dash bulbs - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-20-2009, 10:49 AM   #1 (permalink)
edieedie's Avatar
Question dash bulbs
sometime back their was a post on installing brighter dash bulbs
i think their was 3 different wattages given
i have done several serches and cant seam to find it
can someone help
1997 F 350 4X4, idm mod, wide open performance GQSSB turbo, stage 2` s by bean` s, intercooler, 4" no muffler, stack, trans from brians truck shop rear, disk brakes, and a stecher stage 1 hpop 6 position chip with bean` s programs crane valae springs, air dog lift pump and electric fuel pump and regulatorand water methonal injection
edieedie is offline
Old 02-21-2009, 11:11 AM   #2 (permalink)
edieedie's Avatar
come on boys. help me out
was posted here last summer
l
edieedie is offline
Old 02-21-2009, 11:51 AM   #3 (permalink)
My Photos: (60)
From an old post, 194 LED bulbs would be one option, they are supposedly brighter.
Another option would be 168 bulbs which are standard bulbs but brighter than the 194.
This came from a post in the 6.9L diesel forum and, of course, would only apply if the bulbs in your truck are 194s.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 02-21-2009, 03:01 PM   #4 (permalink)
edieedie's Avatar
thank you, i though i seen this post last summer but anyway thanks again i think their were three numbers given and the ones you give were right need brifgter light would consyder led` s but the reostat would have to be changed in order to control brightness
edieedie is offline
Old 02-22-2009, 08:42 PM   #5 (permalink)
gnxtc2's Avatar
Yea, I posted the part numbers for the bulbs. The 168 are brighter then the 194s. Let me see if I can find my original post.
Billy T.
gnxtc2@aol.com
Ahhhh found it:
TheDieselStop.Com Forums: Instrument Cluster Lighting
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, 3"-4" DP, Bilstein 5125s, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, CA fuel regulator, 4" Exhaust-Straight piped,FORD AIC, welded EBPV, B&M Transpan, Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, Hydroboost conversion, replacement 38 gal rear tank, Swamp's Baby Hybrids, CJC Traction blocks, 209K <---STOLEN
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 02-23-2009, 10:30 AM   #6 (permalink)
edieedie's Avatar
thank you, i knew i seen then here, i done several searches but could not find it
edieedie is offline
Old 02-23-2009, 11:42 AM   #7 (permalink)
Cratos's Avatar
My Photos: (15)
yea i just did 168's much brigher
97 F-250HD Super Cab 4X4 E4OD, 3.55 gears, swamps 238'/80s & SWAMPS Chip,Beans D-66 Turbo, Adrenaline HPOP & Reservoir Filter, BTS,TSM Disk Rear Brakes,DIY Electric Fuel system,DIY Air Filter,Auto Meter Dash Mounted Gauges: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp,Fuel Pressure Gauges,3 Inch Intake plenums, 4 inch MBRP, Intercooled, CCV mod.
294,000 Miles and still going Strong.
Cratos is offline
Old 02-24-2009, 08:31 AM   #8 (permalink)
would you be able to find those bulbs in a auto parts store or where would you buy them cause i just replaced my gauge bulbs with led autometer bulbs and now the gauges are brighter then the dash lights
BlackBeauty96 is offline
Old 02-24-2009, 09:58 AM   #9 (permalink)
Cratos's Avatar
My Photos: (15)
autozone is where i got them in stock i tink i saw them in walmart too
Cratos is offline
Old 02-24-2009, 12:06 PM   #10 (permalink)
are the bulbs green and how many are there too and also how hard is it to do i was planning on doing it today
Old 02-24-2009, 12:14 PM   #11 (permalink)
korg70bc's Avatar
Send a message via Yahoo to korg70bc
Its SUPER EASY!!! I just did my whole instrument panel Big time diff w/168's over 194's. Just don't lose any screws!!!
1999.5 F250 SD short bed Lariat 182k, autometer gauges (the usu), 4" turbo back exhaust, CCV mod, a lot of other things to put on, but got to fix basic maint first!
korg70bc is offline
Old 02-25-2009, 03:25 PM   #12 (permalink)
Send a message via AIM to bamboo
Can you get different color bulbs? Like maybe just some whiteish light not green? or blue maybe?
Mahaloz..
-patch
1996 F250 X-cab SB, zf-5, open element intake, tymar 3-4" DP, 4inch dual DE exhuast,gutted EBPV,MidWest Shortshift kit, DP-tuner chip,Gauges,
sounds, with a bunch of rammat and ensolite in the cab.
1997 f250 longbed xcab,zf-5, 4inch lift with 18 inch wheels and mickey thompsons
Motor all stock for now..
1994 f250 with a custom dump/flatbed heavy duty winch up front, 7.3 idi, None turbo...
bamboo is offline
Old 02-25-2009, 07:01 PM   #13 (permalink)
My Photos: (60)
Mahaloz..
-patch
Bulbs are white, the color comes from tint in the dash cluster.
Old 02-27-2009, 11:50 AM   #14 (permalink)
i found 168's but the bulb was green will that work still
Old 02-27-2009, 12:39 PM   #15 (permalink)
My Photos: (60)
It will work but it will change some of the colors in your dash display.
