Old 02-02-2007, 01:49 PM   #1 (permalink)
Chip causing no start?
Yesterday I left work heading for lunch and I noticed the check engine light coming on intermittenly and the more I paid attention the more I noticed that the truck was hesitating some. I left it running at the house over lunch and on the way back to the shop I saw no problem. I just went out at lunch and tried to go home for lunch again and now it wont start. I noticed when I first turned the key on that the wait to start light came on for a very brief period and then it would spin but no start. Now I dont get a wait to start light at all. I swapped a known good cps into it and still spin no start. My question is could my problem be my chip or the PCM? I am going back out when I get done posting to remove the chip and see if that makes a difference! Sorry so long fellas, any help is appreciated as always!!!!!
97' F-350, 4dr, 4x4, 5spd. 00' Lariat heated seats, Tymar intake, BDP stage 2's, Humped HPOP, Super duty turbo with ATS compressor side and banks 1.0 exhaust, 3 inch intakes, Tony Wildman tuning, California kit, Banks intercooler system, fleetguard 777 oil bypass, 5 inch exhaust, LUK Cermatallic clutch, MB Gel cells. 427.3/813.1
AKA: 00GAGUY
Sold - 2000 F-250 (GOODBYE MY LOVE)
00GaGuy is offline
Old 02-02-2007, 02:24 PM   #2 (permalink)
Re: Chip causing no start?
Clean the pcm contacts and make sure the chip is taped in securely, and don't wiggle or mess with the chip at all while the key is in the ignition.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 02-02-2007, 06:27 PM   #3 (permalink)
Thanks Wild. The chip has been in this thing for a couple of years so I didnt think that could be the issue. I didnt get to pull it out at lunch but I am looking at it now so I am going to try that.
AKA: 00GAGUY
00GaGuy is offline
Old 02-02-2007, 06:37 PM   #4 (permalink)
I Just pulled the chip and still no start. So I am going to plug it back in and try something else.
I Found fuse #22 to be blown. I replaced it and the glow plug light came on but then the fuse blew again. I think I have heard something about the fuel heater shorting? Where is the plug and what colors is it?
AKA: 00GAGUY
00GaGuy is offline
Old 02-02-2007, 07:35 PM   #5 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Its the fuel heater. Funny looking plug on the driver's side of the fuel bowl about halfway down. Red wire with a light green trace. You can also remove the fuel filter and disconnect the little spade connector in there (that's how I do it). Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 02-02-2007, 07:35 PM   #6 (permalink)
Tom S's Avatar
My Photos: (20)
You can unplug it inside the fuel bowl and see if that fixes it. The standpipe is left hand thread.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 02-02-2007, 07:36 PM   #7 (permalink)
STurbo90's Avatar
My Photos: (9)
Yes, unplug the fuel heater.
The plug is located on the drivers side of the fuel bowl. There are two connectors, it should be the top one.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 02-03-2007, 01:18 PM   #8 (permalink)
I got it. Thanks fellas. Luckily I slowed down and did a search last night after getting frustrated with it and found a post describing this repair. I just cut the wire and heat shrinked the harness end of it. After I repaired it the truck still wouldnt start and I got pretty ill about it. Then I realized that I hadnt put the new CPS in it. You can fix alot more when you slow down and think about what you have done. Thanks again for everyones help. TDS members save the day again.
AKA: 00GAGUY
00GaGuy is offline
» Sponsor Links
»Garage Storage and Cabinets
