Clutch in to start - Switch delete?? - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 09-10-2007, 03:21 PM   #16 (permalink)
Re: Clutch in to start - Switch delete??
If that is the case I spliced the wrong ones initially. All I should have to do is twist them together correct?
95 PSW with 5 Speed Manual. 200,000+ miles.
LUK Clutch, 3" Downpipe, 3" Straight Exhaust, Tymar Intake
Ckill is offline
Old 09-10-2007, 07:48 PM   #17 (permalink)
johndeerebones's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ckill</div><div class="ubbcode-body">If that is the case I spliced the wrong ones initially. All I should have to do is twist them together correct? </div></div>
Please don't rig it like that, atleast splice it with a connector.
If you aren't gonna use the switch, bust it apart and see what the contacts connect when the switch is activated. Full proof way to find what wires to connect.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 09-10-2007, 10:15 PM   #18 (permalink)
STurbo90's Avatar
My Photos: (9)
I think the problem is there is 2 identical switches on the bracket for clutch pedal position, one for cruise and one for the start circuit.
I think he spliced the one for cruise.
the start circuit is red/blue, the cruise is white/purple.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 07-23-2009, 11:48 AM   #19 (permalink)
I just bypassed the switch. One of the replies in another post says it's the two white wires, another says it's the blue wires. I tried both, and it was the blue wires for me. I've got a 96 F250 diesel 2wd 5sp stick. I just pulled the plug, cut the wires before the plug, and put them together with a wire nut.
erikandelman is offline
Old 11-01-2009, 03:10 PM   #20 (permalink)
pschand's Avatar
Hey guys, can anyone tell me where the clutch pedal bypass switch is supposed to be? I just did the auto to manual swap and my truck starts in gear, and for me thats cool, but my wife drives it too and I have a bad feeling that she is going to put my truck though my living room one day... Is the switch already in my truck from the E4OD or do I have to go get a switch? Where do I hook it to? Thanks....
06/F350/6.0L/CC/4x4/LWB/AT/SCT XCAL2
My Old 96 Truck
pschand is offline
Old 11-02-2009, 01:46 PM   #21 (permalink)
There isn't a bypass switch...this old thread was talking about adding one.
The factory clutch switch (mounted on the clutch master cylinder pushrod) has two functions. One set of normally open contacts enables the starter motor circuit, so the engine won't start unless the clutch is pushed in. The other set of normally closed contacts drops out the cruise control when the clutch is pressed.
I added a bypass switch to the circuit that controls the starter motor. Flipped one way, the switch lets the clutch safety switch fundtion normally: you've got to press the clutch to start the engine. Flip to the other side, the starter will crank without the clutch being pressed. (In the middle position, the engine won't crank period)
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
coming soon: 6.0 IC
nashvillebill is offline
Old 11-02-2009, 04:13 PM   #22 (permalink)
pschand's Avatar
This is a great idea!! I'm going to go to the junk yard and try to find me a clutch pedal switch then I will hook it up with the bypass switch. Thanks for your awesome info!!!!
My Old 96 Truck
pschand is offline
Old 11-02-2009, 06:13 PM   #23 (permalink)
You may already have the wiring under the dash. If memory is right, there's two blue/red wires and two white/purple wires. Connector is something like a 7 pin plug, all the pins in a row. The connector may have jumpers in it from the factory if it was an automatic transmission.
coming soon: 6.0 IC
