can you change the dash light color? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 01-11-2006, 09:29 AM Thread Starter
Is the green color of the dash lights a changeable bulb or tinted plastic on the gauges? I would like to change it if fairly easy.
Thanks!
'97 F350, Crew cab, 4x4, 120,000 miles, 4" dp straight through to tail pipe, rhino liner, backup lights, Tymar intake.
pchtxag is offline
post #2 of 14 (permalink) Old 01-11-2006, 10:05 AM
MarkEkberg's Avatar
My Photos: (13)
Re: can you change the dash light color?
The green from the film on the cluster itself. If you change the color of the bulb the needle will change, but that is it.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
post #3 of 14 (permalink) Old 01-11-2006, 10:52 AM
My Photos: (21)
The bulbs are clear; the tint comes from the gauge assembly itself.
The tint is not very strong, and if you put some red bulbs in there, you'd probably get red lighting. It might be a bit dimmer than you want, though, because of the green filter.
I've thought about LEDs for this. I'm OK with the green color, but I like the idea of never having to change them again. There are some LEDs made for that purpose that have an inverted cone in the front so that they shine out the sides. However, I haven't been satisfied with LED's for tail or backup lights, because they are not bright enough. They emit a strong narrow beam, but not a strong wide beam like an incandescant bulb does. So I'm afraid that, as instrument lights, they would be too dim. Here are some (red dash LED is last item on this page; scroll down to the bottom, click page 2 for other colors; first two items).
<font color="blue">Shoebear</font>
____________________________________
97 F-350 XLT PSD TDE1 crew long bed 4x4 automatic 4.10 SRW Line-X,
, TYMAR intake & HPX, Drawtite 65015 front receiver, Mag-Hytec on diff & trans, Banks downpipe & exhaust, Rancho 9000's, Velvet Ride's, Hypertech PPIII, Westach boost/EGT & trans/diff temp gauges, 2-pod A-pillar mount, Turbo Temp Monitor, Jordan brake controller,
1/04, Delvac 1, JS IDM,
Colorado Springs, CO -- at the foot of
shoebear is offline
post #4 of 14 (permalink) Old 01-11-2006, 10:54 AM
Covah's Avatar
I changed mine to red,used the ones from autozone. The bulbs were pretty dk red not very bright. Then I found some at wallmart lighter color red much better your gonna need 6 for dash and 2 for heater controlls 8 total.
95 crew cab,5spd,4x4,edge evo,3"downtube,no cat,4"exh,k&n,autometer pyro&boost,stancor,10k,smfw,240k,RSK& V codes
Covah is offline
post #5 of 14 (permalink) Old 01-11-2006, 12:55 PM
DIESELMIESTER's Avatar
Hey just checked out that link and will place order in near future I want LED lights on my truck also. Thanks for postin that. [img]/ubbthreads/images/graemlins/grin.gif[/img]
96 F-350 SRW LB STRETCHED 6-DOOR, PSD 5SPD,DETROIT LOC REAR, 4X4, 6 POS CHIP, 5'' STRAIGHT EXHAUST
DIESELMIESTER is offline
post #6 of 14 (permalink) Old 01-11-2006, 01:01 PM
I just read what covah posted about how many are reqiured for dash illum and didnt even know my heater controls are supposed to be lit, god do I feel dumb I always fumbled for them @ night and was wondering why ford didnt put lights in there because mine have never worked! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
post #7 of 14 (permalink) Old 01-11-2006, 01:57 PM
kfjensen's Avatar
Not to hijack this thread, but that link that Shoebear posted with the LED's, anyone know why if you put them in the tail lights they blow fuses?
Kevin
94.5, PSD, F-250, 4x4, Handshaker,
kfjensen is offline
post #8 of 14 (permalink) Old 01-11-2006, 02:33 PM
My Photos: (21)
If you get them, please let me know how they work. If you could post it and and then send me a PM to alert me to your posting, I'd really appreciate it. I'm afraid they'd be dimmer than factory, and for me, the factory is just bright enough.
I tried one of their tail lights. It didn't blow a fuse for me, but it wasn't bright enough, so I took it out. I only installed the LED in one side so I could compare to normal. I also had trouble getting the LED to fit through the hole in the lens box, but did manage to get it through.
Maybe you got a defective one?
I tried both narrow and wide beam. From 100 feet back, the narrow beam LED looked about as bright as the incandescent, but it looked much dimmer if I went off-center. The wide beam was only half as bright from directly behind, but didn't drop off so badly when I got off center. Neither one of them illuminated to the side at all. IMO, both would be significant safety hazards compared to incandescent. I also tried white vs. red. The white was a lot dimmer than the comparable red.
shoebear is offline
post #9 of 14 (permalink) Old 01-11-2006, 04:25 PM
gnxtc2's Avatar
I'm curious on this also. But did anyone try the LEDs in the taillights and see if the cruise control still worked? The LEDs are much less amperage than incandescent bulbs and the computer might read it as a burnt out bulb.
Check out the Tower LED bulbs.
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, D66, Punisher Trans with Precision Converter, Dana 60, 3.55LS, built 12/97, 3"-4" DP, Bilstein 5125s, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, CA fuel regulator, 4" Exhaust-Straight piped,FORD AIC, welded EBPV, B&M Transpan,, Joe Servo IDM, MAP sensor mod, RSK w/ "V" & "F" code SD springs, Hydroboost conversion, replacement 38 gal rear tank, Swamp's Baby Hybrids, Jonathan Jones Tunes, CJC Traction blocks, 227K
gnxtc2 is offline
post #10 of 14 (permalink) Old 01-11-2006, 04:42 PM
kfjensen's Avatar
Billy T.
gnxtc2@aol.com
Think those backup lights are any brighter?
Kevin
kfjensen is offline
post #11 of 14 (permalink) Old 01-11-2006, 05:46 PM
I got white faced gauges with blue lighting of Ebay for 6 bucks, if you get em drive the truck around for a bit so everything warms up take a mental picture of where the needles go pull the needles and the white face go right over the top put the needles back and done, the blue looks great at night! [img]/ubbthreads/images/graemlins/grin.gif[/img]
1997 PSD #34 Beans electric fuel, H2E FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (SD DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre/post turbo pyro), E4OD auto, 4.10LS, TC LU w/ ind light, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox light, ford manual hub conv., ext trim gone.
Highest hp 498, highest tq 950 corrected
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97 is offline
post #12 of 14 (permalink) Old 01-11-2006, 05:50 PM
gnxtc2's Avatar
They look brighter [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Billy T.
gnxtc2@aol.com
gnxtc2 is offline
post #13 of 14 (permalink) Old 01-11-2006, 07:11 PM
kfjensen's Avatar
Billy T.
gnxtc2@aol.com
...then stock..
Kevin
kfjensen is offline
post #14 of 14 (permalink) Old 01-11-2006, 08:29 PM
brahamfireman's Avatar
I have blue bulbs in mine. just changed the color of the needles.
Seen Here.
Diesel Rod
Formerly Diesel Rod.
A
with 295K miles, 90 LED's and 5" stacks, among other things....
A
Reg cab with 210K miles, Needs to go away. PM me.
SHORT HOOD. The ongoing "project" it aint pretty but its got a
425 air to air Cat motor
.....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
