Old 09-12-2007, 12:36 AM   #1 (permalink)
D60 install info
I am doing a D60 swap on my 95 PSD 4x2, Given its an F350 I am putting the 4" OEM blocks in the rear and simply am working to level the truck out with a home brew RSK and "V" code SD springs.
So my question is if you were to level out a 95 F350 4x4 do you have to put longer brake lines, dropped pitman arm and some sort of track bar extension ?
Thanks,
Scott
95 PSD crew cab LWB 5 speed KP D60. Converted to 4wd from 2wd (wow, what a job!). Custom RSK with SD springs. 290k miles and running strong. SMFW conversion, 3" DP, 1.0 A/R exhaust housing on rebuilt turbo.
skeen550 is offline
Old 09-12-2007, 12:47 AM   #2 (permalink)
DIESELDUTTON's Avatar
Re: D60 install info
If you go on the two websites that sell the rsk one says its recomended and the other says its not needed. I will be done with mine tomorrow and I will be using the stock brake lines until I order stainless lines, also I will be using my stock pitman arm. I can let you know tomorrow if it works and I did use the drop bracket for the track bar that SKY supplied with the kit. Good Luck
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is online now
Old 09-12-2007, 01:37 AM   #3 (permalink)
cool, thanks for the info.
And actually, For the track bar I will just align it so it works/aligns properly. Given I have to drill 3 new holes for it anyway since the 4x2 didnt have one and there are no bolt holes there, until I drill'em [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
skeen550 is offline
» Sponsor Links
»Garage Storage and Cabinets
