Old 10-15-2009, 12:48 AM   #1 (permalink)
Smile DIY Clutch Linkage Repair Instructions - heim joint, bushings
I recently did my own clutch linkage repair and documented it to share. Rather than using the stock nylon bushing, I modified a 5/8" female rod end heim joint. Its all very solid now and looks like it will last. Its also very servicable should it decide not to last!
Hope this helps someone
www.worldacumen.com/content/clutch.doc
1995 F250 4x4 Turbo Diesel regular cab, 5" exhaust, 6-pos ATS
getrolfed is offline
Old 10-23-2009, 12:50 AM   #2 (permalink)
Not to rain on your parade but there's a guy who's been selling a "kit" of sorts on Ebay using a cut down rod end like yours, but it's nice to have some intructions/pics too.
I did a similar mod several years ago and also eliminated the switch. More convenient and no close calls so far. Anyway IIRC I used a 3/8 rod end and didn't put a nut on the inside of the arm, just ran the both through both pieces, the rod lined up good this way. I also used a 3/8 bolt for the master rod - drilled a vertical hole in the head the same diameter as the rod, something like 3/16, and welded it, this provided adjustability too. I can take a pic if anyone is interested.
'94.5, ZF-5, S&B air filter, 3" downpipe & 4" Magnaflow exhaust, gutted EBPV, otherwise bone stock
preith is offline
Old 10-24-2009, 12:51 AM   #3 (permalink)
I did something similar to this and used an industrial "micro" switch with whisker on it for a neutral safety switch. The original switch is also a redudant cut off for the cruise control so I added a second push button style micro switch for that. Been perfect for about 3 years!
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 10-24-2009, 01:22 AM   #4 (permalink)
i did the same thing on my 1975 f250 when i installed a zf 5 trans and hydrolic's from a f450 back in 1994,,,that was a good truck,shame the kid i sold it to rolled it
1996 F350 CREW CAB,37"tires,2003 hpop,160CC injectors,electric fuel system.malery pressure reg.6.0 intercooler,sd bd turbo,sd 3 in intakes ,tw 4 pos. chip,gauges,tcc disconect,mod.e4od,rear detroit,20,000remote cooler,baja fiberglass body panels,stage 3 methanol...............former fmc diesel tech....
NORTHRIVER1 is offline
Old 10-27-2009, 05:16 PM   #5 (permalink)
I looked on eBay, but I couldn't find the kit for sale. I agree that a single bolt would have been better. I just installed a new LuK clutch and SMFW. The pedal now feels as light as my Honda Accord. Very light.
I have yet to test my cruise control! I suspect it will not work. Thanks for pointing this out. Saves me looking in all the wrong places for the problem.
Old 10-27-2009, 05:39 PM   #6 (permalink)
Supporting Member
bugman's Avatar
My Photos: (16)
Here is a LINK to the one on Ebay.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-03-2009, 07:44 AM   #7 (permalink)
Parky66's Avatar
My Photos: (5)
^^^ Yup, that's the eBay one that I used as well.
Works so GOOD that I forgot all about it... 4 years + !!!
Mike Parker - Parky66
1996 F-250 Ext Cab
Long Bed, 4X4, 7.3 PSD
(ZF5) 5-Speed Transmission
(Twildman's) 4 Position Chip
Auto Meter Cobalt Series Gauges on Full A-Pillar
Tymar Intake
(DPP) 3" Downpipe
(DPP) Catalytic Converter Delete Pipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
Old 11-03-2009, 01:16 PM   #8 (permalink)
If anyone's interested I have this available for resale. I couldn't use it because I had an aftermarket slave rod with a plastic end. PM me, it'll be cheap.
preith is offline
