Old 11-20-2005, 07:16 PM   #1 (permalink)
kfjensen's Avatar
Cooper Tires
I am looking for an E rated set of 265/75R/16's for winter. I dont want anything tooo aggresive just an all season. At tire factory they have Cooper Disco. ATR's for $166 a tire. That didnt sound too out of line, they are about the exact tire im looking for, I still have to hit Shwab before I make my desicion, anyone have any experience w/ these Coopers? Thanks.
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 11-20-2005, 07:24 PM   #2 (permalink)
Re: Cooper Tires
I run the Cooper tires on my F150's typically get about 60K miles out of a set. Never had a bad tire in over 500k miles of use.
Aaron [img]/ubbthreads/images/graemlins/cool.gif[/img]
We be a Ford House! '96 CC,PSD,DRW 4.10locker <font color="red">RED</font> '97 F150 297,000 miles '03 F150 SC Lariat <font color="red">RED</font> HER Truck!
wahoonc is offline
Old 11-20-2005, 07:30 PM   #3 (permalink)
kfjensen's Avatar
Re: Cooper Tires
Nice, that is a good thing to hear, he said they are 50k tires..
Kevin
kfjensen is offline
Old 11-20-2005, 07:40 PM   #4 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Re: Cooper Tires
With the weight of the PS your not going to get 50K out of a set of coopers. Best I ever did out west on my coopers was 30K, but they were the STT's.
MarkEkberg is offline
Old 11-20-2005, 07:50 PM   #5 (permalink)
Re: Cooper Tires
another option for u could be the yokohama geolander a/t's we run them on all our work trucks (4-dr, super duty, psd's) and have been having great luck with them always been in the 50-60k miles had one set go 72k (dumb luck) and these are work trucks we use for road construction just my .02
Joey
97 F-350,XLT, 4-dr, auto, 270xxx mi, Geolander A/T's, 4"exhaust, no ebpv, 203* t-stat, electric fans, lunar gauges, amsoil nose to tail, custom weight bracket and hitch for pullin, diy intake/air filter, hpx hose, LED cab lights, extra fuse panels, kenwood stereo system, pedestal from Rick, 4r100 out of an '01, trans mods from Jon, custom big fuel system, arb's front and rear, and 6.0 i/c, custom big oil
pics
"...the smoke rolled out and the day turned BLACK!"
stage II's
D66
THANKS BEAN!
awesome tuning
THANKS TONY!
'06 M7 153" Let it Snow!
joeyslushr is offline
Old 11-20-2005, 10:02 PM   #6 (permalink)
Believer45's Avatar
My Photos: (17)
Re: Cooper Tires
I ran a set of Cooper <font color="blue">DISCOVERER LT</font> size 255/85X16 (no longer available) for just over 70,000 miles on my two wheel drive 95 and currently have a set of 285/75 x 16 Cooper <font color="blue">DISCOVERER ATR</font> load range D (3305 lbs per tire) on mine and really like them. I have under 10,000 miles on these. They are much quieter and have a significantly better ride than the LT's did.
I have run coopers on several cars and a couple trucks and am more than satisfied with them.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Believer45 is online now
Old 11-20-2005, 11:35 PM   #7 (permalink)
Re: Cooper Tires
If you really want a "winter" tire in that size, then look at the Cooper Discoverer M+S. It is a true winter tire.
toalpi is offline
Old 11-20-2005, 11:56 PM   #8 (permalink)
Re: Cooper Tires
I run Pro Comp A/T's... great tire and they ride great. tires have over 20K on them and they still look perfect. I drive it in the snow at home here and the tires really hook up under all conditions I have here. I will be getting another set when these are done. And they have a 50K warranty. I got them at 4 Wheel Parts.
LOOK HERE for them... I have the size you want and they are E rated.
MY TRUCKS
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
&lt;&gt;&lt;
2002 Excursion PSD 4x4 XLT Premium- TN BB 1.0 Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner PCM QLJ5/PMT1 combo, Edge Juice/Attitude for gauges.
SOUTHERN CALIFORNIA POWERSTROKES MEMBER
mattymx is offline
Old 11-21-2005, 01:07 AM   #9 (permalink)
kfjensen's Avatar
Re: Cooper Tires
Does Shwab carry Yokohama or who does?
Thats not a bad sounding deal on those tires, I did notice that under the 235's, and 245's it says E rating but under the 265's said nothing but you said they are E rated so yeah....
