Dana 60 Write up? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 12-12-2008, 12:22 PM   #1 (permalink)
Dana 60 Write up?
Hey guys, Finally got out of denial that my truck needs a new front end. So... does anyone have a good write up on the d60 swap? How big of an undertaking is it? I don't have very much experience with suspension and steering but am mechanically inclined, I have access to a lift and some good knowledgeable help. Any feedback would be great. Thanks!
Brad
96 F-250 extended cab long bed, 5-speed, Luk clutch, 4x4, 4.10, 3" lift, 35x12.5 BF All-terrains, 3" down pipe, straight pipe, shimmed FPR with gauge, stage 1 injectors, Dp-Tuner F-5 80 econ. 1100 HI-Idle 100HP Performance, Gauge style switch, ISSPRO pyro and boost, water temp, oil pressure, SuperDuty starter. 193,000 and counting
blaster1288 is offline
Old 12-13-2008, 11:11 AM   #2 (permalink)
Feedback Score: 3 reviews
One day install with a lift. Get a RS kit from ORU or Sky and front and rear V and B codes from a SD. A adj track bar will be needed and a F350 CV front driveshaft. A set of Bilsteins, 4" rear F350 block, longer SS brake lines and a rear sway bar will finish the install.
Check all the RS kit posts as this mod has been posted many times since I first did it 5+ years ago.
Cary
Cary
caryt is offline
