Old 11-20-2005, 07:29 PM   #1 (permalink)
kfjensen's Avatar
Dana 50 Help
Alright, well a while back I put in add-a-leaves which raised the front end but now instead of the tops of the tires in they are out. My buddy gave me These which are for a diesel w/ a Dana 50. I was just wondering if anyone else has used these longer brackets in conjunction with add-a-leaves and if it made the tires half way straight and aligned...thanks.
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 11-20-2005, 09:30 PM   #2 (permalink)
Re: Dana 50 Help
Those are drop brackets for the pivot points of the I beams. Yes, they are designed to help alignment. However it is had to say if it is enough or to much drop for your truck. Usually the springs and brackets are bought to work with each other.
'95 F250 PSD, Bean 170's, AFE intake, HPC'd 3" downpipe and 3 1/2" cat delete, Magna flow 4" exhaust, DP/Bean 6 pos flip chip with TWildman burns, 6" lift, 35's, 4.10's, ARB frt/rear, custom pre-runner bumper, and some stereo stuff. Daily driven.
'73 Bronco buggy
'06 Jeep Liberty CRD (stock for now)
'90 Miata go-cart
rckcrlr is offline
Old 11-20-2005, 10:54 PM   #3 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
Re: Dana 50 Help
It sounds like you need to take your truck to an alignment shop and have them take care of it. I am willing to bet that you will need 2 $50.00 shims to take care of the problem. One for each wheel. That is the curse of the Dana 50, whenever it needs to be be fixed it is at least $100.00.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 11-20-2005, 11:06 PM   #4 (permalink)
PSDfreak's Avatar
Re: Dana 50 Help
if you put the add-a-leaf in the to compensate for saggy springs i would do as was said before. Take it to an alignment shop and have them install the correct shims. You probably just need a different degree installed to bring you back straight. For me is was $38 bucks installed for two and now im perfect...knock on wood [img]/ubbthreads/images/graemlins/wink.gif[/img]
Good Luck,
Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 11-20-2005, 11:07 PM   #5 (permalink)
Re: Dana 50 Help
The Ford F-Series front tires sat a little out at the top when they were new. How much are they out? [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1997 F250HD Regular Cab 4x4, 4.10 SRW, Handshaker ZF5 Tranny, Bean Stage I's, TWildman 4 Pos Chip, 3" Downpipe/4" Exhaust, Tymar Intake, Luk Single Mass Flywheel/Clutch, IDM Mod, Ford AIC, Stancor GPR, HX Mod, Gutted EBPV, Dead Kitty, Coolant Filter, 203* Stat, Twin Electric Fans, A/C Mod, GPR Bypass System, 1.0 A/R Turbo Exhaust Housing
There's no Substitute for Cubic Inches!!!
F250Jockey is offline
Old 11-20-2005, 11:18 PM   #6 (permalink)
hansvl's Avatar
Re: Dana 50 Help
I have the same problem, I just had new stock front springs installed and I asked the spring shop to arc them an extra inch, the end result was the top of the tires were out.
I had it alligned and they put in the largest shims which corrected it a lot but they are still not standing straight. The way they explained it to me was that I got a lift without the lift kit and that I would have to get those brackets to straighten it out and they would probably have to allign again.
good luck, let me know the final result.
94 powerstroke 5 spd, 4x4 xcab longbed,5 spd, 189.000 miles 4.10 gears, tymar style open intake, 3" DPPI downpipe, South Bend clutch, Edge EZ,pyro gauge, 1" front lift, Firestone airbags rear, 285 Toyo a/t tires, BB in fuel regulator
http://good-times.webshots.com/album/55769610
Go to my albums.
hansvl is offline
Old 11-21-2005, 01:00 AM   #7 (permalink)
kfjensen's Avatar
Re: Dana 50 Help
Yeah, I will have to get it in on the rack again. Last time I did was a while back, it was at Shwab and they said that it was to bowed out to do anything with and I had to wait till it sagged out a little more, it seems you just cant get ahead w/ this damn front end...
Kevin
kfjensen is offline
Old 11-21-2005, 11:50 AM   #8 (permalink)
Re: Dana 50 Help
Yep... time for a D60! [img]/ubbthreads/images/graemlins/grin.gif[/img]
My tires get cupped really bad if I don't keep them rotated.
I've got a D60 coming... probably sometime after the 1st of the year.
I can hardly wait to get rid of the TTB.
JOHN
FOR SALE*1996*F250*4X4*<font color="red">RED</font>*CC*SB*E4OD*4:10's*4" Exhaust *Tymar*Factory AIC*SnugTop Shell**NAW4*129,XXX miles
KC Fan is offline
Old 11-21-2005, 12:32 PM   #9 (permalink)
Re: Dana 50 Help
Are you sure it ain't your shocks? [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Old 11-21-2005, 12:51 PM   #10 (permalink)
Re: Dana 50 Help
Well it could be, but the shocks only have about 25,000 miles on them and it is only happening on one side.
The way that the TTB pivots just tends to wear to inside and outside edges IMO.
Besides, it is a good excuse for the better half... [img]/ubbthreads/images/graemlins/grin.gif[/img]
John
KC Fan is offline
