Old 10-17-2006, 09:36 AM   #1 (permalink)
TheRubberDuck's Avatar
DIY injectors smoke pic
I thought you guys might like to see what kind of smoke my DIY 160cc injectors are makin. You can't see me very well through the windshield, but I promise there is a grin on my face. Thank you Jim.
www.ford-trucks.com/forums/attachment.php?attachmentid=2870&stc=1
TheRubberDuck
1995 F350 Crew Cab 4x4 dually
Stage 2 DIY inj
RSB 140v IDM
Tymar Intake
DP Tuner 2 pos. chip w/custom switch
FPR Shim 70psi
3"dp to 4" straight piped to 5" Stacks
Hot Pedal
I miss you No.3
RIP #17
TheRubberDuck is offline
Old 10-17-2006, 10:14 AM   #2 (permalink)
Re: DIY injectors smoke pic
link not working
2006 Ford 250 4x4 crew cab short bed auto
front windows 20% and back factory with 35%
auto meter gauges
4inch exhaust
JasonBarhorst is offline
Old 10-17-2006, 10:18 AM   #3 (permalink)
Crap! It worked in the test forum. And it works here for me. My deepest appologies guys I don't have time to fix it right now, I'll try later.
TheRubberDuck
Stage 2 DIY inj
RSB 140v IDM
Tymar Intake
FPR Shim 70psi
Hot Pedal
I miss you No.3
RIP #17
Old 10-17-2006, 10:24 AM   #4 (permalink)
Went to test form and didnt work there either.
auto meter gauges
4inch exhaust
Old 10-17-2006, 10:29 AM   #5 (permalink)
Is this it?
ford pinto with spinner hubcaps from walmart- big pimpin
Thunder_struck is offline
Old 10-17-2006, 10:38 AM   #6 (permalink)
Yes sir, that's it. If the link had worked, it would have come up a little bigger. But yeah, that's it. Thanks Thunder_struck. Did you just dig it up on the other site? I just put that on there this moring, and I thought for sure it would work on here. These computer thingys baffle me sometimes. Thanks again.
TheRubberDuck
Stage 2 DIY inj
RSB 140v IDM
Tymar Intake
FPR Shim 70psi
Hot Pedal
I miss you No.3
RIP #17
Old 10-17-2006, 10:53 AM   #7 (permalink)
Still not working for me. What other site is it on?
auto meter gauges
4inch exhaust
Old 10-17-2006, 03:02 PM   #8 (permalink)
PSDfreak's Avatar
Worked for me [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Looks awesome!
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 10-17-2006, 08:18 PM   #9 (permalink)
Its a dead link, sure would like to see it.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RSD Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake * gutted ebpv * 4" exhaust & 5" tip * AlumaCraft diamond plate toolbox * custom antenna mount (108" whip) * Uniden cb * diamond plate bed rail caps * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25 * ccv mod * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * poly bushings (front) * Rancho RS9000 shocks * dual steering stabalizer * 60,279 on rebuilt engine (myself) as of 1/08
To do list:IDM mod
94strokerace is offline
Old 10-17-2006, 08:20 PM   #10 (permalink)
fastg60's Avatar
not working for me, I'd like to see it though....
95 F250
5 spd
123k
fastg60 is offline
Old 10-17-2006, 08:28 PM   #11 (permalink)
Is this it?
Click on the words "this it" in the above quote
Old 10-17-2006, 08:30 PM   #12 (permalink)
fastg60's Avatar
yeah, i did that. all i get is a blank page.
95 F250
5 spd
123k
fastg60 is offline
Old 10-17-2006, 08:42 PM   #13 (permalink)
PSDfreak's Avatar
for some reason using an AOL browser I would get a blank page too so I opened up an internet explorer page, copied and pasted the address and that worked.
-Casey
PSDfreak is offline
Old 10-17-2006, 08:56 PM   #14 (permalink)
kfjensen's Avatar
I tried with Firefox and Internet Explorer, no go, this thread is dead...
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 10-17-2006, 09:00 PM   #15 (permalink)
My Photos: (38)
Not so fast, Click Here!
http://photos.thedieselstop.com/show...hp?photo=30453
some stuff
14.8 @ 90
gregrob is offline
» Network Links
»Ford Car Reviews
»Motorcycle Reviews
