Contemplating DIY E4OD (re)build - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 08-12-2009, 02:59 PM   #1 (permalink)
First a little background: I have a 1997 Crew-cab dually that I purchased third-hand with 194k miles. It's now nearly up to 200k, and it's primary purpose in life is to be a fun project for me to work on in my spare time (and to occasionally haul a load of junk or two.) One aspect of this project is that I wish to convert it over to 4wd. This will necessarily entail some transmission work. However, since it's nearing 200k with an unknown history, it's probably due for some work anyways.
I've found a guy selling an E4OD out of a '96 with a blown engine for what I believe to be a reasonable price. So the question of the day is: Are there any differences between a 1996 and a 1997 transmission that would affect the process or outcome of a DIY rebuild? If I go take a look at this transmission, is there anything in particular that I could/should check to make sure it's not completely toast/ruined/trashed/etc.? It'd be nice to be able to take my time building the transmission without having the truck inoperable the entire time.
If and when I go forward with this phase of the project I will likely use the RacerX kit parts that people seem so fond of.
Thanks in Advance,
RD
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 08-12-2009, 09:07 PM   #2 (permalink)
e4od out of a what??--it has to b another diesel trans. as the bellhousing is only diesel. most of those years trans have been rebuilt once already, and have a lot of the updates in em--
94_turbo is offline
Old 08-13-2009, 11:32 AM   #3 (permalink)
Feedback Score: 3 reviews
Do yourself a big favor...call John Wood and get his DYI kit..from a real trans expert.
Cary
caryt is offline
Old 08-13-2009, 09:40 PM   #4 (permalink)
What are you lookin at price wise for a rebuild kit from john wood?
97 f350 diy intake 3 inch downpipe 5" mitre cut stack Isspro boost, trans temp, pyro, TW 4 Position Chip beans fuel system. John Wood Trans. Tymar intake.
08 HD Night Train pc3 rinehart 2-1, woods tw6 cam
mstng5point0 is offline
Old 08-14-2009, 03:08 AM   #5 (permalink)
Send a message via AIM to rockets10510
what do you mean?
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 08-14-2009, 11:19 AM   #6 (permalink)
Big difference between someone that has built trans for years, developed many new parts and someone till very recently just sold radios. Talking to a expert and taking notes is different than doing it. Call JW or BTS don't take my word for it.
Cary
caryt is offline
Old 08-14-2009, 11:22 AM   #7 (permalink)
JW 760-356-9421
Cary
caryt is offline
Old 08-14-2009, 04:42 PM   #8 (permalink)
i had good luch with racerx. built 2 trans and both went great and hold up to the stage 1's and towing is so much better than the stock trans.
i used racerx and had no problems.
just my .02
Parts Replaced:
Parts Replaced
Old 08-18-2009, 10:17 PM   #9 (permalink)
Briansshop's Avatar
Member on here "Blindviper" also did his own rebuild w/parts from RacerX and he had nothing but good things to say about it.
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,up on 38s, Baumann TCS controlled E4OD.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 08-19-2009, 08:45 PM   #10 (permalink)
And she still barks the tires after 25k
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Some people are blinded--because they have all the answers
Racerxpower.com for your upgraded E4OD/4R100 needs
BlindViper is offline
Old 08-20-2009, 12:46 PM   #11 (permalink)
Choice is symple buy a kit from a master..JW or a past part time apprentice.
Cary
caryt is offline
Old 08-20-2009, 01:22 PM   #12 (permalink)
Thanks for the advice, everyone. I'll keep it in mind (and continue to watch this thread).
-RD
webshots
RD97 is offline
Old 08-21-2009, 10:40 PM   #13 (permalink)
How much better do you think a jw trans can be vs a bts or racer-x trans? Are you that simple minded that you don't realize that there is only so much you can put in a stock case?
Old 08-22-2009, 10:46 AM   #14 (permalink)
No but I do know that racer X can't get the parts that JW and BTS puts in, he's tried..And I know where RX got his "experience" from.
Its simple you want a trans that will handle anything get a BTS or JW otherwise take your chances with a DYI from others
Cary
caryt is offline
Old 08-22-2009, 05:43 PM   #15 (permalink)
Kinda funny my converter came from the same shop jw gets his?
Where do you think jw or bts came from? Do you think they just popped up from no where they had to start somewhere. My trans has had zero issues I drive my truck harder then anyone I know. When my trans was going out I called bts at least 3 times leaving messages each time. I never received one phone call. I got my kit from Racer-x, he took my calls, walked me threw steps I didn't understand. He even took my calls on a sunday during a family birthday. I go where the customer service is and no where else.
Do you really think that bts and jw have custom made clutches for these transmissions?
He asked about a rebuild kit not a complete transmission.
