Old 01-21-2008, 06:40 PM   #1 (permalink)
darn oil leaking pedestal!
i thought i had fixed the oil leak when i had the motor out but it is still leaking. i replaced the 2 o-rings between the pedestal and the block and the 2 between the pedestal and turbo with o-rings out of an o-ring kit i had, is the ones from ford different, mabey thicker? they looked the same. i dont see oil coming out of the rod so i think the only place left is those o-rings? could i dissasemble again and put some grey rtv on the matting surfaces or would that be a no-no?
thanks, rob
flcobra is offline
Old 01-21-2008, 07:59 PM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
some have found small hairline cracks in the pedastal itself.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 01-22-2008, 01:14 AM   #3 (permalink)
johndeerebones's Avatar
Also I don't know about your kit, but the orings from International are yellow. Different oring colors usually mean different materials. Better heat resistance, holds x pressure yada yada yada...If your kit was plain ole nitrile black bet they can't take the heat so to speak.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 01-22-2008, 08:05 PM   #4 (permalink)
I had the same problem, replaced the o-rings twice, gutted and plugged the back pressure valve, finally resolved it after replacing the turbo. I've unfortunately been quite busy and haven't had a chance to disassemble and examine it. No visible cracks in the center section either.
preith is offline
Old 01-23-2008, 06:30 PM   #5 (permalink)
a-ha, my o-rings are just the old off the shelf junk, that makes sense. i'll run to ford and get the right ones.
i was also thinking mabey the mating surfacees could have warped? the old owner knocked a connection loose on the turbo and ran it without the turbo for about a mounth untill he brought it to me so i could fix it. could this have warped the surfaces?
thanks, rob
flcobra is offline
Similar Threads
Leaking oil from turbo pedestal tcdfwilson Power Strokes 1994-1997 General 1 05-27-2007 12:55 AM
turbo pedestal leaking oil lebeouflimousin 7.3L Power Stroke Engine and Drivetrain 3 11-27-2006 10:01 PM
Leaking at the turbo pedestal boulder 7.3L Power Stroke Engine and Drivetrain 8 01-13-2006 06:27 PM
oil leaking from turbo pedestal bpence 7.3L Power Stroke Engine and Drivetrain 5 03-05-2005 07:02 AM
oil leaking from turbo pedestal bpence Power Stroke Excursions 1 03-04-2005 08:40 PM
