Cooling fan upgrade?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-05-2009, 10:27 PM   #1 (permalink)
zombietroopers's Avatar
Does anyone know if there is a way to get away from the heavy clutch fan. I know electric is an option but don't know where to start. I want to keep it simple. Right now I am running without the cooling fan as it is not warm in my neck of the woods. Just replaced the water pump again !! Seems that I'm only getting 125,000 km out of each pump. 380,000 km on the truck and I would like to keep going. Any advice on the fan??
1997 F-250 HD,5-Speed,4X4,Ext/cab,393,000 km 3" Turbo downpipe with 4" exhaust, No Cat,Firestone rear airbags,255/85/16 Toyo
M-55 tires,new transmission HD upgrade
Luk clutch/flywheel single mass conversion,Drawtight front hitch,Class 5 Hidden Hitch,Tekonsha brake controller,Warn 6000lbs.winch on custom removable plate,Tymar coolant filter kit,coolant eye,Tymar HPX kit,K/N cone air filter (open air),Shimmed FPR,SCMT 1705,Autometer boost gauge,Autometer pyrometer,SP Diesel EBPV dongle,Ford auxillary idle control.3 Electric cooling fans,gutted EBPV
zombietroopers is offline
Old 11-05-2009, 11:18 PM   #2 (permalink)
I don't know about the electrics, sounds great if they work. I don't trust aftermarket mods much. I'm still fighting my fan clutch after 4 new replacements I'm still not satisfied with how the clutch performs.
About the water pump, this may be just opinion, but it makes good sense. Most antifreeze is high in silicates to protect aluminum. From what I've read the silicate ruins water pumps in vehicals designed for low silicate antifreeze. Our trucks specify use only low silicate. I think only the old green standard antifreeze is low silicate and not all of it, you have to read and see if it meets the ford spec spelled out in the manual. I've been literally afraid to change antifreeze for this reason so after 13 yrs I thought it time and went to ford and got the correct antifreeze. If they don't have the motorcraft, they will hopefully have a suitable use antifreeze and it won't be Peak, Prestone or Zerex most likely. Sure all antifreeze whether it green, red, purple or hot pink says "Safe for all engines". Yea safe if you don't mind replacing water pump every couple years.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
Old 11-06-2009, 01:17 AM   #3 (permalink)
pjwoolw's Avatar
My Photos: (5)
An electric fan conversion is pretty pricey. I concur that the aftermarket (Hayden) clutches suck. I learned my lesson. Bite the bullet and go with the OEM clutch. I can't remember which pump is preferred. If I can find the name I'll post it up. Airtec??
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
Old 11-06-2009, 04:19 PM   #4 (permalink)
Supposedly Ford Windstar electric fans are suitable..if you dont tow heavy..from what i recall.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 11-07-2009, 03:00 AM   #5 (permalink)
Jcart's Avatar
ZombieT....how much do you tow and where? It would seem your ride is set up for towing and if so I would keep the stocker fan on....and just run w/o in the winter...Both my trucks have e-fans my '96 design is removable but just the same a hassle and if you tow a bunch there is nothin' like the B52 prop out front to cool things down. If not that much a E-system will work.
As a suggestion I used to run K&N and they are a good product just make sure you're on the maintanence...used to find small dust film on the intake upstream of filter...switched to donaldson paper no dust film....anyways I think I have some pix of the twin E-fans Taurus set up in my pix in truck folder....just for ideas...
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler.
http://community.webshots.com/user/jcart44
Jcart is offline
Old 11-07-2009, 09:26 PM   #6 (permalink)
I bought a fan from advanced auto parts with the thermostat included. hooked as per instructions and she works like a charm.
PROCOMP 14" INCH ELECTRIC FAN & THERMOSTAT SENSOR 16738:eBay Motors (item 230386329870 end time Nov-08-09 04:33:31 PST)
2003 F350 crew cab 4x4 Bone Stock.
RIP, For now. Left in a field in Wyoming.
96 7.3 f250 4x4 ext cab , longbed,3" downpipe to a test pipe, Gutted ebpv, tw 4chip, stage 1 injectors,Stealth oil pump,Electric fans. shimmed fpr . 19 mpg in economy mode 8mpg in extreme mode. 281,117 miles as of 11-30-11.
ryhed is offline
Old 11-08-2009, 12:06 PM   #7 (permalink)
Zrock's Avatar
iv been thinking the same thing changing over to electric fans... that fan and clutch is frigging heavy... I dont do any towing so electric would work great for me
1995 F250 Powerstroke
Zrock is offline
