Chip problem! PLEASE HELP - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-20-2010, 03:48 PM   #1 (permalink)
I have a 96 250 (7.3), and i just installed a ts 6 position chip. I made sure the contacts were clean and all that mess. The truck cranks and runs good in positions 1 thru 5 (stock, hi idle, +50, +75, +100), but when i switch it into the 6th position (+150) the truck cuts off. And all i have to do is switch to another position other than the 6th, and it cranks right up. Can someone please help me with this?
Elross is offline
Old 02-20-2010, 03:57 PM   #2 (permalink)
bugman's Avatar
My Photos: (18)
You need to get back with the programer and see what they say. The only problem with a 6 posistion chip is that after the 50 hp setting all you are doing is hopeing for more power since all the horsepower that the stock injectors will put out is around 50.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 02-23-2010, 10:38 AM   #3 (permalink)
Cratos's Avatar
My Photos: (15)
Yea be sure to fill in your sig so we can see what other mods you have, just adding a chip without the supporting mods will not have the desired effect.
97 F-250HD Super Cab 4X4 E4OD, 3.55 gears, swamps 238'/80s & SWAMPS Chip,Beans D-66 Turbo, Adrenaline HPOP & Reservoir Filter, BTS,TSM Disk Rear Brakes,DIY Electric Fuel system,DIY Air Filter,Auto Meter Dash Mounted Gauges: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp,Fuel Pressure Gauges,3 Inch Intake plenums, 4 inch MBRP, Intercooled, CCV mod.
294,000 Miles and still going Strong.
Cratos is offline
