coolant temps - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 12-17-2008, 10:00 AM   #1 (permalink)
Question coolant temps
Hi what kind of coolant temps do you have with stg 1 injectors in cold temps i cant get my truck over 160 deg at -25deg celcius
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is online now
Old 12-17-2008, 02:28 PM   #2 (permalink)
johndeerebones's Avatar
The injectors have nothing to do with it really. You need an different thermostat if you want more heat. Another helper is does your ebpv work? I gutted mine, am glad I did, but it takes 8 years of highway driving to warm it up. The stock thermostats are rated at 192 or so, that is at full flow, so in reality they start to open around 160 or 170. Dieselsite has 203* thermostats that do a better job of keeping you warm. Our cooling systems also bypass flow quite a bit of coolant when the thermostat isn't even open, unless you are pulling a load, that flow is enough to keep it cool enough to not open the thermostat for a long time. I have the same problem, just haven't ordered a thermostat, as I am trying to sell my truck, so don't wanna mess with it if I sell it. The best thing I can do is plug it in, the block heater does a bang up job of getting it up close to op temps. My cold weather starting is top notch, never had a problem starting in cold weather, esp since the sd starter, new gps and a stancor, the block heater just helps warm it up a bit, as a bonus if you leave it on defrost it puts off enough heat to thaw the windshield too.
On a side note, the only difference I have with stage ones and cold weather is holy crap does it run when its cold out, makes me think I need an intercooler. And with the straight pipe, no ebpv, and stage 1s, it smokes like a freight train sitting in the driveway when its cold out. Oh well, its a diesel, semis do the same thing when its cold out.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 12-18-2008, 09:58 PM   #3 (permalink)
with that said mine smokes too and i think this is why it is cooler and harder to warm up i have my ebpv disconnected not gutted cause i cant get the damn thing warm enough to keep it off while driving i have thought of a 203 tstat but i would have to get rid of it in the summer though
Old 12-18-2008, 11:09 PM   #4 (permalink)
Why would you have to get rid of it in the summer. It is full open at 203, stock is full open around 192, no much difference. Typically, our trucks have no trouble at all staying cool even when its hot out and you have the ac on.
My Pics
Old 12-19-2008, 11:07 PM   #5 (permalink)
Ayuh,...
A quick, simple Fix is to block out the grille with cardboard....
A real weather Front is you want to get fancy....
2005 F550 pick-up DRW, CC, 4X4, Kelderman air, towing machine, 4.88 rear! Didn't buy an economy vehicle bought a towing vehicle.
1964 F100 (project truck in the works)
3 horse Sundowner trailer with 10' living quarters
AERC member (www.aerc.org)
Bondo is offline
Old 12-20-2008, 11:51 AM   #6 (permalink)
already done this thing is extremely cold blooded with these injectors the last 3 days have been -37 deg celcius
Old 12-20-2008, 01:48 PM   #7 (permalink)
ScottFraser2's Avatar
Yeah, I cant get any heat out of mine either. I've got the lund solid grille insets and cardborad blocking off pretty much all of the rad. My truck also smokes lots for the first ten minutes then just settles down to a blue haze (with the AIC on charge protect). After its been driven for a little bit the blue smoke disappears.
1986 F-250 Supercab 2wd 6.9l T-19B 4 speed 200,000 kms (125000 miles) College teacher dropped it off at my house to have for FREE !
1990 F-350 XLT Lariat CC 4x4 SRW 7.3l, E4OD (Now ZF5 with Luk SMF), 3.55, 281000 kms (175000 miles) Paid $1300 01/05
1995 F-250 XL Supercab 4x4 7.3PSD ZF5 (Luk clutch/SMF) 3.55 265000 kms (164000 miles) Paid $6200 10/08
2005 E-150 XL 4.6l V8 60000 kms (37000 miles) Paid $15000 09/07
ScottFraser2 is offline
Old 12-20-2008, 02:33 PM   #8 (permalink)
JMCX's Avatar
I put in one of the Dieselsite's 203* t-stats this fall. Works good, factory temperature gauge points straight up once you have driven a bit. I have no cardboard or grill inserts.
