C/C light, squeak, other questions! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 08-07-2005, 04:44 PM   #1 (permalink)
Banned
how can i install a little LED light that will come on steady when i engage my cruise. i dont need this, just thought it would be cool.
is there a grease sert anywhere on my steering wheel? it has a funny squeak sometimes when i turn. i think i might just squirt some WD-40 into it.
chase n.
cnesloney422 is offline
Old 08-08-2005, 02:12 AM   #2 (permalink)
Banned
Re: C/C light, squeak, other questions!
any help?
Old 08-08-2005, 04:00 AM   #3 (permalink)
you can get an LED and wire it into the cruise...you just have to find a basic LED and then look at a wiring diagram to find a wire that's hot when it is engaged. as far as the grease zerk, not that i know of. i don't think there is such a thing (unless it is on the steering shaft...be careful with WD-40, as it will drip and be all over your carpet...
Josh
1996 Ford F350 XL SuperCab shortbed 4x4, PSD, 5-speed manual, D60 swap, 6" Skyjacker (all spring) lift, 37" Super Swamper SSRs, 16x10 Ultra Stargazer wheels, South Bend Con-O-FE clutch (HIGHLY RECOMMENDED!!), SMFW, Tymar air intake, Swamps 150/146s, shimmed FPR, Northern Diesel Performance 4-position chip, 3.5" Hypermax downpipe, 4" Airflow exhaust, Dieselsite's BRV, Husky lo-profile toolbox, Reunel front "Import Mauler/Chevy repair kit-gotta do my part to clean-up America" DYNO'D 1 October-308.8 RWHP, 620.1 RWTQ!!...see her here www.cardomain.com/id/rattlinford
RattlinFord is offline
Old 08-08-2005, 11:21 AM   #4 (permalink)
I know that throwing an LED in for brakelights will mess up your cruise due to a resistance issue, so i don't know how that would work on your cruise control switches? i'd be careful about that...may have to rip out all of your wiring if it messes up
'95 XLT-302-39.5 IROK's, D60/10.25-Detroits/4.88 ~7" lift
'95 4dr Bronco C150 351, '05 60/10.5 swap with 4wheel discs. ~5" lift on 315's
'95 4Dr Bronco C350 PSD-AFE stage 2 intake, Tymar 3-4" DP, 4" exhaust, EBPV delete, FPR shim, IDM mod, and Wildman 4pos chip.
JoeBob1901 on Supermotors for pics/info
JoeBob1901 is offline
Old 08-08-2005, 11:26 AM   #5 (permalink)
Banned
wont bother with it then
thanks,
chase n.
