I might be able to get a front D60 from an 86 F350 with a 6.9. Actually I will have access to the whole truck so I can get everything from brakes, springs, steering, etc... Is this a bolt in swap for the most part on my 95 F250? I like the idea of a king pins instead of ball joints, is that the only difference?
Yes, just bolt it in. Brake lines may or may not have clearance issues but other than that just bolt it up make sure you use the 350 springs or go all out with an RSK and SD springs for a good ride.
1996 F250 Crew Cab 4x4 PSD Mods=
All DIY- E4OD Upgraded DIY Rebuild at 125k, Stroked Injectors, Tymar Style Intake, Exhaust, IDM, DIY RSK with V code SD springs, 1-piece TTB, Big Tranny Cooler and Full Tugger Kit
DP Tuner Chip
Pyro-Tranny-Boost Gauges in Autometer Full Pillar mount
yep works great...drop the i-junk and bolt up the 60
96 f250( Big Foot ) 3" downpipe, 4" exhaust(no kitty or muffler), ancient superchips program, shimmed fpr, intake, guages....thats it for now
future.......i still dont know what direction i want to go yet
teh brake lines do work with a kingpin unit , you jsut need to shave a bit off teh side of teh block to teh caliper.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
Will the SD springs bold right up or are they ar different lenght?
They will bolt up if you do some mods..a RS kit or add SD shackels. Check the Tons of posts on the mods.
cary
-Michael
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
