit a 31 properly.
I'm going to go with group 31 when I replace... move them behind my rear seat.
97 E350 SRW minibus, E4OD/D70/4.10, 19.5 whls, BD trans pan, 3 batteries & inverter, tach dash
93 W250 6BTA/5spd/D60/D70/3.55
90 D250 6BT/5spd/D70/3.55
Other rigs I wrench on:
95 F350 CC 4x4 ZF 4.10 Lockright/Detroit, T444E J/W pump, hydroboost, EBPV brake, straight pipe, 5.6k mod, 4" lift, 35" Toyos
Ford 6.9/7.3/IDI/turbo/PSD, 89-02 Dodge CTD
Marine Engines I mess with:
Mitsubishi S6U, S6R, 6D14; Mirrlees National KVSSM; DDC/MTU 12V2000; Cat 353, 398, 3306, 3406
u2slow is offline
Old 12-19-2009, 08:54 PM   #6 (permalink)
dirtyharry's Avatar
u2slow
Hey, looking at your picture if I didn't know better I'd say you were driving my truck. Blue crew cab with white roof, bush bumper and headache rack. Thats funny. Especially since mine is in storage in Duncan while I'm away. They must be twins fell out of the same ugly tree!
Rob
Old 12-19-2009, 09:25 PM   #7 (permalink)
I have 31s in my truck. I did have to do some mods but it was nothing too difficult. I just installed my second set a month or so ago. My first set lasted me 5 years to the month. There is adjustment in the battery trays that you can move them down further and then they aren't as wide so I stuffed a piece of plywood behind them to hold them in tight and wrapped a bungie strap around each of them.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 12-20-2009, 01:04 PM   #8 (permalink)
i just put in fleet farm 1k cca's today wasnt to bad had to beat on the tray a lil bit to get it to fit them since they are about 1/2inch to long and a bit narrower than the tray but just had to bend the one side of the tray in a little bit to get it fit sung
the part number for the batteries is P31925A $85/ea
my photos
95 f-250 444e e4od 4X4 ex cab long bed 3.55ls White Knight Reverse Lights, AIC, FORD seatcovers, AFE STAGE2 INTAKE, 3" downpipe 4" exhuast, EDGE Evolution 100hp setting, auto meter ultra lite pyro, tranny and boost gauges, .177bb in FPR, amsoil atf in transmission & tcase, amsoil syn gear lube in rear diff, bilstien shocks, fog lights, 1000cca batteries
************future mods*******************
intercooler, smaller turbo housing, window tinting
03 vw jetta tdi stock for now
traxmedic is offline
