Coolant Filtration System...which one to buy? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-28-2005, 04:20 PM   #1 (permalink)
Ever since I replaced my water pump, I've been thinking I should install a good Coolant Filtration system, but don't know which one to get. Any ideas will be greatly appreciated. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
Griz is offline
Old 02-28-2005, 04:40 PM   #2 (permalink)
Re: Coolant Filtration System...which one to buy?
I think they use all the same or very similar parts. My advice would be to find the cheapest one since they are all basically the same.
ART
2005 Dodge Durango Limited w/HEMI.
2006 Chevrolet Cobalt LT.
SOLD 1996 F250 CC 4X4- Stage 1, Tymar, 4" exhaust, BDP chip...etc.
agsF2501 is offline
Old 02-28-2005, 04:42 PM   #3 (permalink)
bugman's Avatar
My Photos: (18)
I don't remember witch one that I went with but they are a sponser on the site here. I don't think that you can go wrong with any of them, just as long as you get one on the truck. On mine I had to build a bracket that fit onto the alternator to mount the filter to. I think that Dale I has one with that bracket already. Right now I am using the Baldwin precharged filters for my sca's. <ul type="square"> Jim[/list]
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 02-28-2005, 05:12 PM   #4 (permalink)
My Photos: (46)
Here's one from Bob Riley at Dieselsite.com http://www.dieselsitetoo.com/index.a...D&amp;ProdID=8 .
Bob is a sponsor here. I have had business dealings with him several times in the past, and would recommend Bob and his business to anyone.
(you may want to think about installing a coolant 'T' in your system as well)
'97 F350 CC, XLT, 4WD off road, 4.10, Milemarker manual hubs, Suncoast E40D w/ Bob Riley's (Dieselsite) remote filter & Triple Lock Torque Converter, Hypermax H2, BABY SWAMP'S! Swamp's 20* HPOP, Head Studs, TS 4 position chip w/ Bill's programming, Banks Intercooler. Ceramic coated up-pipes and down pipe. Triple pillar w/ Isspro boost, trans temp and digital EGT gauges. 4" Exhaust. 45gal Transfer flow rear tank. Dale Isley's HX mod. Joe Servo's IDM mod. Bob Riley's coolant filter, Coolant "T", Evans Coolant, A/C mod. Velvet-Ride's, Monroe Gas Magnum Shocks. TSM's rear disc brake kit. Frozen/ Slotted front rotors with Hawk Pads. Centramatic Wheel Balancers & 285/75/16 Michelin LTX/MS. Interior sound deadening (what a difference!).
BLDITRT1 is offline
Old 02-28-2005, 05:53 PM   #5 (permalink)
Go with Dale Isley - Tymar Performance. He is the best, hands down.
1996 F350 XL, PSD, CC, LB, SRW, Green/White, 4x4, 4L10, ZF5, LUK clutch & flywheel, 295/75/16 BFG AT on 16 x 8 Centerlines, Bill's Race chip, gutted EBPV, Ceramic coated Hypermax downpipe, Tymar 4" exhaust w/Donaldson muffler, Tymar Intake, Tymar boost pop-off valve, Tymar HX hose, Tymar coolant filter, JD Coolant eye, AC & fuel tank mods, Autometer Pyrometer & Boost gauges in pillar pod, Warn Premium hubs, Powerslot rotors, Smittybilt nerfbars, add-a-leaf & poly bushings, Bilstein shocks, Drawtite front receiver, Optima red tops, 130W Stainless KC Daylighters, stainless Ventshades, Eclipse CD player, MB Quart speakers, JL sub, Phoenix Gold amps, Viper alarm, Cobra CB, 2001 Honda CR250, 400EX & ATC 70 in the bed, not much more to come...
1996CC is offline
Old 02-28-2005, 05:58 PM   #6 (permalink)
Leroux's Avatar
Build your own! I have less then $20 into my setup. Here are the directions that I used.
2000 F250 Lariat, CA Emissions, CC, Long Bed PSD, 4x4, Manual, 4.30 gears, 82K Miles
Performance Mods: Tuned by PHP, Gauges, AIH Delete, 5" straight exhaust, DIY Intake
Suspension: Fabtech all spring 8" Lift, Fabtech Dual Front shock mounts, Fabtech Dual steering stabilizer, Bilstien 5125 on corners, 17" ATX Vice, 37" Toyo M/T
Leroux is offline
Old 02-28-2005, 06:24 PM   #7 (permalink)
Thanks everyone for the input. I didn't know Dale I. sold them. I called him up and order a kit. I've done business with Dale before and have always with happy with his stuff.
Thanks again for the inputs.
Griz is offline
Old 02-28-2005, 07:16 PM   #8 (permalink)
BlueMule's Avatar
My Photos: (12)
Thats also the way I did mine, just used a longer piece of angle and put coolant and atf filters side by side. [img]/ubbthreads/images/graemlins/smile.gif[/img]
BlueMule is offline
Old 03-01-2005, 01:02 AM   #9 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Mine (in my pics) is the Carpentractor (Keith Anderson) version, but slightly modified (different fittings for less joints and lower profile). Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 03-01-2005, 11:17 AM   #10 (permalink)
Pat, where did you get your fittings? Talking to Dale I. his kit mounts to the alternator also. I haven't received it yet, but like the looks of your 'Home Made' system...good job. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Griz is offline
Old 03-01-2005, 10:24 PM   #11 (permalink)
My Photos: (19)
I got them at a hydraulic supply place (not as cheap as a hardware store, though). I didn't like all the joints with the female hose barbs and nipples with Carpentractor's setup. The hose barbs are also the short "single" barb style. I also cut off the top mounting ear on the base and put a groove in it for the hose and clamp to clear. Cheers!
Old 03-02-2005, 12:03 AM   #12 (permalink)
It looks nice Pat. I'll see what I get with Dale I's kit. Hopefully mine will turn out as nice [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Griz is offline
Old 03-02-2005, 08:13 PM   #13 (permalink)
TYMAR coolant filter picture
PSDWILDERNESS is offline
Old 03-02-2005, 08:27 PM   #14 (permalink)
My Photos: (32)
Hey All,
In case you are considering a future I/C installation and thus want to leave that space beside that alternator clear for the cold side I/C tube, here is a link to my old post about fabbing a bracket to mount the filter between the jack and the fender.
No new ideas in my post other than location.
Here 'tis: Remote coolant filter install
These were the first pics I posted in my gallery so it makes more sense if you start at the end of the pics and work backwards! [img]/ubbthreads/images/graemlins/blush.gif[/img]
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
TimC63 is offline
Old 03-03-2005, 03:55 PM   #15 (permalink)
I received my Tymar coolant kit last night from Dale I and I am pretty impressed with it. It comes with everything you need to mount it to the alternator. Since I don't have an intercooler or plan to install one...this will work just fine for me. Thanks Dale Isley. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Griz is offline
