Old 11-19-2005, 10:08 PM   #1 (permalink)
Boost Gauge Install
Can anyone please tell me the best place to "tap-in" a connection for a boost gauge [img]/ubbthreads/images/graemlins/shrug.gif[/img]
97 F350 PSD 5speed CC 4X4 210,000 miles, "Tymar" Intake, 3"-4" Downpipe, 4" exaust, Autometer pyro & boost gauges, 4 pos.chip by Dale I., Baldwin oil Bypass, HPX Mod, Exaust Brake, Fumoto Valve
You Enter And Leave This World With Only 2 Things
"YOUR NAME AND YOUR WORD"
Do Your Best To Keep Them Both Intact.
slcragun is offline
Old 11-19-2005, 10:17 PM   #2 (permalink)
Re: Boost Gauge Install
the line running from the intake "y" over to the map sensor, looking at the motor will be on the left center of motor and runs to the firewall "between" the ac stuff and motor to a sensor with an electrical plug and rubber hose attached to it, the rubber hose is where u need to tap.
97 f350 cc 4x4, srw ,tde1, 4.10 gears,head studs w/ factory gaskets' bts tranny mobil 1 synthetic diesel site full pull injectors h2 turbo, 02 hpop ,twin tymar intake ,beddins custom fuel system ,custom ladder bars,turbo life saver,dead kitty, ,dp tuner 4 position chip,hypermax innercooler,oil filler extension,,maghytec pan,4inch exaust w/ 4" stacks, aux tranny filter,dual aux tranny coolers, autometer a-pillar 3gauge,295 nitto at's,4inch lift,ranchhand bumpers front&rear
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!!
scottginfla is offline
Old 11-19-2005, 10:53 PM   #3 (permalink)
Thanks, I plan to install these gauges tommorow morning and I'm missing those instructions.
Thanks Again, scott [img]/ubbthreads/images/graemlins/smile.gif[/img]
slcragun is offline
Old 11-20-2005, 12:00 AM   #4 (permalink)
My Photos: (5)
<font color="blue">Here's one option...</font>
1995 F-350 PSD SRW LWB CREW 4X4, manual hubs, 4:10 L.S., TEE5; Hobbs; Rebuilt E40D with AutoTrans Coast Clutch Controller, Precision Stallion TC, Alto Red Eagle frictions/Kolene Steels; all steel planets, Transgo "Tugger" kit, Tru-Cool 4739 40k cooler, Magnefine in-line filter. DIY Open-Air Filter, Coolant Filter, Hood Mod, Grill Mod w/ Remote Release, HPX Mod, Diamond Eye 3" DP and 4" exhaust, 1705 SCMT, Stancor GPR, Joe Servo IDM Mod, FPR Shimmed, 10K Switched, DIY IVS-EB, Westach Gauges in dash pod, Grab Handles, Cell Phone Bracket, FlexSteel Seats, Pace-Edwards Roll-Top.
http://community.webshots.com/user/sdm13
sellwithsam is offline
Old 11-20-2005, 02:20 AM   #5 (permalink)
I would go with the option that sellwithsam shows. I tapped into the map sensor hose and I had problems with it, and I have been told that it can interfere with readings to the map sensor. Little more work, but its worth it. JMO.
1995 F350 PSD 4x4 Reg Cab LB 5 speed. Babies, 6 po chip, Southbend OFE, Autometer Ultra-Lite EGT, Boost, Oil Pressure, Poor man Tymar, 3" downpipe, cat delete, 4" exhaust with muffler, 4.10 gears, Bilsteins, crushed white with pearl clearcoat, all black interior with tan Eddie Bauer seat. SOLD 12/06
2003 F350 King Ranch 4x4 6.0l powerstroke CCSB
AFE stage 2 Pro Dry S
4" Turbo back Magnaflow
FOKISD Member
Truck Pics
95PSDF350 is offline
Old 11-20-2005, 03:59 AM   #6 (permalink)
My 97 had the map sensor/boost gauge line coming off of the passenger side intake plenum neck. I used this with no problems with and without an intercooler. I now have the msp and boost pressure lines tapped into the turbo outlet to the intercooler to check response pre-intercooler. Doesn't seem to be any difference in engine performance, map operation or boost gauge function compared to the stock plenum tap.
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline
Old 11-20-2005, 11:45 AM   #7 (permalink)
rednck21's Avatar
is that the line with the loom on it? why should it be put there?
2000 F-250, reg. cab, 4x4, XLT, 7.3, AFE stg. 2, MBRP 4", Autometer gauges
2000 Ranger, 3.0 daily driver
72 early bronco- uncut stocker!
ECBR
PICS
WEBSHOTS
rednck21 is offline
Old 11-20-2005, 09:40 PM   #8 (permalink)
My Photos: (5)
Yes. My boost gauge from Westach came with an NPT/barb fitting, so I simply tapped into the manifold (AFTER I put material inside to catch drill and tap shavings). The hose is covered with loom and routed to gauge. Seems the fastest and easiest to me...
You should put it where ever you decide it works best for you. Sometimes that is dictated by the parts you receive with gauge.
Otherwise, I usually decide these things based upon my investigation of how other guys have done it and how it worked out for them.
Sam
