clear cab lights - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-10-2009, 09:40 PM   #1 (permalink)
clear cab lights
Has anyone tryed the LED clear cab lights from LMC?
-SEMPER FIDELIS-
1997 F-350 4x4 ,XLT ,LB, SRW, S5-42 5 spd, 4.10, 125,000 mi.
- Dp tuner , RDS stg 1's,D66, T444E pedestal, Autometer Z series Pyro/ boost, Diy Idm mod , shimed FPR, ccv mod, Diy Intake, 7.3 IC, Southbend Con o, 3" dp-4" Hog-6" Aussie stacks.
- 3" rsk, rear 2" add a leaf, 35" BFG all-terrains on 16x10 MT Classic II's, xrf ball joints and tie rods.
- line x'd rear bumper, clear headlights, turn signals, cab lights, 3rd brake and tail lights.
- Sittin in the garage, coolant filter kit, 203* stat.
- Next, Adrenaline, fuel syst. etc......
Pics.
http://entertainment.webshots.com/al...=entertainment
powerstrokin1997 is offline
Old 11-11-2009, 07:33 AM   #2 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
Not yet but am planning on getting them soon. They look pretty sharp in my opinion.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
Old 11-11-2009, 06:52 PM   #3 (permalink)
i just ordered some, ill let you know how they turn out.
-SEMPER FIDELIS-
Pics.
Old 11-11-2009, 09:30 PM   #4 (permalink)
Sweet. Definitely keep us updated.
CAI
IDM mod
TS 6 pos. Chip
3" PA Body lift
B&M deep pan
Adrenaline HPOP
Old 11-11-2009, 09:51 PM   #5 (permalink)
95DRW4x4's Avatar
I bought the amber lights from LMC and just put them on my 95. Then I bought white light LED bulbs because of all the hype on how good they are. To test them I installed them in two of the five lights. The amber color looked good with regular bulbs. But the two LED bulbs made the amber lens look green. So I put the regular bulbs back in. I'm sure since they are sold as a unit the clear ones will look good with LED bulb, just a lesson for me. Six LED bulbs from Advanced Auto $33...ouch! Just need to find a place to use them.
95 F350, 7.3 PSD, CC, ZF5 speed, 4x4, Dually, Autometer EGT, Boost and Engine Temp Gauges, DP and 4 inch exhaust, Tymar Intake, CPR Fuel System, Adrenaline HPOP
85 Ranger, 302, ZF5 speed, Klune-V, Dana 20, Explorer front and rear diffs, 35 inch TSLs, ARBs, Superwinch
95DRW4x4 is offline
Old 11-11-2009, 10:46 PM   #6 (permalink)
They are 194 replacements so you could use them in the instrument cluster if they are white leds. If they are amber bulbs you could use two of them in the corner lights on the front of the truck.
CAI
IDM mod
TS 6 pos. Chip
3" PA Body lift
B&M deep pan
Adrenaline HPOP
Old 11-11-2009, 11:07 PM   #7 (permalink)
95DRW4x4's Avatar
Yes they are the white 194s. Thanks for the info for instrument panel use.
95DRW4x4 is offline
Old 11-13-2009, 02:25 AM   #8 (permalink)
95FORDBOY's Avatar
clear turn green in about 3 months
1995 F350 7.3 PSD Blue White EXCab XLT 4X4 ZF5 * 349,000 KM * super duty Intercooler * DP Tuner * south bend clutch *ultra light HPOP , pyro and Boost Gauges * Customized 4" straight pipe no kitty * IDM MOD * AFE/Tymar * Viair Onboard train horns* custom winch bumper 12000 warn * royal purple everywere * 37/12.5/17E on 197 american racing * 4" lift* 6pc crystal headlights ,6000k HID's, 6" spots 6000k HID's*
95FORDBOY is offline
Old 11-14-2009, 01:59 AM   #9 (permalink)
Clear what turn green in three months? Are you referring to the clear cab light lenses or the clear led bulbs? If you are referring to the clear cab light lenses, how do you know this? Is this from personal experience at having bought them and installed them on your or another persons truck? When this happened what was the corrective method that you used to resolve this matter? Did you return them to LMC or did you simply remove the lenses and clean them and reinstall? If you returned them to LMC, what did they say as to why it happened? Thanks for any information you can provide to us about the "green" issue.
CAI
IDM mod
TS 6 pos. Chip
3" PA Body lift
B&M deep pan
Adrenaline HPOP
Old 11-14-2009, 09:40 PM   #10 (permalink)
Chinese lenses. Maybe not green, but a mixture of green/yellow. It takes a long time though, 6 months or so, which is pretty dang long lived for a chinese lense really, so you get good life out of it. 6 months clear, the rest green/yellow which is even better.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
Old 11-15-2009, 12:24 AM   #11 (permalink)
95FORDBOY's Avatar
a buddy of mine had them .... he got new black ones insted of the clear
Old 11-17-2009, 10:39 PM   #12 (permalink)
i just got the new lights installed. i love the way they look. ill try and get some pics posted tomorrow.
-SEMPER FIDELIS-
Pics.
Old 11-17-2009, 11:23 PM   #13 (permalink)
i dont think led lights will dim in the insterment cluster,try em and let me know,,,,,,has anyone used leds in tail lights just replacements in stock housings and how do they look?any brighter?
1996 F350 CREW CAB,37"tires,2003 hpop,160CC injectors,electric fuel system.malery pressure reg.6.0 intercooler,sd bd turbo,sd 3 in intakes ,tw 4 pos. chip,gauges,tcc disconect,mod.e4od,rear detroit,20,000remote cooler,baja fiberglass body panels,stage 3 methanol...............
NORTHRIVER1 is offline
Old 11-19-2009, 10:00 PM   #14 (permalink)
pics of the new lights
clear cab lights-dscf1569.jpg   clear cab lights-dscf1570.jpg   clear cab lights-dscf1571.jpg
-SEMPER FIDELIS-
Pics.
Old 11-19-2009, 11:00 PM   #15 (permalink)
95DRW4x4's Avatar
Lights look good! I really like the chrome base. Do you know if these lights are the same shape as the amber ones listed in LMC as 49-3700? They look the same to me.
95DRW4x4 is offline
