Biggest tires on 16X10 wheels? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 09-05-2006, 09:05 PM Thread Starter
Fireman87's Avatar
Subject says it all. I have a new set of Eagle Alloy 16X10 and im wondering if 285/75 tires will fit alright? If not i can make someone a heck of a deal on them. -Shane
2012
F-250SD PSD Super Cab Longbed 4X4, 3.55, Firestone Air Helper Springs, Upgraded Headlight Harness, AMSOIL Fluids/By-Pass Oil Filter, owned since 8/8/2012
1997
F-250HD Reg. Cab 4X4 PSD "The Stroker", ZF5, 4.10, LUK Clutch Conversion,
Custom Open Air Intake, 3" to 4" DP, 4" Straight Exhaust, Gutted EBPV,
Bully Dog Boost/Pyro, HPO Crossover Line, Amsoil Bypass Filter, All Amsoil Fluids, Cali. FPR, High Voltage IDM, Upgraded Headlight Harness, Scosche Remote Starter,
in the front, One Ton springs in the rear, Owned Since 08/20/2004
Fireman87 is offline
post #2 of 11 (permalink) Old 09-05-2006, 09:33 PM
Re: Biggest tires on 16X10 wheels?
you can run that size easy...alot of guys are runnung 315's on the stock rim which I think is 16x7..I'm currently running 315's on 16x9's hope this helps..ahhhyour thinking that the tire could be to small....should be ok.....
agomez is offline
post #3 of 11 (permalink) Old 09-05-2006, 09:43 PM
I think it will push the sidewall of the tire out too far.
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
2002 Excursion PSD 4x4 XLT Premium- BB Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner
mattymx is offline
post #4 of 11 (permalink) Old 09-05-2006, 09:56 PM Thread Starter
Fireman87's Avatar
matt,
I think you have right idea, thats why im leary on mounting them. The tires are less than a month old and i made a stupid mistake when i ordered the wheels. Thanks for your input though.
-Shane
2012
1997
post #5 of 11 (permalink) Old 09-05-2006, 10:00 PM
sorry guys, i disagree! i actually ran a set of 351/75-16 buckshots on Pacer 16x10 alloys and i couldnt have been happier! they filled out perfectly and really made the truck sit just like i wanted!
in my experienced opinion 16x10 is the perfect size... if you go narrower you are taking chances of wearing the inner tread of your tires b/c the wheel pulls the tire closer together making the tread more round than flat!
off my soapbox, lol. if i can find a pic i'll post up.
EDIT... here is a pic of my PSD! http://www.ford-trucks.com/user_gall...71&width=0
-cutts-
96 F350 PSD 4x4 CC/LB 5spd XLT Ranch Hands F/R, 6637 mod, 4.5" straight pipe, tymar 3-4" DP, Dominator 66 turbo, Banks IC system, DIY Stage-I's, TW 4-pos chip, 37" SuperSwampers, autometer gauges,RAM laptop mount w/AI OBD diagnostics, fold down g/n hitch, OBA system with York and dual trumpet air horns, bronco 33gal fuel tank
72 bronco 302/435/twinsticked D20/D60/10.25 welded F/R, hydro assist, 39.5" stretched WB to 105", 1410 yokes/shafts, Staz custom double beadlocks, CroMo shafts front shafts with 35 spline outers and sexy lady drive slugs, GLO diamond tread diff covers, custom cage, mesh floor, custom diamond aluminum dash overlay, wristed radius arm, homemade shackle ladder bar
Fishmanndotcom is offline
post #6 of 11 (permalink) Old 09-05-2006, 10:08 PM Thread Starter
Fireman87's Avatar
Fishmann,
I understand what you are saying but you are running 315's and i have 285's. Thats a pretty decent size difference. I was told by a tire retailer that the 16X10's might be to wide for the 285's. Ive also had friends (with no tire experince, lol) tell me they will fit. Has anyone ever ran that combo?
-Shane
2012
1997
post #7 of 11 (permalink) Old 09-05-2006, 10:26 PM
you're right, i somehow overlooked the fact you wanted to run 285's. i still stand on the grounds, i think they will fit fine but i dont have any first hand knowledge. just dont know how they will look!
you're best bet is to go to some mom & pop tire shop and see if they have a 10" wheel they could put a 285/85 tire. its a long shot but thats definitely what i would do! in fact before i bought my buckshots i made the shop put one of them on a wheel and put the combo on my truck before i bought! i was not gonna spend $1000 in wheels and tires and not be happy!
happy huntin!
-cutts-
post #8 of 11 (permalink) Old 09-05-2006, 10:47 PM
desertwheeler's Avatar
They will fit as thats what my friend has on his duramax and they look ok, i think my 16x10's are too wide for my MTR's but they work fine.
08 F250 CC SB 4x4 New baby.
03 F250 SC LB 4x4 sold
In SO-CAL?
Check out Southern California Powerstrokes.(SOCAPS).
desertwheeler is offline
post #9 of 11 (permalink) Old 09-05-2006, 11:07 PM
Big K's Avatar
Matt,
I disagree also, had many of set of 315's on the 16x7 wheels.
Here is a few pics of them.
Judge for yourself [img]/ubbthreads/images/graemlins/wink.gif[/img]
http://www.northtexaspowerstrokes.co...e.php?pos=-248
http://www.northtexaspowerstrokes.co...e.php?pos=-247
http://www.northtexaspowerstrokes.co...e.php?pos=-246
http://www.northtexaspowerstrokes.co...e.php?pos=-245
http://www.northtexaspowerstrokes.co...e.php?pos=-244
http://www.northtexaspowerstrokes.co...e.php?pos=-243
http://www.northtexaspowerstrokes.co...e.php?pos=-242
[img]/ubbthreads/images/graemlins/smile.gif[/img]
Kevin "BigK" Neal
972-768-7252
Big K is offline
post #10 of 11 (permalink) Old 09-05-2006, 11:14 PM
I think that the 16x10 expose too much of the weaker sidewall to the elements on my MTRs and i think the 285's would be alot worse.
In SO-CAL?
post #11 of 11 (permalink) Old 09-08-2006, 09:47 PM
Soaggydogg's Avatar
My Photos: (11)
Feedback Score: 2 reviews
I agree, I would not run 285's on 16x10 wheels. It will look like a mexican hoop-T with 8 inch wide tires on 12 inch wide wheels. If I can find a picture I'll post it.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
