Re: A different kind of chip question
A chip does not reprogram the PCM like a programmer does, it just overides it. So leaving your chip in a certain program will not leave that program in your PCM when you remove it. When you reinstalled your chip you want to make sure you seated it all the way in and you also want to make sure your switch is plugged in the right way and securly.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