I also put on my plumbers cap and rigged up some rear foot heat for my complaining sledding buds in the back seat.
97 F350 SW CC 4X4 Auto, IDM mod, TW six position, DIY Stage I's, Beans D66 Turbo & 3" DP, 4" straight exhaust, Mobil 1 ATF, Tru-Cool 28k, Fuel filler mod, 99 Intercooler, Open Air Filter, SmittyBuilt stainless nerf bars, Trans-go tugger kit and Billet TC
04.5 Dodge 2500 QC 4X4 600 Cummins auto (work truck), 72 Mach I 552 stroker
JMCX is offline
Old 12-20-2008, 03:11 PM   #9 (permalink)
Check your thermostat, you may need a new one. A good stock one will work fine. BTW the temp ratings are STO (start to open) temps. Make sure you get one the right length or it can bypass too much coolant and make the engine overheat. One other thing you might check that might make your heater work better. Does your truck have a Y at the heater hose on the front of the pass head? If it does you can block or restrict the hose returning to the radiator.
444-4D is offline
Old 12-20-2008, 03:59 PM   #10 (permalink)
What he says, if you have the rad blocked off and its still cold replace the tstat, its gotta be stuck open.
My Pics
Old 12-20-2008, 07:21 PM   #11 (permalink)
Hmmm it might be worth trying a 203* t-stat. I just bought a new one from IH about a week ago thinking my stat was stuck open. It made no diff.
Old 12-20-2008, 08:21 PM   #12 (permalink)
i have a new t stat in the truck i would like to know where i could get the 203 other than dieselsite it is too darn hard to get s tuff to canada if some one has the correct IH application or part # that would be great
Old 12-20-2008, 08:33 PM   #13 (permalink)
drwoodchopper's Avatar
Well I could be wrong but I dont think there is a IH# for your year of truck. In 96' they changed the water pump the 94.5 and the 95's had the 203* stat I believe. I have the dieselsite 203 and have hauled 14K over a very steep pass at 90*+ with notemp issues.
Good luck.
1997 F350 CC4X4 120K superclean truck Beans 6 pos chip! IDM mod(it works!) Pyro, Boost and Trans Autometers over mirror. 4" straight pipe! 285/65X18's Nittos. Ford V-10 trans cooler, Tymar Intake, 6 leaker intercooler. Swamps 175/146 sticks fed by Adrenaline in front of a BTS. WOP QSSB turbo! 1997 F350 XLT 4dr 125K 5" Pipe no muf and no kitty (totaled). 04/04 F350 EX Cab LWB "Leveled" Lariat FX4 Limited slip. BFG's 295/75R16. 4" pipe from back of kitty exiting in front of rear wheel. Autometer Pyro and Boost guages 65K. 422hp and 772tq (SOLD) 96 F250 powerstroke extended cab. Original E40D 132K Wood hauling machine. 10k MOD. Autometer Pyro and Boost gauges. Gutted Cat. Sold.
1966 Mustang "mostly restored" replaced by 2009 Dodge Chalenger! My Youtube vid. http://www.youtube.com/watch?v=fdXy-bV6Zks
drwoodchopper is offline
Old 12-20-2008, 11:06 PM   #14 (permalink)
A fellow I work with that used to work at Ford on the diesel trucks said they used to get the 203* t-stats from John Deere. He can't remember exactly what machine they were for except they'd buy them by the box to cure customers complaints of low gauge readings in the winter time. Wish I'd talked to him sooner before buying another original t-stat with the same problem LOL. I guess if someone were to go John Deere and have the parts guys do a similar parts search for a 203* thermostat that measured 65mm in diameter they'd be able to find one?
