Old 03-07-2006, 11:19 AM   #1 (permalink)
Boost
For a basic stock truck, whats the purpose of monitoring boost? I understand having guages for EGT and transmission temps, but why boost?
96 F-250 PS 4X4 Supercab, Manual Hubs, 3:55 rear-End, Longbed, Green & Green, Rear Air Bags, Goose Neck, Jasper Tranny, Rhino Lined, DP, basically stock, 150,000 miles
joelmon is offline
Old 03-07-2006, 11:26 AM   #2 (permalink)
Re: Boost
Its just fun to look at! Plus it gives you an idea of how much performance you gain when you start doing mods and such.
Craig
2000 Ford F250 Lariat 4x4 Auto SuperCab LB PSD
2L Motorsports transmission (Precision 3 disk converter, valve body, upgraded clutches), V10 tranny cooler, TS chip, MBRP 4" exhaust, 4" to 5" tip, Auto Meter Z Series Boost, Pyro and Tranny, Poor Man's DIY intake, Boost Relief Valve, Crank Case Vent routed under truck, AIH plug
Both powered by 2L Motorsports
2L Who??
www.FOKISD.org
CraigPSD is offline
Old 03-07-2006, 12:29 PM   #3 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Re: Boost
For me it's just another indicator to tell when things are normal or not. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 03-07-2006, 01:28 PM   #4 (permalink)
PSDfreak's Avatar
Re: Boost
I agree with BOTH of the above posts...It is fun to look at and can show you if there is a problem in your exhaust/turbo system like a leak etc...
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 03-07-2006, 02:34 PM   #5 (permalink)
Re: Boost
Thanks guys. I kinda figured that was the deal. I really dont plan on doing a bunch of mods. Just put in a new dp this past weekend ( thank God for potra powers!) Fixin to order an authentic TYMAR intake and plan on Jody putting in a chip. After that the only power upgrades will be when the original stuff breaks.
joelmon is offline
Old 03-07-2006, 03:50 PM   #6 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Re: Boost
I installed my pyro and boost gauge pre mods. At one point I noticed less boost then before. After many discussions with Ford they covered a couple injectors.
Ran fine, but they were not fueling they way they should have. Never would have noticed without the gauge there.
MarkEkberg is offline
Old 03-07-2006, 04:09 PM   #7 (permalink)
My Photos: (10)
Re: Boost
cause it is fun to take a ricer guy for a ride and see his face when you are puting down 35+ lbs...
Wacker
"If your talkin' bout me.....your leavin' somebody else alone.
wackerjr is offline
Old 03-07-2006, 05:50 PM   #8 (permalink)
kfjensen's Avatar
Re: Boost
Yeah thats exactly how far ive gone, then will get guages and be done with putting more power to it, just drive it [img]/ubbthreads/images/graemlins/cool.gif[/img]
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 03-07-2006, 09:49 PM   #9 (permalink)
hheynow's Avatar
Re: Boost
He burn it for you BUT you'll put it in. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1997 F-350 PSD XLT RC 4x4 E4OD
303K miles and still running very strong
Using WVO and biodiesel since May 2006
hheynow is offline
Old 03-07-2006, 10:55 PM   #10 (permalink)
Re: Boost
Yea right.......... Been their and told the Wife that! Once the moddin starts their is no end!
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 A/R exhaust housing, vdo gauges, 279,000k
http://community.webshots.com/album/549770704UdvVUs
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, gauges, 6oh intercooler(GTS Kit), Tymar intake, HPX, .84a/r housing, 203* stat, 4pos Wildman chip!
ltfox is offline
Old 03-08-2006, 08:51 AM   #11 (permalink)
Re: Boost
We live about 15 miles from each other, so I'll go to him and do what he wants me to do.
joelmon is offline
Old 03-08-2006, 08:58 AM   #12 (permalink)
Re: Boost
Let me live in my dream world for just a little while ok? LOL
joelmon is offline
