03-25-2007, 09:02 PM
#1 (permalink )
Dana 60 is in!!!
well, i got lucky and was able to pick up and install a dana 60 over the weekend [img]/ubbthreads/images/graemlins/biggrin.gif[/img] it came out of a '94 f-350 dually dump truck with a whopping 68,000 miles on it [img]/ubbthreads/images/graemlins/cool.gif[/img] i got everything with it, sway bar, trac bar, and all the brackets. i installed f-350 springs in the summer, so i didn't need them. the only thing i have to do is replace the steering linkage, finish drilling and bolting up the sway bar brackets and bolt on the driveshaft. surprisingly, the truck sits level now, so i won't be raising the rear end. i ended up with all new rotors, pads, calipers, u-bolts, and brake lines. while getting the brakes worked on, i changed out the master cylinder with a reman because i started to see signs of failure. i have to thank lil joe (wreckaboy1) for his help with the installation. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
here's a few pics
Matt
'96 F-250 XLT,ext-cab,4x4,BTS E40D, 249k,dana60,swamps175/173s,CPR Fuel sysatem installed 8/2/08,rear discs
4" dp to 6" exhaust w/ twin 6" miter cut stacks,Tymar,Autometer Lunar Boost,Pyro,and Tranny Temp,white-faced gauges ,
intercooler,diamond headlights and corners ,
onboard air ,
HX mod ,Twildman 6-position chip,shimmed fpr,led 3rd brake light,2 green neon underbody kits+extras,clear cab lights,alteeza tails,4 corner strobes,Sirius satellite,kenwood mp3 player
NRA Life Member
North-South Skirmish Association
"Gotta love the fresh smell of diesel and black powder in the morning!"
03-25-2007, 09:56 PM
#2 (permalink )
Re: Dana 60 is in!!!
So what did ya have to pay for the 60?
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
03-25-2007, 09:57 PM
#3 (permalink )
where did you get it?
03-25-2007, 11:34 PM
#4 (permalink )
i drove away from a cool guy in massachusetts with $800 less in my wallet [img]/ubbthreads/images/graemlins/smile.gif[/img]
Matt
onboard air ,
NRA Life Member
03-26-2007, 10:18 AM
#5 (permalink )
That's ironic. I live in Lansdale an am getting my D60 from MA.
96 F250 Crew Cab 460 4x4
79 Bronco 4" rough country, 38"TSL's,5.13's locked f/r, Warn 8274
05 Excursion ltd.
93 Escort Wagon.
95 Bronco XLT
03-27-2007, 05:00 PM
#6 (permalink )
You've got PM!
03-27-2007, 10:12 PM
#7 (permalink )
Did you use your old drive shaft or a F-350 shaft?
1997 F-250 XL SC 4x4 3.55 ZF-5, Kingpin Dana 60, 1" add a leaf, open element air filter, Hypermax downpipe w/4" straight pipe, Mile Marker locking hubs, Energy Suspension bushings, LUK Clutch
2001 Dodge Ram 2500 4x4 CTD Quadzilla XZT
<font color="blue"> NOVAPS Member </font>
<font color="blue"> Northern Virginia Powerstroke Club NOVAPS </font>
03-27-2007, 10:46 PM
#8 (permalink )
he stil has the old driveshaft on it. in order to change to the f350, you need to change the yoke on the transfer case, we just did not enough time to do it all in one day.
1997 F350 CC 4x4 5spd- 4.10, XLT, custom intake, custom 4 inch exhaust, 4 inch lift, cerametallic clutch, Ramsey hydraulic winch, PTO, swamp babies, 6 pos. TS chip, hideaway strobes etc..all the goodies
1995 F350 Wrecker, 4wd, Vulcan 882
Truck Pics
03-29-2007, 03:21 PM
#9 (permalink )
I got my 60 with everything for $500......
1997 F250 Regular cab 4x4, '97 12V, 911 pump, 4KGSK, L/C DV's, studs, o-rings, 435's, HTT Pro Street 66/71/13SS, Cool Twist 6L I/C, 7" Aussie stack
Next up: Home built trans
My Stuff
03-29-2007, 04:58 PM
#10 (permalink )
give ya $600 today!
cary
2006 Yamaha FJR1300
03-29-2007, 11:38 PM
#11 (permalink )
i got everything to convert my 2wd to 4wd for 500 bucks. trans, tcase, front 60, rear sterling, and all springs/mounts.
i cant wait to get back into pa, catch up with all the guys from my area again.
83 F250 6.9 rebuilt at 280,000. NP435, NP205, 4x4 conversion with hp60 front, 10.25 rear. 35inch Cepek Mud Countrys - RESTING IN PEICES (PARTED OUT)
99 Expedition 5.4 gasser
2000 F550 Lube Truck (Work Truck)
Certified PA Inspection Mechanic
i'd rather be 6.9'n than cummin or strokin'!
03-30-2007, 12:27 AM
#12 (permalink )
^^^^^^ [img]/ubbthreads/images/graemlins/smokin.gif[/img] And I thought I did well....I guess thats what I get for "bragging" [img]/ubbthreads/images/graemlins/laugh.gif[/img]
My Stuff
03-30-2007, 12:42 PM
#13 (permalink )
i guess it all depends on location and mostly luck as to how much you'll be able to get one for
Matt
onboard air ,
NRA Life Member
03-30-2007, 01:45 PM
#14 (permalink )
Cool!! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Can't wait to get my project underway!! [img]/ubbthreads/images/graemlins/smile.gif[/img] Got the D60, just need to disassemble and rebuild.
1997 F-250 HD, XLT, PSD, Ext. Cab, Off-Road pkg., 3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, Lund visor, 151,000 miles, triple Auto Meter gauges, Tymar intake, Tymar DP, Straight piped, 5" Miter Stacks, Tuning by DP Tuner, 315/70/17's.
Without data, it is just another opinion!!
Linear Mode
» Site Navigation
» Other Sites
» Network Links