Another thing to ponder on, is syping (sp?) worth the extra $?
Kevin
kfjensen is offline
Old 11-21-2005, 06:43 AM   #10 (permalink)
Re: Cooper Tires
i think summit usta carry yokohama [img]/ubbthreads/images/graemlins/shrug.gif[/img] otherwise i get mine from a local guy up here (tire associates)
syping- in my experience thats a bad idea until the tires r down past half tread or they really get chewed up fast [img]/ubbthreads/images/graemlins/eek.gif[/img]
Joey
pics
stage II's
D66
THANKS BEAN!
awesome tuning
THANKS TONY!
Old 11-21-2005, 08:58 AM   #11 (permalink)
Re: Cooper Tires
I'm running the Goodyear Silent Armor's on mine, quiet, good ride and in snow so for they been great. 50,000 mile warr. but the cost was a little steep 188 each for E's.
Jay
97 f350 cc lb 4x4, tymar intake, new turbo, gpr, glow plugs, fuel pump 223000 miles BFG's, new rear hitch 18k, new brakes, alt, fan clutch, belt, exhaust brake, 7.3 SD oil cooler, new spring bushings all 4, new track bar bushings, downpipe, DP F5, 259000 and counting add another gpr, upgraded headlight wiring harness.
Thank You and God Bless all active and retired members of our Armed Services!
All Gave Some, Some Gave All
97psdcc is offline
Old 11-21-2005, 10:32 AM   #12 (permalink)
Re: Cooper Tires
I used to run Cooper Discoverers 235/85s but didn't get the wear out of them I wanted ~30K (I do change tires early though owing to the amount of winter driving I do). Right now I'm running some General Grabber AT^2s (235/85 again) and am super happy with them, ~20K so far and they look near new. Good traction in the snow/ice and okay off-road as well. IIRC paid 160/tire installed.
97 psd, sc, 4X4, 4 pos Wildman Chip - Tymar Intake/H-max Downpipe
'99-'00 Igneous Pinners, '00 Igneous Smurfs, '02 Dynastar Arno Adams, '03 Atomic BIG Daddies, '04 V-Pros
-- Resident Bilge Don Quixote #3
lemon boy is offline
Old 11-22-2005, 09:38 AM   #13 (permalink)
Re: Cooper Tires
Been running Coopers on both PSD's for years. The 01 got a set of ATR's a while back.
You keep them rotated, keep the air right and take it easy from a stop and they'll give you 60-65k. That is with the older AT's.
I like the ATR's and will get a set for the '96 next spring.
'96 Red & White F250 XLT 4x4 PSD 4R100, a 4R100[/i] SC LB 4.10, Banks Stinger, BD Torque Convertor, Isspro Pyro & trans guages, 230k
'01 F250 4x4 Crew Shorty, DPPI 4" SSTL Exhaust, DP Tuner 80hp tow, Monster Box, Firestone Ride-Rights, Regulated fuel return and Cooper ATR's
3h Featherlite GN with Tennesse Walkers inside. Wyndancer Gordon Setters
Dan V is offline
Old 11-22-2005, 09:45 PM   #14 (permalink)
kfjensen's Avatar
Re: Cooper Tires
Yea I am heading in Friday to get a set of 265's on it, for $166 a tire...
Kevin
kfjensen is offline
Old 11-23-2005, 12:15 AM   #15 (permalink)
Re: Cooper Tires
I just got a set of Discoverer S/T's for my truck, they were around $170 per tire but that is 10 ply, if you don't haul much you might be able to get away with a less beefy tire. I haul 10-15k lb stock trailer and if you have ever driven over Ryegrass (the pass between Ellensburg and Vantage) you know you don't want to blow a tire with a trailer on that SOB. They are a fairly aggressive tire but I haven't noticed too much road noise (of course we are talking a PSD) but the traction in mud is awesome!
I have had the A/T and LT also and I was really happy with both of those tires. about 50k-60K per set with rotation.
Coopers aren't the cheapest but the quality is outstanding. And when I compared them to Les Schwab they were actually cheaper! And the quality of the Schwab tires isn't as good (and this coming from a guy who used to work at Schwabs)
1995 Ford F-350 Crew Cab 4x4 powerstroke 5-Speed 222k straight piped
1981 1/2 ton Chevy 2wd 395k
cowcountry is offline
