Best Cummins Conversion Kit - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 08-02-2007, 11:35 PM Thread Starter
I've been reading a bunch of threads about the cummins conversion. I was wondering for all those who have done it who has the best kit? I found a 12v cummins still in an 89 Dodge pickup. Will this motor work? Should I rebuild my e4od or go with something else?
1995 F-350 CC 4X4, Auto, 3.55's, DP, Straight Pipe,<a href="
target="_blank">[color:"blue"]Wildman 4 Position Chip[/color]</a> Gutted EBPV, Modded Turbo Pedestal, Autometer A-Pillar gauges,
, Shimmed FPR,
, 466 Blue CPS
<img src="/ubbthreads/images/graemlins/smokin.gif" alt="" />
Gtndrty is offline
post #2 of 14 (permalink) Old 08-03-2007, 06:00 AM
Re: Best Cummins Conversion Kit
well the whole point of that swap would be for more power, and the E40d won't take a whole lot, so yeah. And it will work, but I think (not sure) most guys are using ones from newer engines. I'm not sure though. (like a 94)
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 150k mi. Dana 60, SD v code springs, RSK
psu927 is offline
post #3 of 14 (permalink) Old 08-03-2007, 07:02 AM
An '89 is gonna have a getrag or a 727 tourqueflite... so your E4OD will be better than whatever is in the Dodge.
An '89 is the simplest one to convert. It has no intercooler and it only takes a hot wire to the pump to make it run. It's also a rotary pump motor which you can turn up with a screwdriver, but it's limits are about 450-500hp and you need a bigger head on the pump to go that far with it.
I would look for a newer truck with the P7100 inline pump and the NV4500. If you stay with an auto you will need a standalone controller for it.
'96 F-250 4x4, PSD/E4OD, exhaust, intake, Bean's squirters, tunes
'84 Ford Ranger 2wd, 2.3 Turbo Diesel/4 Speed OD, 3" stacks, pump tweaks
OldSchoolPSD is offline
post #4 of 14 (permalink) Old 08-03-2007, 11:37 AM
E4OD won't take a whole lot of power? I think you are mis-informed.
MADDOG is offline
post #5 of 14 (permalink) Old 08-03-2007, 12:06 PM
Mine was holding 600rwhp daily and 650+rwhp for 150+ passes at the track.... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Stock your right- they arent very tough but you start adding good parts and they become very tough. I had my built trans tore down and inspected @ 20k miles and everything was well within specs even with all the daily beatings, racing and towing.
Thunder_struck is offline
post #6 of 14 (permalink) Old 08-03-2007, 05:29 PM
You might have looker here already www.destroked.com and www.cummins-conversion.com
Rusty
1997 F250 CC, SB 4x4, 220,000 miles, 7.3 PSD, E4OD, 3.73 gears, Kingpin Dana 60, 10.5 rear, True-trac, Sky 3" RSK, D-code spring in front, B-codes in back, F250 blocks
rusty1161 is offline
post #7 of 14 (permalink) Old 08-03-2007, 09:42 PM
ThreeStarJR's Avatar
Give Bean a call.....He has done a conversion on his own personal truck and it is AWESOME!! He has hooked up and is a vendor for the best conversion kits out there and you have the number one psd aftermarket shop to advise you on which way to go....
...BDP.....
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
#3
ThreeStarJR is offline
post #8 of 14 (permalink) Old 08-03-2007, 10:22 PM
GSXRTURBOQUAD's Avatar
Try PMing Maddog or look him up, Maddog Motorsports in Utah. He has had a 12v in his 95 for years and is still the king. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Precision Hybrid from BWD), Industrial Injection BD Injectors, DIIC with custom stainless 3" piping, Terminator HPOS, DI headstuds, BTS tranny, TruCool 40GVW cooler, DP LIVE TUNED F5 with Extreme ICP(ya, it works)!, Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be shortened.
97 F350 Regcab4X4: Twin Turbo's, lots of fuel and oil.
02 Excursion4X4Limited: Wifes ride: Terminator HPOS2, DP Tuner F5
SDRCM #7
GSXRTURBOQUAD is offline
post #9 of 14 (permalink) Old 08-03-2007, 11:51 PM
Not sure what will be the best swap for the engine, but I would stay away from the getrag transmission that dodge had even thought the transmission is built tough. I had one in my 93 Dodge 3500 and keep burning the 5th gear bearing out. I found out that the way the trans was designed that the 5th gear pulled the oil away from the 5th gear bearing. So, there was no oil going to the bearing. I fixed the problem by fulling the transmission all the way up to the breather on top. After that I had no more problems.
White 2005 F-350 6.0 4X4 Crew Cab
Bulletproof Diesel Oil Cooler System
Bulletproof Diesel EGR Cooler
Bulletproof Diesel Alum. Radiator
4 in Turbo Back Exhaust
36 inch MT ATZ
SCT Tuner
White 1997 F-350 4X4 Regular Cab
Tymar Intake installed 08/17/07
mike77 is offline
post #10 of 14 (permalink) Old 08-04-2007, 02:22 PM
Yes a stock E40D won't take the power. That's what I meant. I should have phrased it different but I was getting to the fact that he will have to spend another 2-4 grand (?) on the tranny to get it to handle the power.
psu927 is offline
post #11 of 14 (permalink) Old 08-05-2007, 10:00 AM
Talk to Rocky he has done more than a few conversions. Rockin S Performance He can hook you up with a turn key set up, with top quality parts and service.
97 PSD f250 4x4. 06 common rail conversion in the process.
<span style="color: red">cummins conversions by Rockin S performance </span>
AlanB is offline
post #12 of 14 (permalink) Old 08-05-2007, 02:23 PM
What he said!
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
post #13 of 14 (permalink) Old 04-13-2010, 07:59 PM
Send a message via AIM to derryspring
cummins swap for 6.5 gm turbo
ive got a 94 gmc 3500 hd 4x4 and its got the 6.5 turbo diesel witch suprisingly blew up. and im gettin a 12v cummins to put in place with the 5 speed behind it would this be a hard swap or no and do they make a click and go wire harnes for it or do i have to do it myself ? tom
derryspring is offline
post #14 of 14 (permalink) Old 04-14-2010, 11:38 AM
i would suggest taking a look at fordcummins.com
97 F250HD 7.3 Powerstroke 5-speed 4wd ext cab long bed superchips max tuner 4" straight pipe, flowmaster 3" downpipe, tymar performance intake, firestone destination a/t
Alan
7.3 Bandit is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
