Contemplating DIY E4OD (re)build - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 08-28-2009, 08:02 PM   #31 (permalink)
Originally Posted by BlindViper View Post
ctperformanceinc.com/services.html ct = Cary Towery = caryt
interesting,interesting-----
94_turbo is offline
Old 08-28-2009, 09:34 PM   #32 (permalink)
Torque converter splines, shaft splines and any where they should be attached. Normal black crud is ok but visible pieces of metal is not good.
Thanks for the info BlindViper.
One of these days I am going to have to get smarter on the E4OD and its common problems because my meter is running and I don't intend to sell my truck. I know I'll have to have it rebuilt and I don't feel comfortable doing it myself. But I want to be knowledgeable enough to ask the right questions of whoever I choose to do it.
Griz
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
Griz is offline
Old 08-28-2009, 11:52 PM   #33 (permalink)
Griz
The real key here with our trucks is to build the transmission. My trans had 3 "rebuilds" before I did the build and there was still factory wear parts in it.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Some people are blinded--because they have all the answers
Racerxpower.com for your upgraded E4OD/4R100 needs
BlindViper is offline
Old 08-28-2009, 11:58 PM   #34 (permalink)
Yes...I think a lot of re-builders put a band-aide in it and call it good. That's not really what I will be after. I want all the worn and weak parts replaced. I just need to learn what they are
Griz
Griz is offline
Old 08-29-2009, 03:35 PM   #35 (permalink)
which makes you wonder--just whats in a ford fac rebuild--
94_turbo is offline
Old 08-29-2009, 05:34 PM   #36 (permalink)
You got that right I suspect they fix the transmission and not rebuild them...not sure about that so take that as a uneducated guess and not fact. I would hope they upgraded and replaced all the worn parts but not sure. Just my 2 cents.
Griz
Griz is offline
Old 08-30-2009, 09:16 AM   #37 (permalink)
I think the ford trans are labeled as re manufactured. That should mean at least the wear parts are replaced.
Old 08-30-2009, 11:44 AM   #38 (permalink)
If that was the case then what is wrong with getting a Ford re-manufactured transmission and adding a better torque converter?
Griz
Griz is offline
Old 08-30-2009, 01:10 PM   #39 (permalink)
Send a message via AIM to rockets10510
Griz
nothing i thought about doing that but then my trans went south and i wanted to add the extra clutches and hardened steel gears
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 08-30-2009, 08:41 PM   #40 (permalink)
Griz
The factory design is barely up to snuff on a stock truck let alone a modded one.
