Old 04-24-2005, 08:55 AM   #1 (permalink)
gnxtc2's Avatar
D60 swap done
Me and my buddy started at 8am on Sat. Had access to a lift but really didn't need, did everything on jack stands.
Took the POS D50 out in 2hrs. Probably the most hardest thing to do was taking out the old brackets near the oil pan. Everything pretty much well except for a few things.
1st snag. When I got the D60 from the donor vehicle, I also got the sway bar and related hardware. There were no holes in the frame for the end link brackets that go on the frame. Did alittle marking and drilling the brackets went on. Did any one else run into this before?
2nd snag. I also got the front driveshaft with the CV joint. But there was one problem, it was about 1.5' shorter than the D50 one. I did not pay attention to the donor truck but if that truck was a stick, would that be the reason the short driveshaft? I also took the front yoke from the TC and the diameter of the splines were smaller than my TC. The tag on my TC says its a 4407. I left the drive shaft out for now so I can bring to the driveshaft shop.
Other than the above problems everything went pretty smooth. Those D50 front leafs are thicker than the F350 ones. I also changed the rear springs also. Went with a 5 pack rather than the stock 4 pack. If anyone is thinking about changing out the rear springs, buy new shackles before tackling the job. I put urethane bushings everywhere and getting the old rubber bushings out of the shackle was a PITA. And they were rusted bad.
Few questions for the guys that done this swap. I know my alignment is way off, but my steering is way looser. I heard doing something about tightening the steering box. How do you do that? Or should I wait until its aligned? The truck sort of wanders, yes the Trac bar is installed. I know one thing, the turning radius is better. The ride is so much better. If anyone should come in contact with a D60 buy it and do the swap.
Anyone want a free D50?
Billy T.
gnxtc2@aol.com
Oh yea, I have to updated my sig and should I change the badges on the truck. Hmmmmmm....Did FORD make a F350 SuperCab??? [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
We go done around 10pm at night.
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, US GEAR downpipe, Bilstein 5150s, Front add-a-leaf w/urethane bushings, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, Shimmed fuel regulator, 4" Exhaust-Straight piped,FORD AIC, Custom triple A-pillar gauge holder,B&M Supercooler, gutted EBPV, B&M Transpan, ART Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, 149K
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 04-24-2005, 09:01 AM   #2 (permalink)
Re: D60 swap done
Did you install a track bar? its a must have with a D60. Now ya need SD springs [img]/ubbthreads/images/graemlins/grin.gif[/img]
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 04-24-2005, 09:49 AM   #3 (permalink)
Re: D60 swap done
nice, got mine in my truck on friday.
you wanna know how to do a garage alinment and have it really really close????
i still dont have my track par on mine, gonna finish that up today. had to do some fab work to get it done i didnt get the track bar or mount with mine.
i used to have the link for the steering box slack adjustment i gotta find it cause i need it too.
i found out why mine is riding soo rough the rubber shackle bushings are frozen so the shackles arnt moving on the pins the rubber is flexing. reverse shackle may happen next weekend...
they didnt make a F350 supercab thats why i bought a F250..
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
00 F350 4X4 CC
RIP CHRIS. 03/09/05
http://community.webshots.com/user/barebackjake
barebackjake is offline
Old 04-24-2005, 10:42 AM   #4 (permalink)
My Photos: (10)
Re: D60 swap done
thats the nice thing about a 60 you dont need to take it to get a allimant all you need is 1/8-1/6 toe in and thats all you can use a tape masure or make up a slide stick like i did its simple to do [img]/ubbthreads/images/graemlins/smokin.gif[/img]
<font color="red"> we are not here for a long time we are here for a good time </font>
<font color="blue"> MICHIGAN POWERSTROKE ASSOCIATION </font>check it out[img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
my picts
other toys
92 ranger extended cab with 310,000 miles
86 f-250 4x4 6.9 diesel 450,000 miles and still going strong
87 f-350 xlt 4x4 4 door 6.9 340,000
87 f-250 xlt 6.9 140,000
97 f-350 exteded cab 4x4 NATHAN P3 TRAIN HORNS two whipps, SWAMPED INJECTORS,head studs,cometic head gaskets, h2e turbo,lots of boost almost too much,joes idm, built e40d 4.10 gears,4 pos ts performance chip,open ellement air filter k&n #41-1400 hypermax 4in dp,kitty is in the litter box.10k mod shimmed,autometer gauges boost,oil pressure, pyro,trans temp, 6 in lift,6' traction bars, diamondplate toolbox, 5in stacks,lighted ford logo in the grill
smokinstroker is offline
Old 04-24-2005, 11:44 AM   #5 (permalink)
Re: D60 swap done
i just use the toe plates for my dads sprint car. or you can have someone spin the wheel and scribe a line it in meausure front and back side and 1/8" in is what i run at. everyone around here wants $90 for an alinment cause its a 4x4......even though theres only one adjustment to make....
00 F350 4X4 CC
RIP CHRIS. 03/09/05
Old 04-24-2005, 11:52 AM   #6 (permalink)
gnxtc2's Avatar
Re: D60 swap done
I tried to do the garage alignment but didn't work for me. Either it was late, brain wasn't functioning too good.
We locked the steering wheel straight with that lock that goes between the seat and the steering wheel. Had pitman arm entered, we thought. We then left the key on, first click. Took a tape measure and measures the tires, off 1/2" but don't know with way, friend had tape measure. Ah, close enought. Started to drive the truck, the steering wheel is at 1 &amp; 7 o'clock postion. I'm just going to drop the truck off at my friend's shop, doesn't charge me.
Billy T.
gnxtc2@aol.com
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 04-24-2005, 11:53 PM   #7 (permalink)
Re: D60 swap done
factory supercab f-350's exist. i've seen plenty all were dually's though and 2wd. they also made regular cab f-350's. just keep lookin and you will run across one.
RYAN
GAUGES, INTAKE, EXHUAST, SBC CLUTCH, CHIP, BDP INJECTORS, BILSTEINS, BUSHINGS...AND A WHOLE LOT MORE..
pics
B99 BIO DIESEL SUPPORTING AMERICAS FARMERS.
US NAVY
looking for an ext cab 4x4 short bed DURAMAX!!! keeping the obs of course.
1997PSD4ME is offline
