Old 02-01-2007, 01:28 AM   #1 (permalink)
BKB
DIY Stage 1= 160cc good for towing? Better options???
I have a totally stock 96 PS out of a E-Van so i think i have the smaller turbo, Also E4OD. My only plans are IC, Intake, and free flowing exhaust without cat. I tow a 10k pound 5th and would like a little more torque but dont want to worry about EGTs. Would i just be better off with a chip? If i install the injectors would i still need a chip to help with EGTs? Money for mods is tight and this truck is only used in the summer for towing.
1997 F250 HD started life with a 351 gas motor, now has a PSD from a 1996 Ambulance. 4'' Magnaflow SS exhaust, 3'' SS downpipe, TW chip, Stage 1 DIY injectors, IDM mod, BB mod, Tymar intake, Gutted ebpv. Soon to have dana 60 up front with 05 radius arms and air suspension.
BKB is offline
Old 02-01-2007, 01:54 AM   #2 (permalink)
rednck21's Avatar
Re: DIY Stage 1= 160cc good for towing? Better options???
if you go with bigger injectors, you'll also need some sort of intercooler on there for towing.
2000 F-250, reg. cab, 4x4, XLT, 7.3, AFE stg. 2, MBRP 4", Autometer gauges
2000 Ranger, 3.0 daily driver
72 early bronco- uncut stocker!
ECBR
PICS
WEBSHOTS
rednck21 is offline
Old 02-01-2007, 02:13 AM   #3 (permalink)
Nit
well teh IC is goign to cost you as much as teh cheapest injectors so thats your choice. Your best bet would be Beans tranny savers teh 130cc ones, very small increae but worth every cent, you will need a chip to help with it, Tony W can set you up with some tow programs that would really help, with thsi setup you could get away without teh IC and save that money, add a good flowing exhaust and a Tyamr intake adn your set.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 02-01-2007, 08:09 AM   #4 (permalink)
Be careful with any injector upgrade...can kill the trans [img]/ubbthreads/images/graemlins/eek.gif[/img] Talk to Bean.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 02-01-2007, 08:13 AM   #5 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
Injectors won't do you much good without a chip. And where is it written in the Powerstroke laws that you have to have an intercooler to tow with one. CraigPSD has 175/190s and tows an '05 Mustang without going over 1100* in the hottest program that he has.
-Michael
Michael Paul
1995 F250: Regular cab, 7.3L PSD, 5-Speed, 4x4, 4.10 LSD, gauges, 2L chip, injectors, turbo, 4" downpipe - 6" tip, clutch, fuel system, Medium oil, Headstuds, Valvesprings, Cab lights, Dana 60 - New Look Soon!
1995 F250: Regular cab, 7.3L PSD, 5-speed, 4x2, 3.55 open, Intake, Downpipe, 4" exhaust, clutch, 2L chip, short throw shifter - To do list!
My Webshots
Dieselfever78 is offline
Old 02-01-2007, 09:50 AM   #6 (permalink)
BKB
Well for the price of the IC i think its a worth while investment. I have fabricated many ICs for turbo/supercharged cars and have alot of alluminum 3'' pipe around. Totall cost would be around $150.00 for me to build the IC, piping and spider. Anyone have a address for BEAN? The trans is a fresh rebuild and will be getting a transco tugger shift kit and im trying to learn about the many different TCs out there.
BKB is offline
Old 02-01-2007, 09:55 AM   #7 (permalink)
www.beansdieselperformance.com
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 02-01-2007, 11:37 AM   #8 (permalink)
My Photos: (13)
Does your motor have a fuel damper behind the fuel pump?
Could be AB code.
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 02-01-2007, 02:36 PM   #9 (permalink)
My Photos: (6)
-Michael
Sure. On level ground, ok.
Go hit some hills, and .. oops, there goes the EGT's north of 1200. Gee, wonder why that happened.
It is not written in law you need an IC, but arguably most everyone will agree that it is highly recomended.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 02-01-2007, 05:37 PM   #10 (permalink)
-Michael
Maybe you should come to KY and see some of these hills [img]/ubbthreads/images/graemlins/tongue.gif[/img]
-Michael
Michael Paul
My Webshots
Old 02-01-2007, 08:18 PM   #11 (permalink)
Well he must not try to go very fast up the hills when I had my stock 120cc in my 97 I could get to 1200 easey just getting on the highway. with a IC not a problem at all any more . Now with the stage II's I can get hot if i'm in a setting over 80hp. I Need New turbo bad. I would of never did injectors with out a IC
00 CC, LB, DRW, Black F350 4x4, 6 speed, lunar series Boost and EGT. DP tuner 6pos chip SBC clutch,fuel system. GTP 38R BB, by Diesel Inovations. Weld Typhoones rims, Tymar filter,CCV mod and TERMINATOR OIL.
97 CC, SB Green F250 4x4 5 speed, SBC clutch, F5 DP chip, Isspro boost, EGT.Stage II sticks, Tymar, CCV mod, TERMINATOR OIL, Banks pipe kit IC, fuel system, GTP 38R BB Turbo, Weld Typhoones
07 Dodge CTD, QCSB, Dark Gray 4x4, 6 speed, Tinted windows and a B&W hitch, MBRP 4in, AFE Stage 2 Progaurd 7, Centerline Wilderness Grizzly, Smarty CR, Quadzilla Commander, Fass 150, sbc , head studs so far a MPI twin turbo ,DDP 90hp tips also. It still smokes a little
deerezilla9620 is offline
Old 02-01-2007, 10:00 PM   #12 (permalink)
[/ QUOTE ]Converter is a no brainer P.I.Stallion ,it made my truck a whole new animal.
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
Aljay is offline
Old 02-01-2007, 11:30 PM   #13 (permalink)
How much did the pi stallion run you?
-Kord
( totalled)white and turquise 96 with 175,000 miles. 4 in lift with 16 in welds and 35 in bfgs. 5in straight pipe exhaust, twildman 4 postion, pyro and boost gauges, diy tymar, Built Tranny. new turck white 96 130,000, 4 in lift, 35 in tires, 4 exhaust, intake, gauges, tw 4position and built tranny
96strokerwg is offline
Old 02-02-2007, 12:11 AM   #14 (permalink)
Garret at puredieselpower.com has them for a decent price.
2000 Black Excursion,PFC 2 piece rotors,Tipton tuned,BDP stage 2 singles, BDP H2E, AFE stage 2, Spearco 7.3, ITP Reg. return fuel system, Evans, BTS, 186,000 miles....And still goin' strong! Thanks Beansdieselperformance.com and Puredieselpower.com for all your help
BBBxcursion is offline
Old 02-02-2007, 01:41 AM   #15 (permalink)
Nit
1, if you can make an IC then hell yes do it, that is worth the money.
2. then do the DIY injectors, you can make then smaller if you want like 130-150cc, very easy.
3. a good chip, call T Wildman is worth every singel penny you spend on it.
open teh exhaust and use a Tymar intake
A PI Stallion is a great TC, really great, but do not install teh tugger kit before you get it, teh plate can not be drilled very must before it is too harsh.
pictures
dirty30
Nit is offline
