bigger better brakes - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 03-16-2010, 11:37 AM   #1 (permalink)
Have a 1997 f350 4x4 crew cab ,diesel of course. pull a large horse trailer an want more stopping power on the truck side. is there a big brake kit for the front available? an what about a conversion for the rear to disc or a complete swap out for rear ? it's also a single rear no dually. pull a 17,000 lbs of trailer so don't want anything that would be iffy! what's your opions?
Mine : 1999 F-250SD supercab 4x4 7.3L ,airaid intake,5 in. exhaust, BTS Tranny , BTS 6 POS. chip,150,000 miles.
HERS :1997 F350 S.D. 4x4 crew cab 7.3, BTS tranny an 4 pos.chip, Rickson 19.5 wheels,DIY tymar,4 in exhaust. 157,000.
ch58dr is offline
Old 03-16-2010, 11:47 AM   #2 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
I don't think you'll find a big brake kit for the front. There may be a kit to convert the rear to disc's. Have you considered an exhaust brake? A lot of guys also convert their EBPV to a poor man's exhaust brake, which essentially operates the valve from a toggle switch in the cab. That would be way I'd do it and it's cheap.
05 F-350 Crewcab 4x4, 6.0, Auto, Dually, My new Tow Rig
95 F-350 Crewcab 4x4, 7.3, Auto, Awesome Tow Rig...Sold on May 17/09 (went to a good home)
80 F-250 4X4, 429, 4 Speed, Lifted, Solid Axles, Boggers, 450,000km and going strong...Gonna Go
90 Bronco, Work in Progress
fordsforever73 is offline
Old 03-16-2010, 11:52 AM   #3 (permalink)
realbadlarry's Avatar
Best bang for the buck is Hydroboost conversion, then slotted rotors and hawk pads, then the rear disc kit. If it wont stop with that, then you need a bigger truck. Actually, electric trailer brakes and a Prodigy controller will make a HUGE difference. Make sure the trailer brakes are up to snuff. I finally fixed mine and it works 100% better.
95 CCLB 4X4, DP, TYMAR, Adeneline HPOP, 5POS CHIP, 4",3 GUAGE POD, 129k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.Banks IC
realbadlarry is offline
Old 03-16-2010, 05:17 PM   #4 (permalink)
Yep already have the Prodigy controller, it does ok now just down shift to 2nd on the bigger hills. just thought if there was something out there easy an reasonable I would consider it.. Thinking about the exhaust brake thing though that be easy enough. thanks
ch58dr is offline
Old 03-17-2010, 08:52 PM   #5 (permalink)
My '97 Superduty (450 I'd say) has the hydraboost and four wheel disk brakes from the factory. You may be able to sway the fronts but the backs would probablly require the axle be changed. Too bad you don't have a dually as the swap wouldn't be that bad. Would be worth a call to your dealer to see what if any parts would swap.
I can honestly say that this truck has the best brakes of any Ford truck I've ever owned.
SCORPIO26 is offline
Old 03-18-2010, 12:28 AM   #6 (permalink)
u2slow's Avatar
My Photos: (21)
I'm planning for the hydroboost swap myself. The popular opinion is it makes at least as much difference (if not more) than rear disc.
I'm not a big fan of the aftermarket kits that use the Eldorado calipers. I'd rather have a drum-in-hat style parking brake. I'm probably going to adapt something OEM at a later date.
97 E350 SRW minibus, E4OD/D70/4.10, BD trans pan, tach dash
93 W250 6BTA/5spd/D60/D70/3.55
90 D250 6BT/5spd/D70/3.55
Marine Engines I mess with:
Mitsubishi S6U, S6R, 6D14; Mirrlees National KVSSM; DDC/MTU 12V2000; Cat 353, 398, 3306, 3406
u2slow is online now
Old 03-18-2010, 08:49 PM   #7 (permalink)
Feedback Score: 3 reviews
You need a Dually..and BD brake
Cary
caryt is offline
Old 03-18-2010, 09:01 PM   #8 (permalink)
some have gotten a 97-00?? van axle--with the old 8 bolt pattern, and adapted that to get rear discs. believe it has emer in rotor--they just use all the outboard pieces--and since its ford--it all goes together, except for making the plate to get caliper brackets to the axle--and i believe they even cut the piece off the van axle to weld to the truck axle--
94_turbo is offline
Old 03-19-2010, 06:29 PM   #9 (permalink)
u2slow's Avatar
My Photos: (21)
Yeah, I've seen that conversion. Hard to find an affordable van/disc axle around here. I do have an '07 350SD axle, but the large diameter (17"+ wheels) and metric pattern don't make it very conversion friendly.
Old 03-19-2010, 08:19 PM   #10 (permalink)
My 97 has the emergency brake mounted in a large drum on the output shaft of the tranny. Would that make axle selection any easier?
Old 03-23-2010, 09:39 PM   #11 (permalink)
TSM rear disc brakes i have heard no complaints about really can get with ebrake or without without is cheaper
Ford - Truck
2005 KR CC SB Auto 6.0L - 4in straight to the back no muff or kitty, Upfitter High Idle mod, Blue Spring
1996 F250 Crew Cab LBox 5sp "Sold"
1967 Ford Fairlane 2Dr Post factory radio delete non ac, manual brakes, manual steering car. 80% restored working on interior Body and Paint done- 390FE stock oil eater, C6, Starshifter, Micky T Indy Style 60 Series on back. Originaly Black repainted black
1972 Ford Gran Torino Fastback 351 Cobra Sold
1979 F350 Custom Crew Cab Short Box replaced Torino for project vehicle..
2004 Lincoln LS8 "Sold"
2008 Kawasaki Brute Force 750 4x4i
96strokerlb is offline
