Well the problem your going to run into is the stock injectors can only flow about 80 to a hundred horse over stock. the cfm range for them is too low. So you could put a chip thats designed for 140 hp on your truck, but your probably only gonna see more like 80 hp increase. If you want to go larger on the injectors, you can but you will be limited before you have to go and install a hi performance oil pump. Swamps and rosewood diesel both make very nice injector setups that are mild enough to be run with a stock pump. So to answer your question, you can put just about any chip on your truck, be it edge, bully dog, banks, hypertech, or any of the other programmers, and see about 80 to 100 hp increase. Or you could go the route of a multi position chip like TW performance, Swamps, or any other multi chip. These are nice because you can install one on a stock or mild modified truck and run it untill you start installing more mods (injectors, hpop, intercooler, turbo, or anything else) and you can pull the chip, send it back to the manufacturer and have them reprogram your chip to the mods you have done. Unlike a tuner where you are basically stuck with what you have.
Hope that helps and welcome to The Diesel Stop!
95 F-250 Stroke, Reg Cab, Short Bed. Custom 6637 Intake. EBPV gutted. CCV Mod. 10k Mod. 3 In Downpipe with 4 In custom Exhaust. Pyro, Boost, Trans Temp, and Hpop Pressure gauges. 35x12.50x16.5 BFG's On 16.5x10 Weld Typhoons, No lift, Yet.....
i would go with the injectors not much difference in money but will get more with no mods to truck than a chip
__________________ 1997 F 350 4X4, idm mod, wide open performance GQSSB turbo, stage 2` s by bean` s, intercooler, 4" no muffler, stack, trans from brians truck shop rear, disk brakes, and a stecher stage 1 hpop 6 position chip with bean` s programs crane valae springs, air dog lift pump and electric fuel pump and regulatorand water methonal injection
Have you done anything to your truck, or is it all stock? Your sig is empty. Depending on what you want to do, start with a DP the stock one is junk and restrictive. Then and gauges with your chip. But you will not see a big increase until you get bigger injectors
Call Dave @ swamps he can set you up. If you tow much be sure to tell them he has a kick butt tune for towing.
97 F-250HD Super Cab 4X4 E4OD, 3.55 gears, swamps 238'/80s & SWAMPS Chip,Beans D-66 Turbo, Adrenaline HPOP & Reservoir Filter, BTS,TSM Disk Rear Brakes,DIY Electric Fuel system,DIY Air Filter,Auto Meter Dash Mounted Gauges: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp,Fuel Pressure Gauges,3 Inch Intake plenums, 4 inch MBRP, Intercooled, CCV mod.
294,000 Miles and still going Strong.
ok thanks guys! What injectors do you guys recommend?
Lol that question is like taking 50 guys in a bar and asking them ford chevy or dodge. Your gonna get a bunch of different responses. Some guys like swamps, sume guys like beans. there are a few different manufacturers out there.
Deciding what stage to go with is easy if you figure out what you want your end result to be. Stage 1's are a noticible difference over stock and stage 2's are a noticible difference over 1's. Pretty much all dpends on what you want your hp at in the end and how deep your pockets are
i use beans have about 120000 miles with no problems
What Inj's....easy Casserlys, what size..also easy, whats your HP goals and Budjet?
hey cary, im over in winnemucca. You ever get over this way?
I'd like to but seems I never leave the shop
lol i know how ya feel. ma and a buddy of mine are just starting a diesel shop here. gonna try and get into big mods and stuff. Next time ur over this way, send me a pm, we'll grab a beer or somethin
