blow off valve?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 06-25-2007, 09:55 PM   #1 (permalink)
blow off valve??
Has any one tried one? Will they help perfomance? Sound?
I have seen the model BD makes, but $650 is a bit much. A "normal" blow off valve, made by Turbonetics runs from $200-$300. I assume there would need to be some adaptation, but I can not understand double the cost.
Maybe its juvenile, but I would really like to hear the psssssh after every shift.
Is it possible to adapt one? Is it worth it.
1995 F350 PSD 4X4, stick, Crew Cab, Long Bed
Mods:
Mile Marker manual hubs, tymar intake, cat delete, 3" down pipe
Truegrit is offline
Old 06-25-2007, 10:39 PM   #2 (permalink)
kfjensen's Avatar
Re: blow off valve??
Just wire a switch into your stock EBPV valve and use it as an exhaust brake, its $20 and you get a loud hiss whenever you want, blow off valves are for ricers [img]/ubbthreads/images/graemlins/cool.gif[/img]
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
, All Cleared Out
kfjensen is offline
Old 06-25-2007, 10:57 PM   #3 (permalink)
we have no air metering device so it is pointless
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
http://community.webshots.com/user/machdriver69
jasonlambert is offline
Old 06-25-2007, 11:37 PM   #4 (permalink)
STurbo90's Avatar
My Photos: (9)
a blow off valve is not a performance device. It's main intention is to prevent compressor surge.
On a engine with a throttle body when you are at full boost and let off the throttle the TB closes and all the compressed air is dead stopped forcing it to backup into the turbo. That is hard on the life of the turbo.
It also helps by diverting the air from the intake. If you are at full boost and let off the pedal, all that air is still being forced down the engines intake causing the engine not to slow down(vehicle still accelerating after you let off the pedal).
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 06-26-2007, 02:14 AM   #5 (permalink)
BOV's are not for ricers see car in my siggy that aint no ricer! I would hate like heck to A)fold 75mm throttle blade over. or
B)trash my T-netics turbo there are times when (on a street car) you must chop the throttle.
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
Aljay is offline
Old 06-26-2007, 04:27 AM   #6 (permalink)
BOVs are for the most part for gassers. They do have a place in a diesel engine that is makeing huge boost like one with twins. They prevent stall not surge. The BOV that BD makes is expensive because of the electronics that come with it. A typical BOV blows off once a certin pressure is reached against it. However on a diesel there is never really a spike in pressure. However when you lift the throttle on a hard accell if you are makeing tons of boost all that air will try to back back out of the turbo makeing it stop or reverse direction instantly. So there are electronics attached to the throttle pedal that activate it when you lift. You can adjust it by how fast you lift off the throttle and how sensitive it is. But it will not give you the sound you are looking for. If you want that sound go buy that ricer mentioned above.
speediesel is offline
Old 06-26-2007, 09:20 AM   #7 (permalink)
Smart guy ehh ! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Aljay is offline
Old 06-26-2007, 09:33 AM   #8 (permalink)
Nit
speed deisel is very correct, to be of any use you much have electronics to open teh valve at a closed throttle, teh boost doesn't surge over any given psi ,just eh amoutn of air backing up teh turbo stalls the compressor. Yes you do need lots of boost and wild ( or Wildman ) programming. I have both and yes I do get compressor stall if I let off too fast from 35psi or durign shifts ( w/ an auto even) but only in teh daily or race settings. Sounds great but I bet teh shaft will go soon. [img]/ubbthreads/images/graemlins/frown.gif[/img]
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now pictures
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
Old 06-26-2007, 01:03 PM   #9 (permalink)
pwrtrip's Avatar
This may be a stupid question but here goes. Watching truck pulls and when then come to the end of there pull and let off you here a huffing noise from the turbo is this stall? I figured it was just the air the engine didnt use coming back out.
1996 crew cab 4x4 black psd
BDP 250cc hyrbids
BDP fuel system
Stealthhinator dual ipr hpop
H2E
TDP tuning
515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke
Truck and misc pics
pwrtrip is offline
Old 06-26-2007, 06:51 PM   #10 (permalink)
Thanks for the info guys thats why I asked before I spent the $$$.
Mods:
Truegrit is offline
Old 06-27-2007, 02:09 AM   #11 (permalink)
johndeerebones's Avatar
That's were the stall comes from, if its enough air to stop or stall the compressor.
Could be, may just be the turbine spinning down quickly on the exhaust side of things. Mine does that, gut the ebpv and run a downpipe and straight pipe and yours will too. Just kinda a "bark" older cummins dodge's with open short (ie stacks or a pipe out the side) do it too.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 06-27-2007, 02:16 PM   #12 (permalink)
Yes you are correct on both counts. It is stall and it is the air comming back out. Very hard on turbo shafts.
