Old 02-05-2007, 06:44 AM   #31 (permalink)
Re: Do OBS trucks defuel when you hit 25psi?
The pressure regulator will allow the regulated pressure to rise to the setpoint and stay there until the supply side pressure drops below the regulated pressure setting, then the regulated pressure will drop to the value of the supply pressure "moving" or not. This is why the regulator works when installed in a truck. Adjusting the regulator to a lower setting once it has been pressurized with a higher supply pressure will not drop the output pressure since there is no place for the excess air pressure to go since the regulated side is not vented.
For ease of adjustment, just put a plug into the regulated side of the regulator with a small orifice in it like the smallest drillbit you have. then you can just dial in the pressure without having to vent off the supply side air.
I bought the pressure regulator because I couldn't find a pop-off valve low enough for what I needed in Grainger or McMaster-Carr. Obviously others can read the catalogs better than I! If you can find a pop-off valve that works then it is much easier to just tee in the pop-off valve into the map line.
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline
Old 02-05-2007, 05:49 PM   #32 (permalink)
My Photos: (28)
http://www.dieselsite.com/index.asp?...&ProdID=31
'97 F350 CC, XLT, 4WD off road, 4.10, Milemarker manual hubs, Suncoast E40D w/ Bob Riley's (Dieselsite) remote filter & Triple Lock Torque Converter, Hypermax H2, BABY SWAMP'S! Swamp's 20* HPOP, Head Studs, TS 4 position chip w/ Bill's programming, Banks Intercooler. Ceramic coated up-pipes and down pipe. Triple pillar w/ Isspro boost, trans temp and digital EGT gauges. 4" Exhaust. 45gal Transfer flow rear tank. Dale Isley's HX mod. Joe Servo's IDM mod. Bob Riley's coolant filter, Coolant "T", Evans Coolant, A/C mod. Velvet-Ride's, Monroe Gas Magnum Shocks. TSM's rear disc brake kit. Frozen/ Slotted front rotors with Hawk Pads. Centramatic Wheel Balancers & 285/75/16 Michelin LTX/MS. Interior sound deadening (what a difference!).
BLDITRT1 is offline
Old 02-05-2007, 06:08 PM   #33 (permalink)
Thank you to all who helped out on this thread. The info here will more than likely help other people in the future. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
I already had this one in my box of air fittings at home. 25psi is the lowest spring. Will probably try it first.
http://www.grainger.com/Grainger/wwg...mId=1611785282
2nd, I'll try this one which looks pretty nice. Could probably calibrate it with a T fitting and a guage on the bench.
http://www.grainger.com/Grainger/wwg...mId=1611571470
Third I could try the pressure limiting ball style valve that I got at home depot...may just keep it for the air tool accessorie box though [img]/ubbthreads/images/graemlins/cool.gif[/img]
PS BLDITRT1, thanks for the link. Looks like that one is setup for immediate bolt in. No running around looking for fittings etc. [img]/ubbthreads/images/graemlins/cool.gif[/img]
'97 F350 PSD E4OD CC 4x4
265/75/16, BB shim=73psi, Open Element, 10K with switch on dash, IDM mod, 30K Hayden tranny cooler, 3" downpipe, 4" straight pipe, the usual gauges, Bullydog 6 position chip. Biodiesel as much as possible.
Tankota is offline
» Sponsor Links
»Garage Storage and Cabinets
